Question about Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine
Troy bult junior has new tines , runs to fast...
Troy bult junior has new tines runs to fast
  • 1,389 Answers
MAKE TWO PASSES SET THE DEPTH GUIDE SO IT JUST BREAKS THE GROUND, DON'T TRY TO DO IT ALL AT ONCE. SOON AS THE GROUND IS LOOSE IT WILL DIG MUCH BETTER.. IT SHOULD HAVE A FORWARD AND REVERSE FOR THE TINES, GEARS FOR FORWARD REVERSE DRIVE
Posted on May 21, 2010
SOURCE:
Tiller moves to fast on a troy built rear tine
what do you mean - are you sure this is a husqvarna or a troy built tiller?
May 07, 2012 | Husqvarna PRRT850X 960920015 CA 17" Rear...
What oil goes in the gearbox behind the motor , I have a junior
any type of gear oil will work for this. I know some gardners that use tranny fluid for heat
May 04, 2010 | Troy-Bilt Pony Garden Tiller
Where do I find the model number and serial number, it is an old troy bilt rear tine tiller, two speed
The older models do not have an actual model number but only a name to distinguish the size. Early production models include the Horse, Pony and Junior. You must find the location of the serial number tag to order parts that will fit your particular rototiller for seamless replacement of parts. Hope this will help
Apr 23, 2010 | Troy-Bilt Pony Garden Tiller
New tines now gets away from me
double check to make sure you have the new tines in the right direction. also you could try to raise your machine, as the new tines are digging better it might not have to be as low as you had to go with your old ones.
Mar 25, 2010 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I can't move my Troy-Bilt tiller unless it's running.
Some Troy Bilt Tillers were designed with a manual "free-wheel". If yours is a Tuffy (and maybe a Junior), you have to pull pins out of the wheels to move the tiller without starting it. The larger tillers, Pony's and Horses, had a lever to shift to release the wheels.
Jun 12, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Troy bilt pony left side tine assembly fell off
sounds like the shaft is either bent,or the inside diameter is worn and the shaft tube needs to be replaced.
Apr 23, 2009 | Troy-Bilt Pony Garden Tiller
Does rear tine tiller run 2 belts
Check the Troybuilt website for specific info on your tiller.
www.troybuilt.com
Mar 22, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
How to remove rear tines to replace seals ?
The tines sometimes get frozen to the shaft. You might try penatrating oil and use a heat gun or hair dryer to heat to loosen.
Also tap wiht a hammer around shaft.
Mar 19, 2009 | Troy-Bilt Garden
Troy tiller tines
they should point inwards and towards the rear of the machine
Oct 17, 2008 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0 Tecumseh Engine Logo
180 people viewed this question
Top Troy Garden Experts
Neil Hancock
Jay Finke
Jay Finke
lnbn1975
Are you a Troy Garden Expert? Answer questions, earn points and help others
