Back to:
Tags:
KVM Switches
Generic problem for all KVM Switches
I have no idea what this is called and Im not... (by 2 users)
posted by panelopy on Apr 04, 2008
I think this is a reciever but Im not sure. Its a black box and has the model number of RX244 on the front of it. Ojn the top of it,it has a round thing that you can turn,kinda of like an anntena. on the back left hand side ther are on/off switches 4 of them to be exact for security cameras. To the right there is a plug in that kid of looks like a s-viedo plug in but its not because above the plug it has the letters EXP. To the right of that are two RCA plugs ins, above the first one is the letter A(RCA color white) and above the second one is the letter V(RCA color yellow). On the right of the RCA plug in is the plug in for the power supply which is 12 volt power supply. Can you please tell me what this gadet is called and how I would use it with my survellance cameras please and thank you. My email is honneydo@msn.com
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by MickeyGirl, posted on Apr 08, 2008
I believe I have the same box as Panelopy. However, on the top of the box, there is a flat, round antenna, I assume, that has Philips Magnavox written on it, along with an arrow. I am not sure what this box is either, but I think it may be a wireless camera receiver of some sort. I have tried to find information about this item, but it is difficult when I am limited to any information available on the box. I know it is a Philips Magnavox, and it has RX244 on the front panel.
Clarification Request
by Nitrotrike, posted on Apr 04, 2008
Does it look like this?
http://i29.tinypic.com/22xf69.jpg
Best Solution
Helpful (85)
Benimur
Rank:Guru Guru
Rating: 87%, 2403 votes
It could possibly be a Voltec RX244 Camera Receiver operating at 2.4GHz. The A could be for the audio and the V for video. All I can gather is the it can switched up to 4 cameras. Other than that everything else would be conjecture on my part. Incidentally, there was also a Magnavox RX244.
This company might or might not be the main distributor. Additionally you can try visual comparison here.
From your post/description, it would also seem that the device/gadget could be reversed engineered and determine features, functions and operations. But that of course would require more than just basic familiarity with electronic components and circuitry.
Would it be possible for you to post pictures of the connectors and the inside PCB?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Comment by Benimur, posted on Apr 04, 2008
Hi you buddy, my compliments.
Rating Locked! (?) panelopy has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on I have no idea what this is called and Im not really sure how I use it,please help if you can.:
I don't want to Accept this solution
Can you Help with these KVM Switches problems?
CTG 2-PORT Dvi and USB KVM Switch with...
Ever since I had my DSL line turned on 18 months ago I...
Belkin (F1DK102P) 2-port KVM Switch
microsoft natural erogonomic keyboard 4000 will not switch...
StarTech.com StarView SV211K 2-port KVM...
hi could you please post the lates ntl uk starivew codes...
hi, do you possibly have the codes for starview box, ntl...
Hi I bought a starview3 super box and when i went and...
Loading problems.
Repair Service
Find KVM Switch Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
