Question about Brother MFC-465CN InkJet Printer
Unable to Init AF - New printer!
Hi
I just bought this printer new - at the startup, the scanning bar would move appr. 5 inches to the right, then back to the left and, get stuck there and makes a loud noise, like it is blocked in this position.
Then the message "Unable to Init AF" shows up in the display. Th eproblem is, that I took the device with me to the Bahamas, so I can´t just carry it back easily for warranty or exchange.
Something you could suggest?
  • ritardando Apr 04, 2008
    Hi!
    First I want to thank you for taking the time to look into it and provide me with your well documented answer :-)
    The greetings to The Bahamas have already been delivered ( I am on Eleuthera), unfortunately the problem did not get solved yet...
    I tried your advice, but the cable seems to be well in place and connected. To be absolutely sure, I even unplugged it and put it back into place carefully.
    Unfortunately the problem is still persisiting...hmmm.
    Maybe there is any other approach to this?
    Thanks a lot in advance!
    Johnny
  • 832 Answers
Sure (this advice costs you some greetings from me to the beloved bahamas ;-))
you have to open the scanner as you have done to connect the usb cable. When opened you can see a "z" like small cover going from panel to the right rear side.
Open this cover which hides the flat cable of the scanner. The cable needs reconnecting to the main board. Simply stick it carefully into the right positon.
(will post a picture later)
Posted on Apr 04, 2008
  • 3 more comments
  • Mix-it-up
    Mix-it-up Apr 04, 2008
    so here it is
  • tad sands Oct 27, 2010
    there is a brother service center in the bahamas. on abaco, phone # 242 367 2004
  • Karlan Oct 13, 2012
    That advice doesn't work...
    This solution doesn't work...any other ideas?
  • Michal Knoller Jan 20, 2014
    Didn't work for me
Brother MFC scanner bar is stuck
check the continuty in scanner cable to cis unit and check the continuity 2ends off scanner cable.
1.cable problem
2cis problem
Mar 31, 2014 | Brother MFC Office Equipment & Supplies
Mfc j691dw unable to init AF what does it mean
I cant get rid of 'unable to init.42' from my new mfc j6910dw. Anybody know what does it mean & how to remove the mssge?
Oct 14, 2012 | Brother Mfc-j6910dw Inkjet Multifunction...
Init unable AF, DCP185c
brother dcp 195c init unable af problem solve solution
Apr 04, 2010 | Brother DCP 165C Compact Color Inkjet...
Brother DPC-165C has 'Init Unable AF' error
Yup. I suspect the head has been removed from the unit. There are adjustments on some printers. It was assembled wrong. The grating noise is likely the auto cleaner. If it cannot go 'home' the unit will not initialize. Possibly the head detect sensor is broken or covered. If the head will not home (moves out and back more than once or slams home hard), 'Init Unable AF'. You may be able to order a service manual from Brother for this. A repair shop can order the manual as well. (I suspect you need a new print head as well. You might want to replace the printer) see tips on bubblejet printers.
Mar 20, 2010 | Office Equipment & Supplies
Scanner bar will not reset, error "unable to Init. AF"
the problem might be the connection from the mother board of the printer to the scanner maybe due to lost contact and the ribbon was broken you might just have to reconnect it or it might be broken and need replacement
May 10, 2009 | Office Equipment & Supplies
Init unable AF
AF means that the CIS scanner is (can) not (get)in right position. This could be because of a broken scanner flat cable, or a loose flatcable or a defective pcb. Check flatcable connection at the pcb (Open scanner like changing carts, open flatcable cover with a screwdriver. Does the flatcable stick in the pcb? (There is only the flatcable without a connector ;-)) Reconnect and power up mfc again. If it doesn't help please write again here.
Sep 13, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-465CN InkJet Printer Logo
7,088 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
