Question about Samsung SF-330 Plain Paper Inkjet Fax
Not sending fax
Suddenly, and for seemingly no reason, the machine has stopped sending.
I done a test via the maintenence option and it returned the message:
"1.Tel. Line Test : Check Telephone Line Cord"
I've tried:
1. Swapping the phone cord
2. Testing the line
Both of these tests revealed no problems with the hardware.
Any ideas?
    President:
  • 2,072 Answers
Plug a phone into that line and see what happens. Let me know what happens. Plug the phone into the line that goes into the fax machine. Make sure it works and is clear. No static or noise.
Posted on Apr 04, 2008
SOURCE:
What does it mean when my Muratec Fax Machine says DHCP Server Did Not Respond and it will not send or receive documents?
DHCP is the way systems on a network get an address from the network. In a home environment, that's usually done by the router. Unless your fax machine is attempting to send faxes via the internet (rare), that isn't why your machine can't send or receive a fax. If you're talking about sending a fax from your computer, then not having an address is indeed the reason you can't send a fax from your computer.
You will need to see why your router isn't giving the fax machine an ip address. Is it connected to the router? Wireless? Wired?
Jul 08, 2015 | Muratec Office Equipment & Supplies
Why did my fax machine suddenly stop working?
Check that the memory is not full. Also, make sure a setting like (auto-dial 9 for outside line) is set incorrectly.
May 17, 2015 | Office Equipment & Supplies
What does transmission report cdoe NG290000 mean on a Sharp MXM363n MFP When trying to send a fax?
My recommendation would be to hit the speaker button when sending a fax to hear why your fax wont go through.
When you hit speaker you should have a clean dial tone, then when you start dialing and the tone stops make sure you don't have any static or noise on the line.
There are several reasons you might get a NG error. One is the fax line you're trying to send to is busy. Maybe it's a phone line not a fax you're trying to send to. Maybe you need to dial a 1 or 0 for long distance, maybe your fax line has noise on it.
Using the speaker can help troubleshoot what the problem is.
Jun 12, 2014 | Sharp Mx-M363n Copier, Printer & Scanner...
How to print to fax using the canon imagerunner 2020i
On the installation cd's of the machine there is a fax driver if you install the fax driver the fax is showing as a fax in the printers and faxes in the controll panel.If you print to the fax a window will open where you tipe the name and number you want to send the fax to.There is also a option if you want to add it to the addresbook.After editing the info add it to the receipient list and send.Your document will faxed from your computer via the IR machine,if your machine is connected to a fax line.
You can edit the address book easy by logging to your machine via your broser tipe the ip address of the machine in your browser and press go.If the machine is connected via local LAN.
Nov 16, 2009 | Canon Office Equipment & Supplies
MFC 7840W, fax not sending or receiving
Is your phone line DIGITAL? Fax machines are ANALOG devices.
Jan 15, 2009 | Brother MFC 7840W Printer
ADF feed problem after going into the maintenance menu
Are you sure there's not something blocking the ADF.
Open it up and look inside, especially for a switch actuator being held down.
Oct 17, 2008 | Office Equipment & Supplies
Cannot receive faxes, but can send
I can send faxes from my HP Fax 1010, but cannot receive them. I can dial the number from another phone but it will keep ringing and the machine never picks up. We have tested the phone line and all seems well. Is there some setting on the fax machine itself that I need to change in order to receive? Any assistance you can provide would be greatly appreciated.
Aug 25, 2008 | HP 1010 Plain Paper Inkjet Fax
Fax sent is sent blank
it seems to me as if the person you are sending the fax to has some problems in his fax machine tell him /her to get it tested or see whether the ink in their machine is suffiecient or not and do the same on yours as well,and also try to see are you entering the page into your machine right way? i think you will get your answer here easily
Feb 22, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Samsung SF-330 Plain Paper Inkjet Fax Logo
Top Samsung Office Equipment & Supplies Experts
jasbo
jasbo
Steve Allison
Steve Allison
Lawrence Singapore
Level 1 Expert
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
