It tells me to open front cover, but I don't see anything. Is there anywhere else to check or a way to reset? Thanks
Comment by kcos70, posted on Apr 08, 2008
Thank you for the response. I will try that. Oddly enough, it started running again but I'll try cleaning those rollers for extra measures. Thanks again!
CLEANING THE FEED ROLLER AND THE PAD Clean the feed roller and the pad when [391: Paper Jam] appears frequently. (1) Remove the paper cassette. (2) Clean the feed rollers (large and small) with tightly wrung wet cloth or an LED lens cleaner. Note! An LED lens cleaner is enclosed in an optional replacement toner cartridge. Feed roller (large) Feed roller (small) (3) Clean the pad on the paper cassette with tightly wrung wet cloth or an LED lens cleaner. Note! • If [392: Paper Jam] appears frequently, clean the second tray (option) in the same way. • If [390: Check MP Tray] appears frequently, clean the feed roller of the multi-purpose tray in the same way. Pad
Was this solution helpful? Show your Appreciation by rating it:
