Televison & Video Logo
Posted on May 21, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Blinking standby light need new capacitors? philips 50pf5532d, where do we buy capacitors? is this an expensive job?
Chi Chu
Level 3:
  • Televison & ... Master 8,457 Answers
  • Posted on May 21, 2010
Chi Chu
Level 3:
Answers
8457
Questions
0
Helped
2822913
Points
26282
No,around $50-75 by buy a soldering iron,solders and all those new capacitors replacement.U must know basic electronic,and soldering to do the capacitors replacement.You could buy capacitors many plaaces like ur local Radio Shack,Amazon.com or Ebay.com.
1helpful
The unit won't power up: when plugged in to power the red standby light comes on after about 20 minutes!
They are common with flat screen. It's the capacitor that needs changing. What happens is the power goes to the capacitor and when the capacitors are worn out, they bulge and won't send power to the tv starter. You can open your tv up and play with it. You will see bulging capacitors and they will look like burnt. You can get a soldering iron and melt the lead, change the capacitor by bringing it to Radio Shack and buy the exact one(just show them the ones you took out). Solder the new ones, just remember not to have the pins touch each other. Plug it and see it it works. Otherwise, just buy a new tv since having it serviced with no warranty is more expensive than getting a new one.
50 inch philips plasma has problems turning on. I replaced all the bad capacitors and now the green lights come on and then goes into blinking red four times. I checked all the capacitors and all of t
More specific, please ! Finally, did you replaced all bad capacitors or only replaced the power supply unit ? Because there are many other capacitors on other places that can be damaged.
Sure, the problem seems to be from one of the capacitors, but you have to know how to find the damaged one (and with the proper instrument will be more easy). Howewer, to buy a good instrument is more expensive than to service your TV set (my opinion). Plus guaranty.
Red LED blinking after turn on the TV
These blinking codes are fault indications. By counting these, you can understand the location of the faulty section inside it. But, counting these blinks too is somewhat difficult to a user who is not aware in electronics. Check this link, and see how to count the standby light blinking codes to Philips brand TVs. Details are described there in detail.
Red blinking standby on my sony tv
That problem is cause of faulty power supply board..
look at the capacitors if bulged then try to replace it..
Watch this video to learn more about capacitors:
If you have soldering skills its better to buy a new power supply board online...
My dvd blink red light on batton standby/on.I can't turn on!?Any idea,please!
In most cases you need to reservice the power board, or change the damaged capacitor. This capacitor is loacated on poer supply board. Also resolder the components heated area. Hope this works.
2answers
Philips 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help thanks
philips2_bing.gif 42 plasma flashing blinking 4 red lights 42PF7321D/37 screen does not come on need help
2helpful
Philips T.V. turning off, when blinking red light won't turn on
at power supply, filter capacitor, indication bulk,should be replaced..note:little knowledge is dangerous, so if you wish to do it yourself an sop here. 1unplug the unit,2discharge the current in the large capacitor, now you can do the replacement...polarities also, should be observed....
1helpful
2answers
Blinking red led light when I plug in the tv then it turns right
Phillips purchases the main circuit board from Samsung, and it has a problem with capacitors failing. The failed capacitors can be easily identified as the top will no longer be flat, but will have bulged up.
If you have a local TV repair shop they can help you.
DVD stuck inside, player won't turn on, standby light does NOT flash
test the capacitor with a meter to make sure it has the value stated on it.
the work on this unit is quickly exceeding its present value, most likely.
consider upgrading to a higher resolution unit if the fix is more expensive in parts and time than a new unit costs.
good luck
mark
2answers
Standby timer light blinking, tv will not turn on
Check out Ceramic Capacitor C514 by the horiz. output transistor (burned/shorted?) My question is how do you find the specs of the capacitor and where do you buy one?
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
