I need to know if I can charge my laptop through usb cable
  • 883 Answers
Negative...USB has only a source voltage with current only allowed to flow away from the hub, in your case, the laptop.
Posted on Apr 04, 2008
Can I charge my PP39L laptop with a USB cable?
the only thing to be aware of is the voltage cannot exceed that required for the laptop . for example if the solar panel puts out 12 volts you will need an adaptor before the usb connection to reduce the power to the voltage for the laptop
Mar 29, 2015 | Dell Studio Computers & Internet
My iPhone is flashing battery and beeping
I assume it is on the black screen with the empty battery. If it doesnt come up with the little lightning bolt to show it is charging then it is likely the cable or charger are dead. try laptop USB charging port instead. Note I have had faulty cables that would lock up each USB port tried until I rebooted. try a friends charging rig that you know works. Another thing to check, is pocket fluff in the charge port which may prevent you inserting charging cabel correctly.
Aug 04, 2014 | Apple Iphone 4s I Phone 4 S Factory...
How can i charge my nokia 1110i to USB cable. I have my USB cable and connect to my laptop but it doesn't work. Is there any driver needed to install it?
No you could not do this because there is no cable other than Flashing Easy Cable.Which will only be used by mobile technicians.Charge with travel charger is the only way.USB doesn't supports.Thanks
Nov 22, 2012 | Nokia 1110i Cellular Phone
My ps3 controller won't work turn on or charge
Check to see if your USB cable works.It coulb be that your USB cable dont work and since your your ps3 remote needs to be charged then when you connect it to charge nothing happens so try using a different USB cable to see if that works..
Jul 02, 2011 | Sony Playstation 3 (PS3) Console
I connected a USB cable to my spice D88 gold with laptop.After removing it the phone is not getting chqrged.On connecting the charger it says the usb has been connected and gives the usb results. Kindly...
Hi.
Pls check setting for USB. If it has charging by USB activated. Try and deactivate for a while and charge it. Also try and use another charger for a while to check if the charger you have has any problems.
Let me know if this helps.
Jun 09, 2011 | Cell Phones
Hi so i must charger my ps3 pad to laptop i put to usb laptop and after 24h i try conection to ps3 and nothing i buy new pad and is this same problem if you know why ???
If you are trying to charge your controller with a laptop, you have to make sure the laptop is ON for there to be power to the USB port.
The other thing I think might be the issue is you may have a bad USB cable. Try a different cable or try the cable with your PS3 while the console is turned on and see if your controller charges. You will know the controller is charging when you see the 4 blinking red lights on the top edge of the controller.
Good luck.
Apr 26, 2011 | Video Game Consoles & Games
How can i charge my battery with USB cable? i have problem with baterry or with baterry's port, i dont know exactly, please help me, thnxx
Because your question is NOT so accurate and clear, I will bring out to you the following scenario:
1- In case you have a problem in the electrical wired cable itself that hold the transfered power to charge the laptop battery then you can't do anything except buying another electrical charger.
2- In case you have a problem with the laptop battery, you can simply remove that battery and straightly connect the electrical wired cable to the slot power of laptop.
3- You recommended charging your batter with the USB cable, which is impossible due to the following reasons:
a) USB cables assemblies are used in the transmission of data across networks in case they are network
b) Cable assemblies are collections of wires or cables banded into a single unit with connectors on at least one end.
c) USB connectors are used with universal serial bus (USB) ports. They can be used to connect USB products together, or to connect USB wires and peripherals to other standard port types.
d) The cable assembly may be used for various computer applications like connecting mice, keyboards, printers, modems or other peripheral devices.
The concept of the above description is that you need a cable that transfer to you a specific voltage from a generated magnetic chain to the receiving destination.
Therefore, USB cable have a huge difference in the capacity of the Electricity cable, where USB cables are for data transfer, and Electrical Cables are for Electric Power Voltage (EPV) Transfer.
I know that you haven't ask for all of this, but the main idea of my explanation is to clarify on why there's NO USB cable that can charge your battery, and those that are charging your phone are doing that through the very low voltage that comes from the vibration of chain magnetic into the USB cable transfered from a higher voltage i.e. Computer, Socket Power, etc...
Regards,
Jan 06, 2010 | HP Pavilion dv6000z Notebook
How do i recharge my mp3 on my laptop?
Connect USB cable that came with mp3 to the laptop. If it asks for driver download it from the website of that MP3 manufacturer.
Sep 08, 2009 | Audio Players & Recorders
LG Secret charging
Dr Know, doesn't know what he's talking about. I have a LG KF750 and have experienced the same problem.
Solution - Really jam the cable into the socket! The connection is pretty rubbish. The phone charging icon will (with some force and wiggling) appear on screen. Then carefully put it down and don't touch it!
USB charges very slowly, if charging from a dead flat battery it may take a good 20mins of charging to boot up.
P.S. the red camera light is not supposed to come on when charging. Keep wiggling the cable and the light will go off when the phone charging icon appears.
Dec 16, 2008 | LG Secret ? KF750 Cellular Phone
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
