Back to:
Tags:
Sony DAV-S500 System
Channel not working properly (by 2 users)
posted by JamesWilliam on Apr 04, 2008
The L Front channel is intermittent, mostly in going into 'mute' mode - ie the sound is very faint. Not a speaker connection problem, as there is a good deal of hiss when the channel 'mutes' itself. I've also taken the case off and reconnected al the leads. All the rest is fine.
Jim
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by Ronny1988, posted on May 26, 2008
I have exact the same problem, I believe.
The left front speaker has a lot of noise, the speaker is ok, I switched the left front speaker with the center, then it worked just fine.
The volume is lower then the volume of the other speakers and there is a lot of noise, what can be the problem?
Can you Help with these Home Theater Systems problems?
I get no sound from the front left speaker. Do you know if...
i have purchased this second hand in good faith, i have...
I have purchased this second hand in good faith, I have...
The machine is no any disply and the red LED on its power...
I have just bought a DVD set with 3 discs. One works fine,...
Loading problems.
Repair Service
Find Home Theater Sys. Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
