Question about Goodman GMS80904BNA Open Flame Mid-Size Heater
Timing off? My ignitor lights (glows), but as soon as the gas kicks on the ignitor goes out and it doesn't light the gas. It's like the timing is off. What's that all about?
  • Anonymous Oct 09, 2008
    I put a new gas valve on and there doesn't seem to be any obstruction but i still get no gas delivery. The blower runs and the ignitor lights but it never turns on. Also my furnace was under water, my basement flooded but all parts have been replaced. Is there something inside that could have gotten damaged
    Scholar:
    New Friend:
  • 70 Answers
It sounds like you are not getting gas out the of the pilot assembly.If you take the 1/4 gas line off of the gas valve and try to blow through it. If you can't then the orifice is plugged. If you can blow throw it then i would say that the gas valve is bad.do you have propane or natural gas. If propane then i would say pilot orifice is plugged.
Posted on Apr 26, 2008
SOURCE:
My Ruud achhiever 90 starts to fire but as soon as the blower fires the burner goew out. I also noticed that the "igniter" on the end isnt firing. Could that cause the burner to not stay lit when the
There is an ignitor and a flame sensor. If the ignitor does not ignite the gas after a time, it goes out. If the flame sensor does not detect ignition the gas valve closes. When you start it you should see the ignitor come on like a light bulb and glow, then the gas valve opens and you get ignition. Then the flame detector turns on when the ignitor goes out. Flame detectors are like a chrome wire that has one connection to it and it sits part of the way in a burner. They get dirty and corroded. When that happens it shuts down. You can clean the flame detector with steel wool of scotch brite pads. Dont get too carried away doing that though.
Dec 25, 2012 | Heating & Cooling
Oven will not heat up
when you ask a question you should send the brand name and model number off of the machine you need help with.if it's gas check the ignitor,if you can see the orange glow from the ignitor as soon as you see it start to glow if the flame doesn't ignite within 40 seconds the ignitor is bad.if you can't see it remove the racks and the bottom floor of the stove so you can see it,if it doesn't glow check the ignitor for continuity to see if it's bad.if the broil works and the bake doesn't 90 percent of the time it will be the ignitor.if it's electric send more info.
Jan 05, 2012 | Kitchen Ranges
Whirlpool gas oven will not heat
most likely you have a bad ignitor,pull out the racks and remove the floor to the stove,turn on the bake,if the ignitor glows but it takes more than 40 seconds for the flame to light you have a bad ignitor even though it glows and if it doesn't glow at all the ignitor is bad,also if the broil lights on top and the bake doesn't change out the ignitor.next time send the model number and i can look up your machine to help you better.
Nov 15, 2011 | Whirlpool Ovens
I have a magic chef ovan/mic unit, when I press the bake option and set the temp the igniter goes on but the gas does not kick in. model # 54FN-5TKVWM
even though the ignitor glows it doesn't mean it's good it opens the gas valve by amps not just because it glows,if you turn on the stove and when you see it glow if the flame doesn't ignite within 40 to 50 seconds you have a bad ignitor.if you leave it alone for a few minutes does the flame ignite?the only other thing it could be is a bad gas valve but most likely it will be the ignitor
Sep 25, 2011 | Magic Chef Ovens
Oven doesn't light. The element glows, but the
Hello Randolph,
Since the ignitor glows it eliminates all other possibilites and the ignitor is weak and not drawing enough amprage(3.3 to 3.6) to open the gas valve, i know you going to have a hard time believing that since it does come on, but i base my diagnosis on my 30 years experience as a appliance repair technician
Gene
Jul 25, 2011 | Kenmore Ovens
Hoping someone can point me in the right direction. Oven won't light, but the stove top burners are fine. Don't smell any gas or any indication the oven is attempting to light....
next time send the brand name and model number so i can look up your machine,if it's a gas stove most likely it will be a bad ignitor,even if the ignitor glows it still could be bad,if the flame doesn't ignite and the ignitor is glowing change it out,if it isn't glowing pull out the ignitor and check it with a meter,common problem.
May 07, 2011 | Ovens
Gas dryer burner intermittently lights. Foul gas
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 17, 2010 | Estate TGDS680EQ Dryer
Oven not lighting on Amana model agds902ss
Helloemauldin Welcome to Fixya
My name is Huum,
When you turn the thermostat on your range on it sends 120 volts to the bake valve and ignitor. The bake valve and ignitor are wired in series and the ignitor draws all the current and heats up. As the ignitor heats its resistance changes and when it is cherry red the current switches to the gas valve and it opens. The amp draw on the ignitor needs to be 3.2-3.6 amps for the gas valve to open. The gas valve has gas to it at all times. The gas valve should open within 40 seconds after the ignitor starts to glow.
If the ignitor is glowing red and the gas valve doesn’t open the ignitor is usually the problem. Sometimes the ignitor will glow red but the resistance doesn’t change and the gas valve doesn’t draw the current.
This is not a do it your selfer!
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Dec 24, 2008 | Amana AGDS902SS Gas Kitchen Range
Heating & Cooling Logo
172 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Paul
Paul
Tom Palicke
Level 1 Expert
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
