Question about E-Machines eMachines Monitor E15T4
Cannot change color on monitor
I've tried using the monitor's menu to adjust the colors on my monitor. The monitor makes everything too red. However, when I click on the menu - color - the only option that is available to me is "cancel." How do I change this? Thank you.
  • 2 more comments
  • eurekablyth Apr 04, 2008
    The monitor is an HP vp17.
  • babiyboo0611 Jun 02, 2008
    my black and reds in my screen loock the same pls help!!!
  • vcasselberry Nov 23, 2008
    I have the same problem with my monitor it has to much yellow.
  • Anonymous Dec 27, 2008
    i have problem with returning color to monitor. i dimmed the screen using the buttons at the bottom to prevent glare. now i cannot reverse it and get true color again. what do i do? it is a 17 " flat screen kogi monitor
E-Machines eMachines Monitor trying to adjust color and screen turned red
Posted on Nov 20, 2008
  • 3 Answers
Check the R.G.B voltages at the crt base.if it is ok the crt may be defective.
Posted on Apr 04, 2008
SOURCE:
The color adjustment won't work. I click on it and go down on other adjustments but none will open to adjust the colors.
you can buy a universal remote for 1 dollar.. option 1 however if you are using componelt input as in RGB then you have no control over your colors
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Oct 07, 2014 | RCA P52927 52" Rear Projection TV
Display coming red in colour
Use the following steps to troubleshoot this problem:
  1. First try resetting the color settings using the following steps:
    1. Right-click on the desktop
    2. Choose Graphics Properties (or choose Graphics Options), and then Graphics Properties...
    3. Click on the Color Correction button (or click on the Color tab).
    4. Click Restore defaults.
  2. Next, check for a button or menu item on the monitor for adjusting the color balance. (See the monitor manual for more information.)
  3. Unplug the monitor from the computer and plug it back in again to assure the monitor is connected securely.
  4. Examine the monitor's VGA connector to make sure there are no bent or broken pins.
  5. If one is available, attach a different monitor to see if the problem goes away.
  6. Attach the monitor to a different computer to see if the problem is with the monitor itself.
  7. If the problem persists, the monitor may be damaged or defective.
Feb 16, 2013 | ASUS US M5A78LM LX Motherboard AMD Socket...
Images on screen are very red. Tried adjusting everything in the menu but still every thing is like glowing red.
Color balance is labeled "Tint"
Color amount is labeled "Color"
Both are in the "picture" adjustments menu.
Either your tint is swung too far to red, or the color setting is wide open making normally pink faces look sunburned...likely it's a combination of the two; Too much red, and a bit too much color.
Going back to the "default factory setting" in "setup" will also drop all settings to center.
Mar 30, 2010 | Hitachi 50V500 50 in. HD-Ready LCD...
HI,the color on my monitor has gone blueish its like
try reseating or/replacing the cable. If the connection isn't good then you can lose one of the three basic color channels resulting is a tinted screen color
Jan 08, 2010 | Acer AL1916B 19" LCD Monitor
Viewsonic VP930b color problem - Red tint
Go to the setup menu on the LCD panel by pressing button 1 on the front. See if there is an option to reset the lcd to factory settings. Reset it and report if it helps not.
Jul 29, 2009 | ViewSonic VP930b 19" LCD Monitor
SVA 17" flat monitor screen color is pink.
It's not a "windows" problem. At the bottom of your monitor there should be a 'menu' button. Push the button and use the up and down, right and left arrows on your keyboard to scroll to color. Get the "red" color and adjust it down. You can also scroll through to 'contrast' and adjust that. You don't need to pay a bunch of bucks to have this fixed.
Apr 10, 2009 | SVA-USA VR 17S 17" Flat Panel LCD Monitor
Acer's x193w killing my eyes..please help
First off, LCD monitors have what is called a 'native resolution' and that is why it is recommended to be at 1440 x 900. That is the resolution they work best at. My first suggestion is to try to move the monitor closer to you. If that is not possible, try right-clicking on your desktop, click on the Properties tab (That is where you change the resolution. I am doing this for a Windows XP machine - if you are running Vista please let me know and I will try to walk you through it there). Click on the "Advanced" button and in the "General" tab, there should be a "DPI Setting" drop down box. There is usually 96 DPI and 120 DPI. Try 120 DPI and see if that helps.
Second, try using your monitor's menu settings to help the color settings. On your monitor there is a "Menu" button of some sort. Press that and select "Acer eColor Management" and try "Text Mode" to see if that is easier on your eyes. You can also manually adjust the screen and lower the strength of the red color by picking "User" instead of "Acer eColor Management" and selecting the icon that looks like a pyramid of 3 dots. Try adjusting the Red slider and see if that helps.
Jan 02, 2009 | Acer X193W LCD Monitor
Sony T240HD monitor TV
make sure that the plug on ps2 is connected and check the settings on tv and the settings on ps2 browser are correct if possible check ps2 on another tv to be sure of it's settings if the ps2 works the check channel setting on tv make sure it's not in pal setting it should be ntsc and also check the antenna setting make sure it might be set to cable and also check cables of any sharp kinks your problem is with the yellow cable red and white is the sound
Dec 01, 2008 | Samsung T240HD 24 in. LCD TV
Crt monitor video chroma processing
first you check the signal cable continuty by multimeter then correct it if faulty .if ok then give -ve click at red cathode on crt base in on condition if red raster comes on screen then red cathode is ok same thing for green and blue cathode if green cathode do not shows green raster after -ve click then crt is faulty then give -ve click at R point at color raster ic which has heat sink if red color comes then ic is ok same thing for green and blue if ic is faulty then replace it if not then check bipolar capacitor if faulty then replace it
Sep 15, 2008 | AOC CT720G 17" CRT Monitor
Colors are off after auto adjust
I seem to have found the solution (and the cause, perhaps?) for this problem!
I was having the EXACT same problem with a monitor I'm repairing for a friend. The capacitors on the power supply board were blown (CapXon capacitors, who'd've guessed), which was keeping it from powering up. After replacing the capacitors, the screen worked beautifully. But it had this weird yellow tint!
The strange part was that pure colors - red, green, blue - all appeared perfectly OK on screen. Curiously, the menus would show in the proper colors, except for one: the manual color adjustment menu, which illustrated "Blue" as a sort of off-green in the icon. Auto-Adjust would always fix the colors for a split second, then go back to yellow. Reset didn't fix it. Color reset didn't either. So, exactly the same problem as above.
The solution I found was hidden within the main menu itself, a sort of "easter egg". <b>Hold the Menu button down while pressing Power, and hold it down until the screen, and menu, appear</b>. There will now be a hidden selection, "Auto Color", printed in a red-on-black font at the bottom of the menu. Use the +/- buttons to access it, and press Menu. Voila! PERFECT COLOR! Perhaps this menu was accessed by accident, and calibrated to an incorrect color key. But now my picture works great, and the setting lasts through Auto-Adjusts and Resets!
Hope this helps some people, it sure saved my ****! ;)
Dec 05, 2007 | AOpen 19" LCD
E-Machines eMachines Monitor E15T4 Logo
355 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
