Question about Acer Aspire 3680 Laptop
System volume on disk is corrupt
Help. won't start up. daughter says she was trying to charge ipod and hasn't worked since
  • acerlaptop Apr 04, 2008
    is there anyway to download Acer Vista Inspire 3680's drivers and recovery data to a disk and not wait for snail mail delivery?
    Scholar:
  • 50 Answers
Assuming you have Windows Vista as an OS on it..
That's a hardware problem, not a Vista problem, the file system is munged and the HDD cannot be loaded. Often times, this is only resolved by recreating the system volume and starting from scratch. Boot from the DVD and try running a chkdsk /r from the recovery environment (choose the command prompt option), see if it can fix the drive. Otherwise, you may have to go the long way 'round. Hopefully you backed up your data on a regular basis
For more detailed information from Microsoft
Follow the link below to the MS website it explains how to fix this.
You will need the Recovery CD to boot into windows.
MS Fix Link
Good luck,
djEnigma
Posted on Apr 04, 2008
    Sergeant:
    Champion:
  • 244 Answers
If you haven't delete the recovery partition, you can reload your operating system using alt+f10 during boot.
for drivers, you can download it from www.acerpanam.com
Posted on Apr 05, 2008
6ya staff
SOURCE:
Mac 0sx 10.5.8
The disk might not have a working OS on it.
It you have successfully run the disk utility the disk probably in full working order. I think that the OS on the disk is either missing, corrupt or not compatible with the computer you are running it on.
May 28, 2013 | Apple Leopard 10.5 Osx Mac Operating...
Tip
Boot problems and their possible causes & resolutions
Symptoms:
Black screen
"Invalid Partition Table"
"Error loading operating system"
"Missing operating system"
Cause:
Corrupt Master Boot Record (MBR)
Resolution:
Boot into Recovery Console and run "fixmbr" to repair the MBR
Symptoms:
"A disk read error occurred"
"NTLDR is missing"
"NTLDR is compressed"
Cause:
Corrupt boot sector
Resolution:
Boot into Recovery Console and run "fixboot" to repair the boot sector
Symptoms:
"BOOT.INI is missing or corrupt"
"Boot device inaccessible"
"Windows could not start because the following file is missing or corrupt:
<Windows root>\system32\hal.dll"
Cause:
BOOT.INI missing, corrupt or out of date as a partition has been inserted
Resolution:
Boot into Recovery Console and run "bootcfg /rebuild" to repair the BOOT.INI
Symptoms:
"Windows could not start not start because the following file is missing or corrupt:
\WINDOWS\SYSTEM32\CONFIG\SYSTEM"
Cause:
Corrupt/missing system hive
Resolution:
1. Boot into Recovery Console and run "chkdsk C: /f" to check the system disk for errors and fix them, then reboot.
2. If the error continues and System Restore is enabled, copy the system hive from the last restore point into \WINDOWS\SYSTEM32\CONFIG
3. If the error continues, copy the system hive from \WINDOWS\REPAIR into \WINDOWS\SYSTEM32\CONFIG
4. If the error continues, perform a repair installation by booting from the Windows installation media
Symptoms:
"Windows could not start because of a computer disk hardware configuration problem.
Could not read from the selected boot disk, Check boot path and disk hardware."
Cause:
Boot volume (with Windows folder) is not accessible as defined in BOOT.INI
Resolution:
Check the boot volume is accessible
Symptoms:
Dual-boot 32-bit Windows and 64-bit Windows system reports "NTOSKRNL.EXE is corrupt" trying to boot into 64-bit Windows
Cause:
System volume contains an older boot loader than the boot volume requires - e.g. XP SP2 installed after XP x64
Resolution:
Copy NTDETECT.COM and NTLDR from XP x64 installation media to the root of the system volume
on May 03, 2010 | Computers & Internet
When I turn on my ipod shuffle & hit play it blinks green and orange several times and won't play
The Apple iPod shuffle is a digital music player that contains a single indicator light that relays information about the device's battery condition, computer connection and any errors the device is having. The indicator light is capable of blinking red, green or orange as well as displaying a steady red, green or orange light. The iPod Shuffle includes a Universal Serial Bus interface and buttons on the front of the device for controlling music files.
Blinking Orange A blinking orange light indicates the iPod Shuffle is receiving an update via iTunes to the device's internal components. The update could include a patch to repair an error the player encountered once before, an update to the player's file-saving software, or a combination of security, repair and software updates. Updates are free and automatically sent directly from Apple through iTunes to your iPod shuffle before a sync process starts. Disconnecting iPod Shuffle When the player's light is blinking orange, do not unplug the device from your computer's USB port this will stop the update process and possible corrupt the device's internal hard drive. Let the update process and sync process finish before clicking "Eject" within iTunes and removing the player. Disk Use Enabled If you use your iPod Shuffle as a flash drive and not as a music player, a blinking orange light means that the device is connected to your computer and ready to accept files. The "Disk Use" enabled setting is changeable within iTunes if you decide to use your iPod Shuffle for music storage instead of file storage. When set up as a flash drive, the iPod Shuffle is assigned a drive letter by your computer's operating system and the drive lets you "drag and drop" files to the device. b> Charging If your iPod shuffle's battery is completely depleted or low on charge, connect the player to your computer immediately for charging then leave it connected to receive any updates to the device's software and internal components. Its indicator light may or may not blink orange until after it is fully charged. If the battery is low on charge or completely depleted, you may receive an error stating that the iPod is corrupt or needs restoring, close the error message and let the device fully charge.
b>
Feb 12, 2013 | Apple iPod Shuffle Second Gen.1 GB MP3...
Dell inspiron 1545 Laptop computer is getting BSOD on boot, when first ran diagnostics got error: Hard Drive - DST Test Results - Fail Error Code 2000-0142 Msg Hard Drive 0 - self test unsuccessful status...
The error indicates that there's a hard drive issue. If it just happened after the hard disk is reinstalled, remove it and reinstall it. It could be a problem caused by loose connection or improper connections. If the same problem repeats, install the hard drive on another system (to verify whether it works on another machine or not and to confirm it still works). If it doesn't work on another computer/system then your only option to run the system is replacing the hard disk. If it works on another computer or if it's detected on another system, then there could be problem with the hard disk, eg. Corrupt Partition, Windows Corrupt etc....
First of all, try booting into Safe Mode. You have to press F8 during the startup to go into Advanced Boot Options. Once you are in the Windows Advanced Boot Options, select Safe Mode using the up and down arrow keys on your keyboard. If it still doesn't work, it's the hard disk issue. Try with another Hard Disk.
But if in case you can boot into safe mode, check the Hard Disk for errors. In other words, run Windows Checkdisk utility. Hope this helps.
Let me know if you need further help.
Good Luck.
Thanks for using FixYa.
Oct 10, 2011 | Dell Inspiron 1545 Notebook
In my IBM thinkpad T41, I opened control panel,after click System icon, in hardware part, for monitor , I reinstalled its driver( computer shows it will do this automatically), then computer crushed,...
Severe Windows corruption - the driver you removed has prevented the reboot and corrupted all the other video files. Try booting in Safe Mode - in there the default driver should be selected. In there try to reinstall the driver again. If that fails the only thing left is to do a repair install (if you have a retail install disk) or a full reinstall - if you have a recovery disk.
Aug 31, 2011 | IBM ThinkPad T41 Notebook
I have a Pioneer DEH-P4150UB car stereo with usb-ipod connection. This was working this morning however when I connect the ipod now there is no volume coming from the system. The tuner works on the system...
you can try a soft reset on ipod by holding the menu and center button at the same time for 10-15 seconds and/or reset your radio by taking face off of it and pushing the reset button on the stereo too.
May 19, 2010 | Car Audio & Video
Laptop wont boot up
Chek whether your system volume is infected. viruses or trojans may be the root cause. I also think that your system software is corrupt.
Aug 09, 2009 | Computers & Internet
Ipod classic corrupt
HAVE WINDOWS XP TRYING TO DOWNLOAD DRIVER TO CHARGE AND DOWNLOAD MUSIC OFF OF BLUBSTERS
Jan 03, 2009 | Apple iPod classic MP3 Player
Hard disk temperature too low!
I had the same problem on my daughter's Lyra 5GB MP3 player. I fully charged it, tried the 10 second power button reset, and was on the way to remove the back to check the disk drive cable when my daughter dropped it and it started working again!
Good job too, since when I checked, the disk drive connector appeared to be soldered on.
Jun 20, 2008 | RCA Lyra RD2763 MP3 Player
Apple 20GB IPOD 4th generation corrupted
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. I'm here to help.
Mar 18, 2008 | Apple iPOD 20GB Toshiba Harddrive for Gen...
Acer Aspire 3680 Laptop Logo
6,239 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
