Phaser 8200 Error Code 21.07 - Office Equipment & Supplies
  • 2 more comments
  • cwatson316 Apr 04, 2008
    Xerox Links do not work
    Thanks
    email = cwatson@kwmappraisal.com
    The error code says Jet right therm: out of range Code 21.07
  • cwatson316 Apr 09, 2008
    The error code says Jet right therm: out of range Code 21.07 this code appears in the printhead test. Help!!!
    President:
  • 2,072 Answers
That is a communication error to the main board, I am going to give you a link so the graphics will show up better.
http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi
Posted on Apr 04, 2008
  • 4 more comments
  • Rick Kasper Apr 04, 2008
    These plastic knobs and handle are on the back of the printer
    The following 2 links display the removing and installing the main board in a Flash movie format and Requires the Macromedia Flash Player
    1. Turn off the printer power switch.
    2. Disconnect any communication cables.
    3. Turn the plastic knobs on the back of the printer counter-clockwise to free the main board.
    4. Extend the plastic handle and pull it to remove the main board.
    5. Guide the main board in to the guides on the printer and slide it in. To get it in the final bit, press firmly on the indentations on the main board back panel.
    6. Turn the plastic knobs clockwise to keep the main board firmly seated
    Yes I know, I copied and pasted the information into the solution.
    The main board, those plastic knobs are on the back close to the middle. They are D shaped, align the flat spots to the edge of the frame and slide the board assembly out, then slide it back in and add some pressure so it snaps back in firmly. Tighten the knobs.
    If you go to the Xerox site it takes at east 10 links to get to the page.
    If you want to provide an E-mail address I will copy and past all the info to you.
  • Rick Kasper Apr 18, 2008
Phaser 8200 error code
I think I had this error once. Could be your bulbs (one or both) are out or are on their way out. I had to replace mine. They are 150 watt halogen bulbs. When you open it up, do you see lights on the side peering in?
Jul 02, 2009 | Xerox Phaser 8200 Laser Printer
Xerox phaser error code is : 07.002.44:10318 what dose this mean
07,002.44:
PM_FAULT_PROCESS_MOTOR_STALL
Verify process motor operation with the Process Motor diagnostic
test. Also exercise processes run with the process motor;
transfix, drum maintenance and head tilt. This can be caused by
the power control board. The process motor may have more than
one task initiated. Reset all solenoids and the pressure roller
prior to cycling power.
Jun 17, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 Error Code 15004.45:18370
unless you know how to service preheater/drum heater then you have no choice but to ask the qualified person to do it for you....
YOu can read more details baout the failure at below link..
http://etech.maiila.com/xerox-phaser-8200-drivers-software-manual-and-troubleshooting
Apr 22, 2009 | Xerox Phaser 8200 Laser Printer
Memory error
Have you try to restart your printer?
you may want to read below link. might be useful to solve your problem..
Mar 17, 2009 | Xerox Phaser 8200 Laser Printer
Error 15 004 45 37888
From the service manual:
15,004.45:
TCD_THERMISTOR_
SLOW
Most likely cause is a failed drum heater. The head to drum gap
should only be checked or adjusted on the Phaser 840. The
Phaser 850, 860, and 8200 have a pre-adjusted head.
In other words, you need to replace the drum heater.
Thanks and please take a moment to rate as fixya.
Mar 13, 2009 | Xerox Phaser 8200 Laser Printer
Error code 15.004.45.172027 on Phaser 8200
I would suggest calling a service agent and have him bring a paper pre heater.
Feb 25, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 15,004.45:50425 error
There are 2 150 watt halogen lamps that heat the drum that are blown out. Thats your problem. If you want to try to replace them let me know.
Feb 23, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8200 Error code 15.004.45:30201
The drum heaters are bad. There are 2 ,,,, 150 watt halogen lamps that warm the drum. One or both of them are bad.
If you want the directions let me know.
Feb 19, 2009 | Xerox Phaser 8200 Laser Printer
Xerox Phaser 8200 error code 15004.45:25393
Yep. The drum heaters are burnt out.
There are 2,,, 150 watt Halogen lamps that heat the drum.
The way to see if they are working or not is to turn off the lights in the office or room the printer is in. Turn the machine on and look through the fan slots on the right side of the machine. GIve it a minute or two and you should see lamps glowing inside, ( I seriously doubt you will see them comming on).
That is a very common problem, You can purchase those lamps at Lowes, Home Depot or anywhere you can purchase halogen lamps. They cost about 12 dollars for a good pair.
Replace both .. If you want to try and do it yourself. Let me know I will send you directions.
Sep 11, 2008 | Xerox Phaser 8200 Laser Printer
175 people viewed this question
jasbo
jasbo
