Question about Intel Motherboard
Cpu overclocking I have a amd 64bit socket 939 3000+ cpu and want to overclock it to play games abit better. When I load files or movies I can see my cpu running at 100% for a long time. I always clear my cache memory and removed a lot of startup programs but I think overclocking is my only option. Money is thight so I can't afford to buy a new cpu or pc. Please help to tell me what to do or what software to run. Regards Steve
  • Anonymous Mar 25, 2014
    any software that can overclock on this motherboard?
  • 98 Answers
Try this. press ctrl-alt-delete to view your task manager. Click the processes tab. From the list of items, look at CPU and Mem Usage to see what all is running.
Posted on Apr 04, 2008
Hello, I would like to overclock my AMD mt30 CPU 1600Mhz25wattTDP 64clockspeed/power ratio to that of a SempronML37 2000Mhz35WattTDP and 57.1 clock speed/power ratio? Do I just change the voltages in...
Due to the way you stated the above John, you seem like a guy that will understand the following;
Yeah know funny thing about overclocking;
1) You may have a good Processor that came off the assembly line that day, or it may be one that just squeezed past Quality Control. Push it too much, and it will fry. Trying to make it hit 2.0GHz all day long, every day, may just push it over the limit. Sure you may have read about, or even heard of someone who did it. How long? How long did the processor last at this overclocked rate?
2) AMD's run H-O-T. Not a good idea to push a Processor with overclocking (Which makes it run MUCH hotter) in a cramped laptop environment, with a low cooling capacity anyway.
3) Ram Memory typically operates at half of the FSB Frequency Rate ('Speed'), that the Processor does. (Front Side Bus)
To overclock you can;
A) Change the Voltage
B) Change the FSB frequency rate ('speed')
C) Change the Multiplier
If you change the Front Side Bus frequency rate too far, the ram memory will not work anymore.
Won't match.
AMD Turion 64 MT-30,
http://en.wikipedia.org/wiki/List_of_AMD_Turion_microprocessors#.22Lancaster.22_.2890_nm.29
The Sempron you name is a Turion also.
Turion ML-37,
4) You have to have a BIOS Setup Utility that will allow you to change CPU parameters.
See this article?
http://www.ehow.com/how_7335931_overclock-turion-64-compaq-nx6125.html
No mention that overclocking a Processor shortens it's 'Life Span'
No mention that if overclocked too far the Ram Memory may not work.
No mention that an AMD processor runs HOT, and if you overclock you'd better have a lot more than the factory cooling. Plus not a good thing for a laptop anyway because of a laptop's poor cooling design. (Cramped small space, small fan, inadequate cooling thermal module)
No mention that the BIOS Setup Utility in your laptop may not have a CPU Soft option, or options inside that allow you to change the Processor's parameters.
No mention that you should go slow. Change parameters in one SMALL increment, wait 24 hours, and check the system. Looks okay? Change parameters another small increment. Check during a 24 hour period. Keep going until the computer starts messing up, then go BACK to the last parameter that checked out okay
Have I dissuaded you yet?
No?
Just don't want to see someone fry their Processor, or computer.
Okay.
The Turion MT-30 has a clock multiplier of 8 times. (8x)
The Turion ML-37 has a clock multiplier of 10x.
The Turion MT-30 uses 1.35 Volts (DC)
The Turion ML-37 uses 1.35 Volts (DC)
The Turion MT-30's Front Side Bus frequency rate is 800MegaHertz
The Turion ML-37's FSB 'speed' is 800MHz.
What options in your BIOS Setup do you have for changing CPU (Processor) parameters?
State back in a Comment. (Believe top right of your page)
No options?
Then try CrystalCPUID, or ClockGen,
1) http://crystalmark.info/software/CrystalCPUID/index-e.html
2) http://files.extremeoverclocking.com/file.php?f=189
3) http://www.cpuid.com/
Regards,
joecoolvette
Sep 18, 2011 | AMD Turion 64 Mobile MT-30 1.6GHz 25W 1MB...
How to overlock my e5500 2.80ghz to 4.5ghz???? or the highest overlock that can e5500 dual core
Hi there, your first going to need better cooling for your cpu like a aftermarket cooler and then go into the bios and raise the cpu multiplier and cpu voltage bit by bit
Mar 03, 2011 | Intel Pentium DualCore E5500 28GHz 800MHz...
Asus k8v se deluxe motherboard
You talking overclocking? That is only with amd cpu's and if you have a amd you need a overclocking tool www.overclockers.com should help you in this regard.. Please leave me good feedback as we do not get compensated for free questions so we look at your vote for out gratitude thanks..
May 15, 2009 | Computers & Internet
Overclock a black edition 5000 x2
@johnhercus26
pls let me remind you that overclocking voids your pc's warranty.you will need to enhance the cooling solutions for the device you will overclock plus the cooling solutions for the CPU case, every time you overclock, more heat is produced by the device you are overclocking. also you have to make sure you have power headroom..., a higher wattage CPU power supply. plus the risk that you may toast your pc or lessen its usable life. overclocking is for advanced users so pls take extra caution if you will do it.. for guide and instructions pls click here and goodluck! >>> http://www.pcstats.com/articleview.cfm?articleID=1804
Oct 23, 2008 | AMD Athlon 64 X2 3800+ Dual Core Processor...
Sandrew
There are different ways to overclock, however some methods might harm the CPU I am adding the link which shows the methods. here is the link
http://www.amdboard.com/ocspecial.html
Also please make sure your BIOS supports overclocking
Good Luck
Jun 19, 2008 | AMD Sempron 2800, 2.0 GHz 2800+...
Overlocked my Intel Pentium 4 3.00 Ghz
You have to go into your bios and see what your front side bus and memmory speeds are. If you overclock you cpu, sometimes you need to underclock your memmory. Say step your memmory down to 333mhz and overclock your front side bus(fsb).
Normally your fsb is 200 and only increase it by mhz. Restart, go into windows. and see if it is stable.
I always use cpu-z and gpu-z to check all of my hardware settings. I use ati tool to overclock my x1950 and it is great. There really isnt any good cpu overclocking tools because its better to do it in the bios.
Do a specific search in google for your processor and overclocking.
Jun 06, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Overclocking
try in the bios first. it will be under something like 'cpu pnp options' then select overclocking, ENABLE. then under it it may have something like a bus frequency setting. it should be at the stock setting. to overclock, set the # higher. hope that helps you, cause that's what i did. BE SURE TO HAVE ENOUGH COOLING FIRST!!!
download speedfan to check the cpu temperature. (Free)
May 21, 2008 | Computers & Internet
Links to overclocking tools
Software tools only work if you have a motherboard chipset which supports them. If you have an nVidia nForce chipset, I recommend nTune. If you have something else, check with the manufacturer of the motherboard and they may be able to recommend a program which can overclock for you.
As a rule I do not recommend overclocking blindly. If you do overclock, make sure you do it safely and be aware that you are voiding the warranty of both your CPU and RAM (unless your memory warranty states otherwise).
Overclocking can be done safely and I recommend you keep a guide closeby when attempting it for the first and 100th times. You can find a guide in this issue of Maximum PC.
Apr 03, 2008 | Video Game Consoles & Games
Gaming processor.
No lie, the best and cheapest you will find for gaming, and for overclocking is the AMD Athlon 64 X2 2.6Ghz "Black Edition" It is a dual core, AM2 socket, and has unlocked multipliers you can access through your bios, which is perfect for a newbie to mess around with overclocking. Go to www.tomshardware.com and search for it, they did a big article all about overclocking it which will explain why its so great. Best thing is its 90 bucks on www.newegg.com , just plan to buy a fan and some thermal grease, wont run you much more. Good luck and happy overclocking.
Jan 26, 2008 | Computers & Internet
Motherboard suggestion
If you are looking for the best socket 939 motherboard then its the DFI lanpaty ultra d that you want :)
Hard to find new now but plenty on ebay. Great boards for features and fantastic overclocking potential.
If its a socket 754 cpu you have i think they also did a similiar version for that platform too.
Dec 27, 2007 | Computers & Internet
Intel Motherboard Logo
77 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
