Question about Tricity Bendix AW1000W Front Load Washer
Tricity bendix AW1000W power wire
Hi
I have just purchased the above washer from an auction and the seller has removed the power wiring from the back, I have the wire but dont know which wires go to which screws as there isnt any diagrams etc. Any ideas on which ones are positive, negative & earth??? I still have the manual but cant find anything in here with regard to it.
Any help would be greatly appreciated.
I need to replace the drum belt , but cant get it on .Please help
Posted on Apr 09, 2008
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
Will a Tricity Bendix AW1000W Washing Machine run on a clock timer?
hi your machine will remember prog if there a power cut and restart from where it was interupted. So if you load the machine and start it then turn the power off on the timer it will continue when the timer switches back on (yes is the answer)
Nov 20, 2010 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix aw 1001 w is not draining,pump and
If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
Apr 20, 2010 | Tricity Bendix AW1000W Front Load Washer
My Tricity Bendix AW1400W washing machine will wash but not drain. I was told I have a faulty pump which I immediately changed but the problem still persists. Can you help?
If you have replaced the pump check that the pump is actually working the easy way to tell is to remove the filter and shine a torch up inside put machine on spin or drain and see if the impellor on the pump is rotating if not then the problem could be in the wiring or the main programmer is faulty.
Apr 14, 2010 | Tricity Bendix AW1000W Front Load Washer
Won't wash empty or spin just fills and doesn't do anything. Does any body know whats wrong. I'm desperate The model is Trcity Bendix Aw1000w Anybody help Thanks so much.
first of all take door switch out, and tape the wires together, then if the washer works fine it is the switch. if it is not the switch tip it over and investagate the motor to see if it is ok.
Jan 12, 2010 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix aw1001w door lock wiring...
If you have multimeter and can use / 1 wire = live feed 1 wire is switch, 3rd is a netural idea is door lock gets 240 volt live netural feed energises the lock which in turn switches feed over to other connection..look at interlock to get idea what wire goes where....
Oct 31, 2009 | Tricity Bendix AW1000W Front Load Washer
How do remove the cover to expose the belt on tricity bendix aw1100s it seems sealed no back pannel
Your remove the front or side panels. Look for any screws to remove first then there will be spring clips that you pry on the side or front where you see it's put together. The spring clamps will release. You need to post a model number to get more specific info.
Oct 18, 2009 | Tricity Bendix AW1000W Front Load Washer
Bendix 800 autowasher
put it on its back on yhe top side of the motor you will see the brushes two screws hold each one on.
Jan 03, 2008 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix 1000 washer
you need to replace the element. remove the rear panel and you can access it
Oct 22, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
116 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
