Creative Labs Zen MicroPhoto MP3 Player Logo
Posted on Apr 04, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Malfunction when connected to my computer a message comes up saying "computer does not recognise the device. when i click on message another message comes up saying there is a malfunction. after a few days i tried again and it worked fine. then when the battery ran out i tried to charge it but the problem started all over again
Anonymous
Level 3:
President:
  • Master 4,402 Answers
  • Posted on Sep 03, 2008
Anonymous
Master
Level 3:
President:
Answers
4402
Questions
0
Helped
1710765
Points
8129
Remove the usb drivers from the pc and then reboot and let windows reinstall the drivers, you can also try the usb ports on the back of the pc since they have more power.
http://serviceman.site88.net/
Finepix J28 device not recognised
Hi Jemma, i suggest you to change the USB female port. Use the other USB connector in your laptop. If you face same problem then let me know or call me +918296415259
When i plug the usb into my laptop it comes up with a message saying, ' USB device not recognised. One of the USB devices attached to this computer has malfunctioned, and Windows does not recognise it....
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options update driver disable uninstall scan for hardware changes
select properties you should see options in the general tab to troubleshoot policies volumes driver and details under the driver tab you will have the options to check the driver details update driver rollback driver or uninstall
hope this helps
EXTERNAL OPTICAL MOUSE IS NOT RECOGNISED BY LAPTOP
1> Click on start and then run or press( windows key+R) and type devmgmt.msc and then expand the item Mice and other pointing devices, right click on ps2 compatible mouse or the item for the mouse.
2> On the Power Management tab, change the power management settings.
Verbatim 1tb external hard drive malfunction error message
Try changing the USB cable that connects the hard disk to the computer, this message usually comes when the cable is damaged.
2answers
USB malfunctioned message
1)right click the my computer icon
2)click properties and then click hardware n go to device manager.
3)uninstall all usb ports and then scan for hardware changes
4)ur pc will detect your printer and ask for printer drivers
5)re load drivers and your pc will communicate with your printer
6)for reloding install the cd follow the instructions on the screen and click next
7)restart when the printer is loded.connect the wires and cords properly
Windows not recognised
Press and hold the lower volume button and plug it in to the computer simultaneously and keep holding the minus button until a box appears where the message of usb device malfunctioned and click on it. Then follow the instructions and it should be recognized.
Computer
First check all connection.Then format the operating system and reinstall it.
Top Creative Labs Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
