Question about Sharp AR-207 Copier
My sharp ar-207 is flashing an L6
I would like to know can this be fixed in the office or do we need to call a technician. I have fixed other problems with your help before. Can you guys help me once more.
The machine flashes L6 and when you press the print button it gives a 10.
What can this be? Please help.
  • Anonymous Aug 25, 2008
    I tried to make a copy and i received an error L6... I don't know what that means.. could you help me over?
  • Anonymous Sep 04, 2008
    AR-206 Laser photocoper flashing L6
  • 24 Answers
Like Patrillica says you will need a new polygon motor for the laser unit or replace the laser unit, not cheap and a time consuming job.
Posted on Sep 12, 2008
    Scholar:
  • 141 Answers
This is a polygon motor lock error (LSU).....This is a very good job if you never did it. You may wan't to service it or at least get a estimate...
Good lock !
Posted on Apr 04, 2008
My Sharp AR-M205 Copier has developed a problem. The code L6 is flashing up on the Display panel. Someone suggested I might be able to fix it by 'resetting' the machine. Can anyone advise how precisely to...
L6 is polygon motor lock (in the laser unit). To try and reset on the keypad press P * C * (pound star clear star) and enter sim 14 and press copy button. the machine should restart if down right. If the code comes back the LSU unit will need to be replaced. Should be done by a trained tech.
Aug 25, 2010 | Sharp AR-M205 Copier
Part Number of laser diode (Mitsubishi), Sharp Copier AR-M160.
L6 code means the motor is not working. You need to replace that, which means replacing the entire laser module. They can be gotten cheaper used from your local sharp dealer. I know this because I work on these things every day, being a certified sharp tech. L6 code means motor lock or motor sense dead, not necessarily laser dead.
May 25, 2010 | Sharp (SHRAM900) All-In-One Laser Printer
AR 207 copier with code L6
L means LASER UNIT is defective
Apr 06, 2010 | Sharp AR-207 Copier
Sharp AR 207 displaying L6-10
HI for L6-10 you must change the polygon motor and if you are unlucky may change all the laser unit but usually with the polygon motor it is ok
Mar 22, 2010 | Sharp AR-207 Copier
My copier flashes the L6 code and 10 when I hit print, how do I fix this?
Hello sir; The error code you display, that's means laser motor problem, need to replace it the item# is DUNTK0041RS52.
Sep 30, 2009 | Sharp AR-207 Copier
Sharp AR-M205 - Error Code L6
Hello sir; "L6" display it means laser motor defect need to replace.
Aug 19, 2009 | Sharp AR-M205 Copier
The L6 code is flashing on my copier
No you can't, it is the polygon motor not rotating. It is inside of the Laser unit. You should replace the polygon motor. The part code is RMOTN0028QSZZ. It will cost you about US$ 80
Jun 04, 2009 | Sharp AR-160 Copier
Error Code E 7
press"clear","interupt","0","interupt",enter14 press start.should take care your problem.
Dec 15, 2008 | Sharp AR-207 Copier
I have a sharp ar-m160
if you press the print switch while the l6 code is in the window you will get a second code. more than likly it will be a 10 that means your laser unit is bad & needs to be replaced.
Nov 12, 2008 | Office Equipment & Supplies
AR-206 copying problem / paper comes out slanted
There could be somthing in you ADF that is keeping the copy from going in properly. Your tires could need cleaning or there could be something going on with a component in the ADF.
Sould have a technician inspect the ADF to see if it needs cleaning or parts.
May 30, 2008 | Sharp AR-207 Copier
Sharp AR-207 Copier Logo
371 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
