Question about Hitachi 53SDX01B 53" Rear Projection Television
Hitachi 53SDX01B Rear Projection Television - No Picture
Everything seems to work, although there is no picture. I am assuming that the bulbs need replacement (?). The TV was purchased in 2000 - 2001.
Upon inspection, I cannot figure out where the bulbs/lamps are within the three lens assemblies.
Any guidance is greatly appreciated!
Tamara & son, Dan
  • 1 more comment
  • artsharp1 Apr 04, 2008
    Thanks sprintsfan.
    After further checking, I see that this TV does not have a bulb.
    This is a CRT-based RPTV. It doesn't have a lamp. It has 3 CRTs in the base,
    Does anyone have any ideas as to why the picture, all of a sudden, just quit showing up?
    Thanks in advance,
    Tamara
  • Anonymous Apr 07, 2008
    tv was working turned off for nite in morning turned on did not get picture or sound did here a clicking when tv is being turned on checked the main power source board for any blown fuses did not find any now iam stuck
  • mwshitachi Nov 30, 2008
    Picture began going fully dark while watching it, then would return to normal picture on its own. Now when I turn the TV on the sound works but there is no picture.
I have a 50" r.p. Hitachi, kinda had the same problem, it would go off at different times and i't hit on the back and get it to come back on,but after awlhile i'd have to hit it more and harder to get it back on till it quit, the menu would come on and would show the video 1 ,3 and that in the corner.After paying $75 for a guy to say it wasn't worth fixing i tried myself. Not knowing what i was doing, i checked all wire plug connections. Found 2 that wasn't seated good replugged them and still didn't work then tried the bulbs, just kinda jiggled all 3 one didn't feel the same so just tapped on it alittle and it popped, i guess back into place, anyway turned on the tv and it worked. Had moved it recentlly so i don't know if that is what moved the bulb. Hope this helps, also mine is a '94 model.
Posted on Apr 04, 2008
SOURCE:
Picture quality is really dark, have cleaned everything, still doesn't work
Presuming you cleaned the lens and the mirror you may have a problem in (yes) the power supply---some of these develop an issue where the filament voltage for the 3 picture tubes goes down as a resistor in the supply from age goes UP in resistance---going to need a meter and a service manual to find that.
If that is beyond you then consider getting a tech or a shop to look at the set.
Let me know if you have questions.
Dec 04, 2012 | Hitachi 53SDX01B 53" Rear Projection...
Crt coolant kit
Replacing the coolant is not going to help a dark picture and is not for a do it yourself repair---it is toxic and dangerous to replace unless qualified.
I need to replace the dust cover on my Hitachi 53SDX01B
the problem here is Hitachi usually if it still has it sells all three screens as a unit---expensive.
You may want to search with GOOGLE the internet as some companies sell replacement "protective" screen replacements.
I have even seen one time someone found a piece of plexi-glass and had it cut to the exact size and thickness for a replacement.
Mar 21, 2012 | Hitachi 53SDX01B 53" Rear Projection...
I have an Hitachi 53sdx01B rear projection HD TV. Worked great until yesterday when it seemed like the contrast or brightness got out of whack. Whites appear to be overly bright, to the point that...
The tv have picture look like a bright dull hallow glow to the screen,yes,than the tv CRT tubes coolant chemicals is bad.Tries websites like Tvrepairworld.com,Tvrepairkits.com to buy a coolant kit to do the replacement.
Feb 05, 2011 | Hitachi 53SDX01B 53" Rear Projection...
My tv has no picture or sound, but the power is on...
Replace your STK ICs -STK392-110s use 120s
Mats has ICs 1-800-628-1118
Sep 29, 2010 | Hitachi 53SDX01B 53" Rear Projection...
Picture is blurry/distorted. I see here on the website the possible solution of replacing the 60V715 TV Lamps. Any advice?
Confirm the actual model number of the set you have.
53SDX10B IS A REAR PROJECTION WITH TUBES AND THE OTHER MODEL IS A DLP WITH NO TUBES.
SD TECH
Dec 23, 2009 | Hitachi 53SDX01B 53" Rear Projection...
BIG SCREEN TV
2.5 ohm resister at 2 watts at R43 is bad on the 53sdx01b same boards as my tv , when mine went it was at 12 ohm instead of 2.5
Jul 02, 2008 | Hitachi 53SDX01B 53" Rear Projection...
Sound, but no picture on some imputs
theres a digital switch IC on or near the AV panel that needs to be replaced if I`m understanding your question correctly you go into menu and switch to Ant. B & there is sound but no picture correct? If this is correct the IC will have to be replaced or it`s supply voltage is missing.
Nov 27, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Dark picture
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Sep 21, 2006 | Hitachi 53SDX01B 53" Rear Projection...
Hitachi 53SDX01B 53" Rear Projection Television Logo
534 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
