Question about Reddy Heater-30-55,000 BTU Variable
Ready heater jet setting
I need to no how many turns on the air jet on a ready heater 55000 btu
  • email me at hanskleczek@yahoo.com if u know how many turns on the air screw on readdy heater 55000
    Problem Solver:
  • 14 Answers
Remove plug on left and install low pressure air gauge. Adjust right screw to 3.4 psi on the gauge. See web site www.Desatech.com Manuals with parts breakdown are available on line.
Posted on May 29, 2008
How do I keep the reddy heater 55000 btu working inside the house
Probably has an oxygen sensor so you don't run out of air. Probably not something i would bypass in a house.
Dec 12, 2014 | Reddy Heater-30-55,000 BTU Variable
Adjustments for reddy heater 55000 btu
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 08, 2011 | Reddy Heater-30-55,000 BTU Variable
I have a 55000 btu 2007 multi fuel forced air heater, It started this winter running 15 seconds at a time I changed the fuel but now it will run but you can cut the kerosene fumes with a knife. I have the...
Is there a fuel pressure gauge on it? IF so it be set to the pressure on the nameplate rating. Mine did samething and I had to replace the rubber hoses from the pump to the injector. Your fuel pressure will tell us whats going on.
Dec 14, 2010 | Reddy Heater-30-55,000 BTU Variable
Heater starts and runs but will not go to full force
You can replace the filters ---fuel--- air--- spark plug and vanes in the pump assembly.This is called a fall check up!
Dec 22, 2009 | Reddy Heater-30-55,000 BTU Variable
I have a 55000 ready heater that will not run.
Try holding the ingiter button down and see if it runs properly. The switch may need to be replaced
Jan 30, 2009 | Reddy Heater-40,000 BTU Kerosene w/T'stat
55000 reddyheater
What is the pressure setting on the air pump? The air pump delivers the fuel. the correct pump pressure deluvers the correct ampunt of fuel. Wrong amount of fuel/air ratio produces a stink!
Oct 30, 2008 | Reddy Heater-30-55,000 BTU Variable
Air screw setting
Apr 04, 2008 | Reddy Heater-30-55,000 BTU Variable
Air fuel mixture screw adjustment, forced air kerosene heater
Most ready heaters have a fuel pressure setting on the back of the heater near the fan. There should be two small plastic covers, looking directly at the back, the one on the left can be removed and a pressure gauge installed. The one on the right is slotted for adjustment of pressure. I think the correct pressure for that model is 3.0 lbs.
Jan 06, 2008 | Reddy Heater-30,000 BTU Propane Forced-Air...
Reddy Heater-30-55,000 BTU Variable Logo
141 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
