I have a vx1120. The bobbin thread does not catch and when it does it garbles thread all over the bobbin.Just had it in for cleaning and tune up. Does not sew smooth. bobbin makes noise as it sews.
NOTE TO THE QUESTION. Bobbins do not catch thread. A hook underneath when you use the wheel to advance the machine will come and catch the under thread OR BOBBIN THREAD and pull it up.
Something common and I do it, wrong bobbin in the bottom thread. I have 2 sewing machines so put thread on both plastic and metal bobbins and then just grab the wrong machine bobbin.
If this is not the issue, take the machine apart and clean it well. Note the spots that you are to oil SPARINGLY.
Make sure you are threaded correctly. Also be sure that your bobbin is sitting in the casing correctly. If the timing is right and the hook is catching, the thread may not be pulling through correctly. Clean your machine as well. Make sure your tension spring is clean and doesn't need to be tuned up.
Carmen, seem that you have carried out the necessary rectification, but could it be your rotary hook tip blunt/broken, if not most probably it needs needle/hook timing adjustment. And this will require your sewing machine technician to do it.
try changing the needle rethread the machine top & bobbin make sure to use every thread guide make sure the bobbin is not over wound make sure the bobbin is turned the right way in the bobbin case make sure the bobbin is not warped or damaged if you've done all these things then it's also possible that the machine is out of time & needs to be checked at a repair shop
Your machine probably needs to be adjusted and timed. But make sure you clean under the bobbin area before you try again... or take it to a machine pro
