When I attempt to print on an envelope with my Epson Stylus Photo R800 printer attached to a Windows XP computer using Microsoft Word 2003 I get an error message "Paper out or incorrect output tray position" neither is true. I get the same error message when I try to print to lables using Outlook 2003 mail merge.When I attempt to print on an envelope with my Epson Stylus Photo R800 printer attached to a Windows XP computer using Microsoft Word 2003 I get an error message "Paper out or incorrect output tray position" neither is true. I get the same error message when I try to print to lables using Outlook 2003 mail merge.
what operating system are you using and how do you connect printer to computer?what operating system are you using and how do you connect printer to computer?
You can't post conmments that contain an email address.
Device error
An internal error occurred in the device.
Press (Select) to resume the job.
Door open
The printer door is open.
The door must be closed before printing can continue.
Engine comm. error
The device experienced an internal communication error.
This is a warning message only. Job output might be affected.
Invalid driver
You are using the incorrect printer driver.
Reselect the printer driver appropriate for your device.
Invalid entry
Invalid data or response.
Correct the entry.
Jam in Cartridge area
A paper jam has occurred in the print path.
Open the door and clear the jam. Then press the (Select) button on the control panel
Jam in Output bin
A paper jam has occurred in the output area.
Clear the jam, and then press the (Select) button on the control panel.
Jam in print paper path.
Open the door and clear the jam. Then press the (Select) button on the control panel.
Jam in tray 2
A paper jam has occurred in Tray 2.
Jam in tray 3
A paper jam has occurred in Tray 3.
Load paper
The HP Color LaserJet 1600 printer is out of paper.
Please load specified paper type into the tray indicated.
Load Tray X [TYPE] [SIZE]
The printer is processing job, but the tray indicated is empty.
Please load specified paper type and size into the tray indicated.
Manual feed
The printer is waiting for paper in the tray indicated
Load the paper as indicated.
Memory is low
The device memory has been almost completely filled.
Allow the device to finish the job, or press (Select) to cancel the job. Break the job into smaller jobs that contain fewer pages.
Misprint
The printed pages have been incorrectly placed on the paper.
To continue, press the (Select) button on the control panel.
1. poor quality printer may reduce printer quality & causes paper jams and other printer problems. If you encounter problem , switch to a higher grade of printer.
Check if the correct paper type and size is set in the printer settings. Also check if the paper guides are set to the correct size in the paper tray. Sometimes, the paper sensors will not detect the correct paper if the guides are set to the incorrect size.
hi Anthony, i spent a month trying to figure out a similar problem with an epson 2200. Now, the printers are different but not that much, and, the changes in paper and ink gave me "some" color issues but not as bad as what i was getting. your problem seems very similar. i run a PC so this is similar but not exactly the same. what i found was that a Magenta/ violet cast was due to double profiling. I could verify that i had the correct settings but i was wrong! I print from CS3 into the epson 2200. What i found was there is an error(no one is talking about) in the printer driver. You cannot shut off the color management completely! Assume this scenario, you are printing with CS3 applying your profile in CS3. Make the settings in CS3 as normal, then you are directed to the printer settings. Go to the print driver and make the selections for ICM Color, and select "no color". The KEY is to make sure you do this step LAST , make sure to click on the "apply" button, then "Close". Once you make the selection of "No Color" do NOT click on anything else. If you change screens in the print driver once you select "no color mgmt" the driver CHANGES your settings. ANY settings in the other pages in the print driver cause the driver to apply a printer profile, this effectively "double profiles" your photo print causing the magenta cast. None of this should happen if the driver was created correctly but there it is! It took a long time to test and verify but it is as i stated. Once i got it sorted out my photos are excellent ALL the time. Good luck, worm1855.
His could be because epson print jets plug up. and usualy cost more to repair than to purchase new printer. i had epson and now buy HP because hp when you replace the ink cartridge the spray jets are incorporated into the cartridge the only thing you have to be carefull of is that somel manufactures now put a chip on the cartridges to expire the units so they can sell you another even if you dont use the ink HP included so look for exp. date on new units. look into food warehouses like sams. costco, Bjs etc. they usualy have good prices on printers. sunday paper is also a good place to look.
hi ray, it's chris. i called your cell phone, but figured you might see this. replace the registration clutch. after some research, this seems to be the solution given that should solve the issue in that printer, and it's an independant part from the paper pickup assembly...
Possible hardware failure, unfortunately.
Turn it off. Then unplug it from your computer and unplug it from the wall too.
Plug it directly into a working power source. Then turn it on.
Please make sure that the paper that you are using is included under the printer's paper compatibility list. Make sure that you are selecting the correct paper type on printer settings. Trash and re-install the drivers.
I had the same cr@p of the problem yesterday. The problem was not in
the paper. You have to do 2 simple things, from which one will solve
the problem.
first, download the latest drivers and install them.
And the more important thing, the problem occurred due to incorrect
paper format. Solution is very simple. Open MS word or something
similar, file->print.. and before you print open Properties menu.
There for the Output Size will be selected "Match Page Size". you don't
want that (i don't know why it doesn't work), but the solution is
manually select A4, or whatever your page size is.
only receiving 'communication errors'. Never had this problem before, and have rebooted multiple times. Have also reinstalled printer software.
