Question about Canon imageCLASS D760 All-In-One Laser Printer
Error e003
  • 56 Answers
E003
During printing, the main thermistor detects less than 120 deg C/248 deg F
for 1 sec or more continuously.
Main cause The fixing film unit is faulty (main thermistor fault, thermal fuse blow,
fixing
heater fault).
or The power supply PCB is faulty.
or The DC controller PCB is faulty.
99 percent is the fuser unit is the problem.
Good luck
Posted on Oct 24, 2009
6ya staff
SOURCE:
E003 Error code in canon ir2420 photocopier
Code E003-0000 Description Abnormally low temperature (detected by main thermistor)
After the temperature detected by the main thermistor has reached the specified value, it does not reach the specified value during initial rotation. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Error Codes Canon iR2420 Code E003 0000
Oct 28, 2015 | Canon Office Equipment & Supplies
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
Right click on the error message select properties you will see all details about the error
or click start type in event viewer press ENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Title : E003-0000 is displayed upon recovery from sleep mode
Error :
Workaround :
When a machine is in sleep mode and is recovered an error code "E003-0000" was displayed.
It is caused during the fixing temperature control at recovery from sleep mode, electrical noise affected the thermistor.
In order to increase the length of time for idle rotation of the drum (by 30 sec) at start-up and prevent electrical noise from affecting the thermistor, make the following selection:
Service mode (Level 2)> COPIER> OPTION> BODY> DRM-IDL = change the setting to '3'
Note: The length of time for idle rotation is being increased by 30 sec.
This mode will delay start of the machine by 30 sec.
or
Product : imageRUNNER 7086 imageRUNNER 7095 imageRUNNER 7105
Title : E003
Error :
E003-0000 Error Code can be displayed when the reading of the main thermistor is below 70 deg. C for 2 sec. after it has exceeded 100 deg. C.
Workaround :
1. Although the fixing heater or the temperature-detecting thermistor may be faulty, before replacing these parts, check J508 on the DC controller PCB for poor contact and refit it if necessary.
2. Make the following selections to clear the error code: [Service mode > COPIER > Function > CLEAR > ERR > OK]
Jul 18, 2013 | Canon imageRUNNER 5000 Copier
File error - in NW-E003 SONY MP3 WALKMAN
I get no data file error when i try to play the song in my NW-E003 SONY MP3 WALKMAN player
Jan 19, 2010 | Sony NW-E003F MP3 Player
I have a problem with copier GP 225 it gives E003 how do I clear this code?
fuser temp not rising at correct pace. could be thermistor,thermal switch or fuser lamp
Oct 07, 2009 | Canon Office Equipment & Supplies
Cannon image runner 2200 error code E000002-0000, how do I fix it?
E002/E000/E003/E261/E733 Error code: Due to AC line noise Error Code
Symptom E002/E000/E003/E261/E733: due to AC line noise. Description E002/E000/E003/E261/E733 occur due to AC line noise.
If the above error codes are frequently recorded in the error log, they might concern AC line noise. Cause When the machine tries to detect a Zero-cross signal of AC line, it will fail if a noise occurred around the zero-cross point. Since the fixing temperature is controlled based on the zero-cross signal, there is a possibility that the fixing temperature could not rise properly if a noise occurs several times. Field Remedy Replace the Switching Regulator PCB ***'y with a new one.
120V: FH3-2613
220V/240V: FH3-2614
The circuit has been modified to resist a noise. REMEDY Caution
 Press (* then 2 and 8 together then *)you are in service mode monitor:
To clear the error, execute the following in service mode: COPIER>FUNCTION>CLEAR>ERR.
GOOD LUCK MATE ......KINDLY RATE ME !!!! THANKS.
Sep 25, 2009 | Canon imageRUNNER 2200
System Error E000 and E003
E002 Error code details Heater temperature error (fails to reachspecific level; inadequate increase)
0000 The temperature of the fixing film is as follows:
1. has exceeded 100°C, but does not reach 115°C within 1 sec thereafter.
2. has exceeded 140°C, but does not reach 150°C within 1 sec thereafter.
3. has exceeded 160°C, but does not reach 165°C within 1 sec thereafter.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor TH1 has poor contact, or the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
 To clear the error, execute the following in service mode: COPIER>FUNCTION>FCLEAR>ERR.
Action
 See the description for E003. E003 Error code details Heater temperature error (abnormal drop; low-temperature detection)
0000 The main thermistor reading is lower than 140°C when paper is moved.
Main cause
 The fixing film unit is faulty (i.e., the main thermistor (TH1) has poor contact or has an open circuit; or, the fixing heater is faulty). The main power supply PCB is faulty. The DC controller PCB is faulty.
Caution
Action
1. State
 Turn on the power switch, and clear E002/E003. Thereafter, turn off and then on the power switch. Does the fixing heater operate?
 NO: See "The fixing heater fails to operate."
2. Wiring
 Is the wiring from the DC controller PCB to the fixing film unit normal?
 NO: Correct the wiring.
3. Fixing film unit, DC controller PCB
 Try replacing the fixing film unit. Is the problem corrected?
 YES: End.
 NO: Replace the DC controller PCB.
Jul 28, 2009 | Canon imageRUNNER 2000 Copier
Canon NP-6612 copier Signal E003
E003 is fixing low temp error
please check thermistor and heater
Dec 04, 2008 | Sharp AL 1631 Copier
Canon imageCLASS D760 All-In-One Laser Printer Logo
249 people viewed this question
Clive
Clive
old marine
old marine
Ekse
