I have an a1530cs copier. It will not pick up any paper when the button is presseed . it just makes a noise (low vibration) like it is wanting to pick-up .can you please help me?
    Genius:
  • 3,422 Answers
HI,
Here are few troubleshooting steps you can try:
1)In your print properties you may need to adjust the paper settings to reflect the size and finish of the paper.
if you are using a 4 x 6 paper you want to make sure that the slide is all the way over to fit the paper properly and that you have the paper size set to 4 x 6
2)take apart your printer and make sure the paper feed rollers roll.
3)
Turn off the printer.
Open the printer door.
Remove the Cartridge.
Look down behind the cartridge, there's a small white roll. Try playing with it. move it back and forth. try emptying the paper tray and place it back in the printer.
Turn on the printer.
If you still face the problem then you will have to call a tech to fix it.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 15, 2008
    Brigadier General:
  • 3,614 Answers
Most such printing problems stem from incorrect paper types or paper loading. Make sure that your paper is loaded properly, and that the paper type is made for your specific printer.
If paper is not feeding properly into the printer, the problem may stem from hardware failure. Check the feed assembly to see if all the parts are in working order. You may be able to manually advance the paper in order to see which component may be failing. If necessary, clean the paper pickup rollers to make sure the paper path is free of sticky dirt and debris.
  • 13,433 Answers
Seems the mechanism is jammed or broken if your not experienced in repairing these I recommend you contact
your dealer or copystar support / local professional.
  • Ekse Apr 15, 2008
    Fixya is haveing a email system problem, you might not get notifyed about my solution untill it is fixed.
  • 3,037 Answers
Am I correct in thinking that the roller spins and tries to pick up the paper but it won't catch (maybe you can't even see it)? If this is so, try cleaning off the roller with a cloth to get off everything that has collected on it. If this doesn't help let me know.
If you can give me more information about this, I can further assist you and let me know how the above information worked out for you.
Thank you for using Fixya and Good Luck!
    Sergeant:
    Champion:
  • 427 Answers
Possibly a paper jam? Make sure that nothing is interfering with the gears that provide the pover to the pieces that pick up the paper.
  • 813 Answers
Hi frined
your printer roller gone bad take ur printer with a good technision
he will change it
Posted on Apr 04, 2008
    President:
  • 1,944 Answers
What brand is the copier? Did you check that there are no paper jams?
4mv won't pick up paper
The feed rollers need to be replaced. The squeak is the worn rollers sliding over the edge of the paper.
Mar 25, 2014 | HP LaserJet 4mv Printer
Rollers not picking up the paper or picking too many pieces at once.
Pickup rollers can be easily replaced if you want to try that first. But the other noises could point to stripped gears or a different problem internally
Jan 08, 2014 | HP Officejet Pro 8500A Wireless All-in-One...
Hp officejet pro l7780 all in one printer, Cleaned the pick up roller still not picking up paper
The pick up roller may be worn and in need of replacement. The slight grinding noise is the pickup roller trying to work but slipping
Oct 30, 2012 | HP Office Equipment & Supplies
Canon IR2000 feeder noise
uhm i know that the reset function helps when on the control pannel display is displayed with the error code E000, but what was said from the noise the copier makes when it copies, i would say that the pick up paper assembly, will stop working, if u have other trays in your copier, try coping from there and see if it makes the same noise, if not..then probably, u have to replace that part soon " pick up paper assembly" am not an expert, but i also have one, and some things i've seen with it:)
Mar 06, 2012 | Canon imageRUNNER 2200
Grinding noise during warm up. Tells my theres no paper but there is
That is the fuser drive gear. It wears out and needs to be replaced.
That causes a vibration and will cause your low paper message falsely.
Aug 04, 2010 | Sharp AL 1631 Copier
Brother HL-5250dnt - Clicking Noise and not picking up paper
You may have to use a true Brother toner cartridge as I have the same problem with me MFC 8500. If I use a compatible cartridge it clicks and if I use a geniune Brothr cartridge it does. Brother direct brought this to my attention.
Apr 06, 2009 | Brother HL-5250dnt Laser Printer
Cassette error
On the control panel for the printer, there's a Feed Switch button that's easily touched by accident. Ensure the Feed Switch is set to the paper source you're using (e.g. either the back or front). The graphic of the printer next to the Feed Switch button will light up to indicate the paper tray it's attempting to use.
Dec 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
Canon PC920 paper feed "clacking" & not working.
check the tray and make sure the guides are set correctly, clacking sound is usually because the tray is set for Legal and has Letter, the paper is towards the bac of the tray and the pick up assembly is making the noise,
otherwise the tray is either not going up (broken gear, )
Aug 22, 2008 | Canon PC-920 Black and White Copier
Won't pick up the paper but the cartridges move up and down the line
Hai Boss it is not the problem with the Catridge . Some of the Spring has begin missing in assemble part . you pull the paper out the problem cause from there never ever pull the paper ..
Feb 12, 2008 | HP DeskJet 970cse InkJet Printer
HP 6110xi
Make sure it picks up paper - this is probably worn paper pick up wheels this is a repairable problem but you will have to contact HP about it. or go to www.fixyourownprinter.com
Aug 24, 2007 | HP OfficeJet 6110 All-In-One InkJet...
jasbo
jasbo
