Question about Westinghouse LTV32W6HD 32 in. LCD Television
Problems with LTV32W6HD 32
I get green noise like patches on the screed. Once in a while I lose vertical and horizontal sync, and some time I get blank screen with vertical lines. Usually I can tap the TV an it will correct itself. When tapping doesn’t work, I unplug and re-plug the power cord.
I appreciate anyone’s help
5 Suggested Answers
SOURCE:
  • 197 Answers
SOURCE: Sony PFM 42V1 Vertical black line
you have a bad lcd panel call sony they may help
Posted on Jul 02, 2009
SOURCE: Westinghouse 32" LCD - Vertical Line across top of picture
i had this same problem, it ended up being a loose connection on mine, attached picture is where the connection was loose, i took off the back panel and just reattached it, and it was good as new.e87b8ee.jpg
Posted on Jul 28, 2009
SOURCE: westinghouse 32 inch screen goes blank
Westinghouse LTV-32w1
replace capacitor c162 on power supply
power supply was a delta electric dps210ep-2c rev01
reheat any solder joints that don't look 100% as well .
such as c310 .
this is a known working fix . try before you buy a supply .
Posted on Apr 15, 2010
  • 286 Answers
SOURCE: westinghouse ltv32w6hd power supply
One of two symptoms on this model (LTV-32W6HD) Blue light comes on but cannot shut off. No picture; OR No picture but sound is OK. 1: In both cases replace ALL the electrolytic capacitors onthe output side of the power supply. This should get the power switch to worknormally. 2: Replace the small tiny wee little tiny small 2.0A fuse onthe inverter board labeled F1. This is the small black fuse, not the slightly bigger whiteones labeled F2 and F3.Ta Da...all fixed.
Posted on Dec 20, 2010
Why does my Westinghouse 32" flatscreenTV shows fuzzy psychedelic colors
Have you tried resetting the TV's settings to the factory default?
You should be able to do that within the settings menu on the TV.
May 01, 2014 | Westinghouse LTV32W6HD 32 in. LCD...
Mitsubishi VS-55609 top left screen has folded over
chk for any electricity or magnetic interferanc. change the location to the TV. switch of the tv fro 5 min and restart it again back.
Jul 03, 2008 | Mitsubishi VS-55609 55" Rear Projection...
Lg crt monior display cable wire circuit diagram
Pin Signal 1 Red Video 2 Green Video 3 Blue Video 4 Monitor ID - Bit 2 5 Ground 6 Red Ground 7 Green Ground 8 Blue Ground 9 [KEY] 10 Sync Ground 11 Monitor ID - Bit 1 12 Monitor ID - Bit 0 13 Horizontal Sync 14 Vertical Sync 15 N/C (Reserved)
Feb 11, 2010 | Computers & Internet
6 horizontal lines
I would look for a Vertical circuit failure. Most likely is the vertical output IC and or open resistor off the hv transformer. Definitely look for any loose solder connections around the Vertical output IC.
Hope this helps,
Skyassoc
Jun 16, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Vertical hold problem
There is a fault in either the input video amp, sync amp, sync separator, or the vertical scan generator areas. Most of the time this type of failure is caused by capacitors in these areas going off spec from age and use.
An experienced TV tech who is familiar with your set should be able to service this for you.
Jerry G.
Jul 16, 2008 | Toshiba 32A43 32" TV
TV suddenly turned off and won't turn on for more than nSec.
Hello kd6aaj, You are on the right track, a vertical line usually means that you lost horizontal deflection which is supplied by the horizontal/High voltage section.The thing that puzzles me is that you did not lose high voltage. Let me explain. In modern TVs the horizontal section uses scan rectification or a process similar to a switching power supply to convert a lower voltage tapped off of the hoizontal/HV section to provide B+ for the rest of the television. So if you lose your Horizontal voltage you lose your B+ also. So you will never see the vertical line because you low voltage power supply if off also. Now I think your Q571 (H-Out), Q572 (H-Drive), Q551 and/or Q552 (H-Control) might be good. However check them anyway. I would also advise you to check your yoke transformer for an open or shorted winding. This would cause you to lose deflection without losing high voltage. You are definatly in the right section just add the deflection section to your scope of troubleshooting.
Sep 10, 2007 | Sylvania SRT2232S 32" TV
PROBLEMS WITH VERTICAL ROLL
That is not a vertical roll from side to side, this is a horizontal rolling. if the vertical had a roll it would be going from top to bottom. This is most likely a coupling between the horizontal sync circuit and the sync separator circuit. Good Luck
Jun 28, 2007 | Sony KP-53S65 53" Rear Projection...
32 inch sony trintron tv red blue green
Switch OFF TV. Open rear Cover. Switch ON the TV. Now, very carefully, (There are very High and Dangerous voltages inside, also, use a mirror to see the screen) adjust a red colored box called "H.STAT" which controls the Horizontal Convergence of the CPT. Should solve your problem. Check some Vertical portion of a object (Text in some Video Title, wall of a building, etc, ) as a reference.
Sep 04, 2006 | Sony FD Trinitron KV-28FQ75 28" TV
Westinghouse LTV32W6HD 32 in. LCD Television Logo
47 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
