Question about Jura Capresso Impressa S90 Espresso Machine
I have a Jura-Capressa S9 that is leaking near the water intake. How do you open one of these to check it. They want $250 (flat fee) to repair it.
  • brad1240 Apr 11, 2008
    I have the same problem water leaking out of the bottom of the machine. The machine is aprox 3 years old.
  • jfmartin May 11, 2010
    can you please give more detail? thanks.
I have fixed this problem..................there is a small attachment on the back (2 in fact). the inlet & out let of the boiler.
The start to leak for some silly reason. U need to replace this
Posted on Apr 30, 2009
My Jura Impressa S9 is leaking clear water from the bottom right side every time I run Rinse or make coffee. The machine has 5 years and never been descaled as per recommendation from Jura.
The heating unit may be corroded. I have an E9 and I run the descaler although I still have a filter installed as well. You can take the cover off the unit and run it to see if the water heating until is leaking (the pressure thru it will burst the seal if it is corroded.). I had a jura that lasted about 5 years - if you can get to the heating unit, you can replace it yourself but it is not a low cost part.
Jan 04, 2018 | Coffee Makers & Espresso Machines
How do I un glog the grinder
Don't see an un-gloger listed.
Sep 15, 2014 | Jura Capresso Impressa S9 Coffee...
Filter change
this was absolutely the problem with my Jura Capressa E-8 machine. I followed instructions after changing the filter. I opened tap-machine stated that it was filling system- I closed tap when instruction. The open tap remained on because no water was filling system. I took the frother tip off and opened tap. Water filled system (container under frother). I closed tap without the frother tip. Machine Ready.... (I heated water in microwave for three minutes) I placed the frother tip in there and used a wooden skewer to ensure frother was clear of debris... Worked like a charm!
Nov 26, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capressa -Tray will not go in, looks like something from above protruding down in the back so that the tray sticks out 1/2 inch (so machine does not work)
I had the same issue. Had to send mine in for repair. Cost $235.00. Nothing I did would fix the issue. They said there was a major blockage. They cleaned it and sent it back. They also fixed my issue with water leaking from the frother.
Nov 08, 2011 | Jura Capresso Impressa E8 Espresso/Coffee...
My jura Impressa S9 chrome keeps shorting out and blowing the fuse or tripping the mains? Help
Hi.Id check the solenids and pumps. Most likely to be a pump. Their positioned under the water tank. Full disassembly of the machine panels, a must. They slide out when your there. dazza
Oct 13, 2011 | Jura Capresso Impressa S9 Coffee...
Water leaking jura s9
The connectors on capresso machines are very tricky.
take it a part again, and make sure all the rings and pressing clamps are in the right place. Also take a good look and "IN" on your hot water tank, and the pressure relief valve in back of machine
Mar 24, 2010 | Jura Capresso Impressa S9 Coffee...
Rinse error
I'm not exactly sure what was going on as I tried again to push the rinse button possibly a little harder this time and now it is working fine.
Sep 26, 2008 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Capressa E9 Leaking
Your spout is probly cracked (a common problem). It won't hurt the machine if you want to live with making one cup at a time to catch it all.
If you want to get it repaired go to Click on Jura Repair for shipping instructions. We can turn the job around in 24 hours. The repair will also include a free software update.
Aug 02, 2008 | Jura Capresso Impressa E9 Espresso Machine...
Jura Capresso Impressa S90 Espresso Machine Logo
627 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Ken Macumber
Ken Macumber
Level 1 Expert
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
