Question about Dell Dimension 4600 PC Desktop
Boot drive no longer has a drive letter
Gentlemen,
After installing Norton 360 on my PC (running XP SP1) in late January 2008, I discovered that I could no longer see my boot drive letter designation in Windows Explorer, although the drive itself is still visible in Device Manager. (I have two additional internal hard drives, both of which are visible.)
And I can't reassign a letter, because it's the boot drive.
Not sure if this is a serious problem, but am uncomfortable with the problem.
Should I consider a workaround, like installing XP on one of the two other hard drives, booting from that drive (through BIOS), and then reassign a letter to the old boot drive, the (again through BIOS) reset the boot drive to the-once-old-and-new-again boot drive.
Or is this just too convoluted.
I'd appreciate your thoughts.
Thanks.
John Pendergast
    Sergeant:
  • 318 Answers
I am not a fan of Norton, but, I would uninstall Norton 360, see if the drive letter comes back. If that works you can try to re-install your Norton, and if it happens again, use a different anti-virus.
Posted on Apr 05, 2008
SOURCE:
How do I fix Fader Sys issues
first of all uninstall norton it uses up memory and connection speed & uses up alot of resources & hard drive space...so get rid of norton...
Mar 02, 2012 | Microsoft Windows XP Home Edition
After I download Norton 2010 (from CD) my comuter
Firstly downland and Norton removal tool to safely remove installed Norton program
To download Norton removal tool
1. www.norton.com/nrt
or
2. www.symantec.com/autotools download and run first tool
Once we finished the un installation we can
To download Norton 360 version 4.0
1. www.norton.com/n360s_4
If are having Norton 36 premier version
go to www.norton.com/n360p_4 to download Norton 360 premier version 4.0
once we finished the installation we can activate with the existing product key If you will get error message like "you exceed number of installation" while trying to activate you need to contact the Norton support to reset the installation count.
Jul 19, 2010 | Norton Internet Security 2005...
I have Norton 360 V.2. Last night I downloaded
Boot up the PC in safe mode. How? Well when you start the PC press F8 before the windows start loading. A menu will open up. On top or there so you will find safe mode. Select it and boot. On booting in safe mode you will be warned that your PC is running in safe mode. Done? Now start control panel and then Add Remove Programs. Once that window is populated with all the progs that are installed on your PC, select Norton V3 and uninstall it. Uninstall V2 as well. Restart the PC in normal mode. Now install V3 and compute happily.
Aug 07, 2009 | Symantec Norton 360 Version 3.0 Full...
Attempted to upgrade Vista to SP1 on an E-machine, during install, Norton reinstalled, upon rebooting - BSOD so I don't know if SP1 issue or Norton, or both. Using VISTA disk, the bar progresses and then...
Try booting into safe mode.
If you can, I suggest getting rid of Norton. The drivers are not compatable with vista.
Vista has a ton of issues and many types of softwhere will not run or work.
If you want a good virus software, use the new software from Microsoft.
Feb 21, 2009 | E-Machines eMachines Desktop PC
Cannot launch my Norton 360 to perform scan
Boot in safe mode and try to run virus software.
If you can remove hard drive? find another hard drive that has a system with virus software, and make your drive the secondary drive and run virus software.
Usually your virus cd boots or lets you make a boot floppy, when booted run virus software.
Have a nice day
Feb 07, 2009 | Symantec Norton 360 Full Version for PC...
I had to replace my pc with a new one. Most All the data were transfered, but not my norton systems works standard which I purchased in late January 2008. Product serial number XJ8KGJVKYJK3. Can my current...
be sure to see or verify that the norton system if it is still compatible to the vista OS. else maybe u can inquire more on www.symantec.com
may this help.
melnavz
Dec 08, 2008 | Computers & Internet
I have renewed Norton 360 for my three computers but only one of them(the one I used to renew) quit sending the expiration notice. Now I have lost Norton n one or maybe both of my other computers. What...
You need to Download Norton Removal Tool from the Following Link.
http://service1.symantec.com/SUPPORT/tsgeninfo.nsf/docid/2007080716223439?Open&docid=2005033108162039&nsf=tsgeninfo.nsf&view=docid
Once you have Downloadand saved it on Desktop then Doubleclick on the Norton removal tool Icon and run the Norton Removal Tool.
The Norton Removal Tool uninstalls all Norton 2008/2007/2006/2005/2004/2003 products and Norton 360 from your computer. If you use ACT! or WinFAX, back up those databases before you proceed.Follow the on-screen instructions. Your computer may be restarted more than once, and you may be asked to repeat some steps after the computer restarts.
once the uninstallation compleates the You need to restart the computer and reinstall the Norton 360 on the computer.
Follow the Instructiions to Reinstall Norton 360 2.0
1.Do one of the following:
If you have the installation CD, insert the CD into the CD-ROM drive, and then click Install Norton 360.
Note:-If you have downloaded the product, double-click the installation file. Unless you saved it elsewhere, the installation file is on the Windows desktop.
2.Read the License Agreement, and then click I Agree.
If you do not click I Agree, you cannot continue the installation.
3.Follow the on-screen instructions.
Once the Installation is compleate you need to Enter you Activation key and it will automatic Activate it, after the Activation you need to run Live updates to Update Norton 360.
You can do the same on Both PCs.This will resolve your Issue.
Jul 04, 2008 | Computers & Internet
I have just had to re install norton internet security 2008 and now it will not start
Check to see if the computer meets the minimum system requirements
    To successfully install Norton Internet Security 2008, your system must meet the following minimum requirements:
    Basic requirements for Windows XP:
    * Windows XP Home Edition or Professional Edition
    * 300-MHz or faster processor
    * 256 MB of RAM
    * 350 MB of hard disk space
for more information check here
How to install Norton Internet Security 2008?
and
further information
http://forums.2cpu.com/archive/index.php/t-87910.html
Jul 01, 2008 | Computers & Internet
Slow computer since installing Norton 360
Hello
Actually all Norton products slow down the computers. Why dont you uninstall Norton 360, and see whether the performance of your computer has increased,if it does, ill recommend you to install Bitdefender Internet Security 2008, please check link below:
http://internet-security-suite-review.toptenreviews.com/
it is a review of all the security softwares. and also ill recommend you to install, Tuneup Utilities 2008, it will keep your computer clean of junk files.
Hope this helps you.
Always here to help
RAhUL_Hunk
Jun 19, 2008 | Microsoft Windows XP Home Edition
2008 Trend Micro Internet Security not compatable to Windows Vista SP1 and Windows XP SP3.
I suggest you to use NORTON 360. this product is so cool.
enhanced antivirus
online fraud protection
automated storage and retrieval
clean up and defragmentation
just like a all in one package from symantec.
i can help you with this product if you have problems
Jan 28, 2008 | Trend Micro PC-cillin Internet Security...
Dell Dimension 4600 PC Desktop Logo
55 people viewed this question
Ekse
Clive
Clive
