Question about Asrock K7VM2 Motherboard
K7vm2 lost the mouse
I have a k7vm2 motherboard and have had no probs untill nmow. i have lost the mouse pointer. i have re installed but its still not there csan you help at all
cheers
ian
Ok on the bottom right of the k7vm2 main board there is a jumper situated between the ir connector and the front panel connector, under which you'll see a connecter labelled ps2_usb-pwr make sure it is set 1-2 and not 2-3 and this should solve that problem if not
Posted on May 07, 2008
  • 13,433 Answers
Ps2 mouse or a usb? try reconnecting the mouse and another mouse.
usb mouse might work?
Posted on Apr 06, 2008
How to install maxwell MOWL-07 mouse?
you will need the usb driver for this mouse
make sure you have the correct mouse selected control panel mouse hardware
might have to uninstall the drivers then reinstall the drivers
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Dec 06, 2010 | Computers & Internet
Please show much higher compatible microprocessors
As per my concern if u want to replace & ugrade all the parts then u take a NVIDIA motherboard only because , the fx5500 videocard is of NVIDIA geforce company only thats why it will suit the motherboard itself & also nvidia provides 256MB onboard videocard so if u keep fx5500 videocard free it will be all right
Let me know is this helpful to u or not
Jul 05, 2010 | Asrock K7VM2 Motherboard
Mouse pointer is fixed
Improper boot media means it's not seeing your hard drive. Check hard drive ribbons and power connectors. Your hard drive might have failed if the ribbons and power connectors are installed properly.
Oct 01, 2009 | Intel D845GEBV2 Motherboard
I've lost my manual and I can't get the laser pointer part to work.
Press and hold Fn button and Laser button until the light turns red.
Aug 30, 2009 | Honeywell PP4IN1 PP4IN1 4-in-1 Wireless...
Freezing or Jumping Mouse Pointer
This could happen if the PS/2 connector on the motherboard is defective, or if there is a failing component in the PS/2 circuitry on the motherboard.
Could also be due to loose solder points at the PS/2 connector.
This needs to be checked by a qualified technician.
Apr 12, 2009 | Foxconn 661MX Motherboard (FOX661MXMB)
BIOS check stops at "checking NVRAM"
yeah, replace the battery it will definitely solve the problem.
Feb 23, 2009 | Asrock K7VM2 Motherboard
Asrock K7VM2 m/b reading RAM
Its hard to say try just using one stick and booting up if it reads all that then its a ram if it doesnt then it seems like it could be a bios or m/b issue
Feb 11, 2009 | Asrock K7VM2 Motherboard
Como hago para conectar los puertos usb
Hola, espero que sabes leer ingles, baja el manual (ingles) en la sigiente coneccion: http://download.asrock.com/manual/K7VM2.pdf
Apr 30, 2008 | Asrock K7VM2 Motherboard
Asrock K7VM2 Motherboard Logo
74 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Computer Links
Iqbal Husain
Iqbal Husain
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
