Question about Dryers
Kenmore Dryer Not turning on
When I push button on while timer is turned to any cycle, you can hear a clicking noise coming from the timer, but the dryer will not come on.
  • LLH351 Apr 18, 2008
    My Kenmore Dryer model #11089722990 has a clicking noise from the turn on button but will not turn on
  • 66 Answers
Timer is no good you will need to replace it you didnot write any m# for the dryer . the best
Posted on Apr 04, 2008
SOURCE:
Why doesn't it start?
other than the timer noise, do you hear anything else?
is motor turning but a broken belt possibly?
Nov 24, 2015 | Kenmore Dryers
Kenmore gas dryer....stopped working mid-cycle and will not restart. when I push the start button, i can hear a noise by the timer...?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Oct 07, 2010 | Kenmore 74602 Gas Dryer
My ler7646eq2 will not start, button makes a click noise when I push it in, and I can here the timer making noise. But the dryer doesn't come on.
The capacitor is probably bad. The relay is still working that is why you can hear a click noise. It won't come on since the motor needs to have enough voltage from the capacitor to initialize. Good luck.
Apr 18, 2010 | Dryers
Dryer wont turn on
the belt is off.
Feb 11, 2010 | Dryers
My 1987 GE Dryer, Model # DDE5300GALWH,will not run all the time.
sounds like you need a new timer you can actually take the timer apart to check for a burnt connection
Jan 07, 2010 | GE Dryers
Heat unit comes on w/o pushed start button
I would check your heating element. It may have grounded to the metal casing. Unplug dryer!!!! Check continuity by ohmning out to one end of element terminal to casing of element. You should not have any continuity.You need to check both terminal ends. (Red Wire) If it has continuity replace it . It is grounded out.It could also be your motor block but this is very uncommon. Hope this helps!!
Mar 31, 2009 | Whirlpool LER4634J Electric Dryer
Whirlpool Dryer GEQ9800LW0 won't turn on
Hi!!! it seems that you have a bad thermal fuze located near the blower..change the thermal fuze and you should be okay..Good luck..
Jan 04, 2009 | Whirlpool GEW9200L Electric Dryer
Dryer not turning on
most likely its the timer it has electrical contacts built on the timer that allow it to start its cycle if the timer has bad contacts it wont allow dryer to come on
Jan 21, 2008 | Dryers
My Dryer Heats but won't tumble
do you hear a humming noise? and is air coming out the rear if so the belt has broke if not the motor has gone bad let me know what you find
Jan 08, 2008 | Whirlpool GEQ9800P Electric Dryer
Dryers Logo
134 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
