Question about Motorola Mobility RAZR V3
Backlight stays on bright
When the case is closed the front cover display light go off resulting in quick battery drain. This is on both my daughters and mine. We previously had external covers on and that might have created the problem although it appears to shut correctly.
  • John Shelby Apr 04, 2008
    The display light doesn't go off when the phone is closed.
  • John Shelby Apr 16, 2008
    I didn't have to reset phone because resting it seemed to work.  However  am still going to figure how to get reset code.
    Thanks.
    Problem Solver:
  • 21 Answers
Try reseting your phones!
Posted on Apr 05, 2008
The back light is out, how to turn it on?
1.Check your monitor brightness setting. Occasionally, the monitor brightness can get accidentally turned all the way down. This will result in a completely dark laptop screen that appears to lack a backlight. Adjust the monitor brightness via the dedicated brightness keys at the very top of your laptop's keyboard.
2.Toggle the backlight back on via the keyboard. This is accomplished by using the "Function" key, which lies near the bottom left of your laptop keyboard and is marked "Fn." When pressed in conjunction with one of the "Fx" keys on the top row of your keyboard, you can toggle the backlight on and off automatically. There is an "F1" key, an "F2", and so on. The exact key to press simultaneously with your "Fn" key will vary by laptop model, so consult your computer's user manual. You may have accidentally toggled the backlight off and simply need to toggle it back on via this key function.
3.Prepare to operate on your laptop if you cannot toggle the backlight back on. Shut down the laptop. Disconnect the AC adapter cord from the back of the computer, then close the display and turn over the computer.
4.Remove the battery. The battery on most computers is at the top of the laptop's underside, although some computers may feature the battery in a bottom corner. The horizontal outline of the battery will be clearly visible all the same. Beside or just beneath the battery will be a battery-release latch. Slide this to disengage the battery.
5.Turn the laptop back over. Open the display.
6.Observe the bezel, which is the perimeter that runs around the display. There will be a number of rubber caps that exist on the bezel. The exact number will vary by laptop model. Use the tip of a flat-head screwdriver to pry under the caps and pop them off.
7.Remove the screws under the laptop bezel's caps with your Phillips screwdriver.
8.Work around the bezel's perimeter with your fingers and pry the bezel completely off.
9.Look at the bottom of the monitor assembly. A thin inverter board will span horizontally across the screen's bottom. There is a connector on either end of the inverter board. If the right cable is loose from the right connector, lift up on the connector and slide the cable back in. This will restore the laptop's backlight.
10.Replace the bezel and the bezel's screws. Reinsert the battery and power on the laptop.
Sep 12, 2011 | Computers & Internet
Has a Toshiba Tecra 9000 won't power up. Power light on front is blanking which appears to be a code 3-3-2
The problem is cause due to one of the following: the backlight or the display, check your monitor brightness settings. Sometimes your brightness may accidentally have been all the way turned down, resulting in a blank/dark screen. The monitor controls are on the keyboard, directly above the numeric keys.
Look closely at your laptop's screen if the steps do not restore power to it and if it remains blank. Can you see a faint image on the screen? If so, the backlight may be off due to the LCD "lid close" detector malfunctioning. This malfunction likely happened due to the lid close switch being stuck in the "closed" position even though the lid is open. The switch is located beside the LCD's screen hinges, and tapping the switch a few times should unstick it.
Use an S-Video cable and plug your laptop up to an external monitor, such as your television set. With the laptop and TV hooked up, turn both on and see if your computer's desktop is displayed on the TV. You can also use a fifteen ( 15 )pin monitor desktop monitor by connecting it to the blue fifteen ( 15 ) connector at the side of the laptop if you cannot see anything on screen it is the display problem. If it is, your laptop's display needs to be replaced. If not, your motherboard and/or video subsystem may need to be completely removed and replaced.
Aug 31, 2010 | Computers & Internet
My daughters Camry keeps draining the battery. We
the light in the trunk may be on as well, it could be on the same circuit as the door lights
Apr 13, 2010 | 1989 Toyota Camry
How do I get rid of a blank screen on my laptop
You may have a defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
Sep 16, 2009 | Dell Inspiron 1501 Notebook
Camera turns on fine. I could view picture and all. Just that when I switch to camera mode a video screen is blacked out. Why is that?
Your have a "Display" button that toggles thru different display modes .. one of the modes turns off the LCD backlight .. that useful if you are in bright light and dont need the backlight .. you have a very nice "transflective" display that works great in bright light without the backlight ... you can get more shots with the backlight turned off on each battery charge .(about 25% more) .
so each time you operate the display mode button you will get a different display .. one shows a hystogram .. one turns off the backlight and one puts the camera in a normal mode ..
if everything is working right then even with the backlight turned off you should be able to go outside or any brightly lighted area and see the picture on the screen ..
Sep 04, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
Front display stays dark after boot sequence
you must forget to re install the magnetic piece which located in the lower left corner of the lcd frame cover try to check it
Jun 18, 2009 | Nokia E90 Cell Phone (Unlocked) - Black
Front key pad stays lit all the time on my wifes envy2 runs battery down
Go to your display setting. Then go to backlight, then click keypad. And then you can choose how long you want it to stay lit up. Hope I helped
May 23, 2009 | LG enV VX9900 Cellular Phone
Front cover display light
Check your settings. You might have the back light display as always on. If that dont work then try resting the phone.
Apr 04, 2008 | Motorola Mobility RAZR V3
Display disappeared of orange spv m3100
sounds like your backlight brightness is turned all the way down. this happens automaticlly on my windows 5 mobile device when the battery is almost dead and when i recharge it it stays this way. if you take and turn it from side to side you can see a faint outline of the windows under a bright light go start settings and adjust the backlight brightness up this should resolve your problem
Apr 03, 2008 | Orange SPV M3100 Smartphone
Motorola Mobility RAZR V3 Logo
109 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
