Question about Canon imageRUNNER 5570 Copier
After power outage we get a service code
Every time the power goes out the copier gets a service code.
We can't turn it back on until we put in the service codes.
Any thought? No other machine does this here.
  • 168 Answers
The service code is probably "loss of Power" error.
One thing you might try is getting a battery back up that is rated for a copier machine.
This way if the power goes out the battery back up would keep power going to the machine preventing the error code.
FYI... the battery back ups are NOT made for copiers. You need on that is rated to back up a regular copy machine.
Hope this helps a bit.
Good luck.
Have a good day.
Mac =)
Posted on Apr 05, 2008
I have a konica Minolta bizhub c450 it was running fine until there was a power outage when powered on the device read an error code CD370 and the language was in chinese or japanese after clearing the...
you should be able to get into service via trouble reset hold utility button while turning on copier when you get to trouble reset screen do the stop 0 stop 0 1 and that should get you in. You might need to put the stock firmware on to cure the fault. If you need anymore help i can look into it for you.
Oct 30, 2013 | Konica Minolta bizhub Office Equipment &...
Rheem Power Vent 50 gas water heater will not come out of vacation mode! Have tried turning on and off, resetting and following directions on the side of the tank. Will not come out of Vacation Mode. Had a...
Water inside tank-type water heater can remain hot for some time.
That's one advantage of well-insulated tank-type water heaters.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Power outage can be related to failure of gas control.
Unplug stuff when power goes out. And then plug back in after power is restored.
Water heaters with electronics are not protected from surge.
Electronics can blow out during and after power outage. For example nearby lightning strike will cause current to run along household wires. With ordinary power outage, once power is restored, the surge can affect all kinds of electronic circuitry such as timers, water heaters, water softener, treadmill etc.
Sounds like you have intellivent gas control valve:
Open following link to identify gas control, and download typical manual, and download intellivent service manual with troubleshooting, error codes, etc.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 26, 2011 | RHEEM 50 Gallon FVR NATGAS Water Heater...
WE HAD A POWER OUTAGE.NOW MY KEURIG WONT TURN ON. CAN YOU TELL ME WHAT THE PROBLEM IS. THANK YOU.
Hi,first you need to check if fuse has not been blown out.Because when POWER comes back after an outage there is a surge voltage flowing through electrical lines.It is advisable that when their is a POWER outage you have to turn off your FUSE box or SAFETY box to make sure that it won'tdamage appliances when POWER comes back>Technically when POWER SOURCE or SUPPLY has been shut off for a period of time.When POWER is back, expectantly there is an abnormal flow of current/line; current will not be as stable until a period of time..AC current behaves like a wave,values changes from time to time especially when POWER SOURCE has just been TURNED ON..So better turn off FUSE BOX when experiencing POWER OUTAGE so that when power comes back SURGE VOLTAGE wont flow within the circuit>Hope this helps..
Jun 22, 2011 | Keurig Elite B40 Coffee Maker
1 have a xerox copier model XD120F Had apower outage when copier cam back on screen is showing a H4 and not powering up thanks Joe
Hello
Since the problem occured after a power outage,you should try resetting the H code.
Press CLEAR, EXPOSURE MODE, CLEAR, EXPOSURE MODE. The display should go blank. Then enter 14 with the copy count keys and press START. If the machine does not turn off and back on by itself - then turn it Off and back on. See if the H code should vanish and your copier should work well.
Apr 17, 2011 | Office Equipment & Supplies
What is H-4 code? AZAR11@Hotmail.com
H-4 code is to let you know that the fusing unit did not reach a certain temperature in a certain amount of time. Likely caused by power outages or fluctuations.
You'll need to reset the code by pressing in rapid succession: # * C * on the keypad, it may take a time or two to get it right; you'll know you're in the programing when the display goes dark. press 14 and then the copy/start button.
This will reset the code and if the lamps and thermistor work then the problem won't come back. However, if it does, it likely means you have bad power coming into the machine, or the fuser lamps need to be replaced.
Jan 04, 2010 | Sharp AL 1631 Copier
Copier power outage while in operation caused paper jam and shut operation down. Service icon activated and will not go out.
Hello sir; Try to do a reset, open clamshell and remove top front cover, close clamshell and reconnect cable from cover to DC controller. turn on power and then short pins JP101 & JP102, the display will show out "F" release the short, then put everything back turn on the power.
Oct 20, 2009 | Canon PC-940 Black and White Copier
I have an HP c7180 all in one inkjet printer and recently we had a power outage. Ever since that time the colors are all mixed up. After the power outage, I was getting this error message: ""Ink System has...
If your product is in warranty then I recommend you to contact HP support to service or replace the unit. Otherwise perform the steps given below and verify the results.
  1. Turn on the unit.
  2. Disconnect the power cord from the back of the unit.
  3. Press and hold the # and 7 buttons simultaneously.
  4. While still holding down the # and 3 buttons, connect the power cord to the back of the unit.
  5. Continue holding the buttons until the Power button blinks.
  6. Follow the instructions that display on the unit to select the language settings.
Oct 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
I am getting an error C6000 on my Kyocera KM-1820 after we had a power outage. I can't seem to get it to turn off. What do I need to do in order to get the copier to work again and for it not to have the...
Go into the service mode ( 10871087 ) then enter 163 then hit the start button. This clears the C6000 (heater error) and if it is a false code due to a power outage, it will clear the code and resume normal operation. If the code comes back, you likely have a bad heater lamp or thermal fuse or thermistor.
Aug 19, 2009 | Kyocera Copystar CS-1820 Black and White...
Power went out and back on; now printer won't print
I had the same problem after a resent power outage. Here's what fixed mine.
Turn the power switch off.
Wait a 15-20 seconds
While holding the button on the front panel down turn the power switch on.
After the drum light comes on release the button wait then press the button again.
Turn the machine off then back on again and you should be back in business.
To prevent the problem in the future if you are not using the printer turn it off and if the power goes off while printing get the printer turned off before the power comes back.
Oct 14, 2008 | Brother HL 1440 Laser Printer
Error Code SC 541
Its a fuser code. Hold down both of the arrow keys for 10 seconds, then press enter. Select 2 for engine, ok, select 7 for data log, ok, scroll to 7807 and execute. exit all of the way out until you get back to engine, then select 3 for end. Recycle power.
Apr 01, 2008 | Ricoh Aficio AP600N Laser Printer
Canon imageRUNNER 5570 Copier Logo
73 people viewed this question
old marine
old marine
