Question about Linksys Wireless-G WRT54G Router
Setting up router having problems
I am trying to set up wireless router, I do not get the wizzord. Also do I need a wireless Adapter to use with my desk top. I want to be able to run desk top and lap top
    Brigadier General:
  • 6,966 Answers
You don't need to have a WiFi adapter for the desktop. It can be connected using a LAN cable from the PC's Ethernet port to one of the routers Ethernet port. AS long as the desktop is set to "Auto obtain IP add" then it should work straight out.
If the LinkSys WRT54G did not came with a setup CD/Wizard, then you would need to reset it since I can only assume that it has been tried/used elsewhere before and the settings/configuration may not match your ISP and/or your network configuration. Reset involves pressing a small recessed button at the rear of the unit for about 10 seconds or more.
Once the reset was done and your router can connect to your ISP and therefore your desktop to the Internet, the laptop would also follow suit as long as the network settings is likewise set to Auto obtain.....
To verify if you can connect to the router, on your desktop, open a browser and log on to your router using,
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Apr 04, 2008
I can't get my desk top to connect to internet it tells me my ip address is not right but my lap top goes through my desk top and i don't have any problems getting on line.
your dell needs a network adapter card or wireless card installed is that the case(look in b ack)
if no wireless, then it needs an ethernet cable plugged into modem/router from cin bell and then in back of dell
please advise your network configuration
May 28, 2012 | Dell Dimension E310 PC Desktop
What do I need to add to my desk top to have my internet run wireless?
A Wi Fi adapter card. Like the ones on the link below, just copy and paste. I'm NOT endorsing anything, just for demonstration purposes.
Sep 05, 2011 | D-Link DIR-615 Wireless Router
My desk top computer in the house is on-line, the laptop is not. Message says it cannot find any wireless networks - I tried everything listed except turning the broadband connection off - as that must...
Well, actually... it might help to turn the router off and then on again. Sometimes power-cycling the router can reset it, which might need to be done. I'm a big fan of the power-cycle; it works for all sorts of obscure problems.
Once the router is on again, use the laptop and adapter to check for wireless networks. If you still can't find a network, disconnect the ethernet cable from the back of the desktop computer, and try the wireless adapter with the desktop PC. If it works, the problem is with the laptop (possibly a power supply problem). If it doesn't work, the problem is either the adapter or the router.
Ideally you should then try your adapter with a friend's router. Eventually you will discover whether the router is playing up or whether the adapter is faulty.
In my (admittedly still limited) experience, connection problems are rarely about faulty equipment and more usually about incorrect settings, so it might also be worth running the New Connection Wizard from Network Connections in the Control Panel.
Oct 10, 2010 | 2wire (1000-000005-002) 802.11g/b Wireless...
Link the netgear wgr614v10 to linksys wireless adapter
First you will need to check the wireless settings of the router. Do you have any computer connected to the router ? If not then connect the computer to the router and open the set up page of the router, check the wireless settings of the router.
Once you have all the wireless settings of the router then you can try to connect to the wireless network on your wireless computer.
Apr 17, 2010 | NetGear WGR614 Wireless Router
Have a new desk top bought the wireless-g usb adapter wg111 to pick up my netgear range max wireless router wpn824v3. After installing the wireless-G picked up internet once but after the system was shut...
I have the WPN824v3 and it can be balky finding and connecting to a network sometimes. It works best (and gets the best range) using the Netgear RangeMax Wireless USB 2.0 adapter (WPN111). The router and this adapter are (according to Netgear) specifically designed to work with each other, thereby maximizing both the range and the speed of the router.
Feb 02, 2010 | NetGear RangeMax WPN824 Router
My wireless adapter for my desktop keeps connecting for awhile and the disconnect from my wireless router /modem. The router is less than 100 feet from the computer i need a new usb wireless adapter...
Is there any other wireless computer in the network ?
Right now the connection is dropping on your computer . It might be the problem with the wireless adapter of the computer or the wireless router .
You will need to isolate the problem.
If you have any other wireless computer in the network and that computer is also facing the same problem then it must be the router problem. You can check the settings of the router . for this you will need to access the router set up.
If you have other wireless computer in the network and that is working properly then it must be adapter issue. Try to uninstall or reinstall the adapter or Update drivers.
If you do not have any other wireless computer then try any laptop in this wireless network just to isolate the problem.
Click Here for more information about the routers and home wireless network
Dec 02, 2009 | 2wire (1000-100052-000) 802.11g/b Wireless...
I have a DIR-615 router that I have no problem connecting my laptops with internal wireless. However, trying to connect my desktop with a DWL-G620 Wireless Adapter. It detect the network but will not...
The WPA key is the encryption key that is configured in the router's wireless settings and the wireless cards in the laptop and desktop needs to be configured with this encryption setting to allow the laptop and desktop computer to communicate with the router.
You can view the encryption settings in the router's wireless settings or on the laptop's wireless card settings and then apply these encryption settings to the desktop's wireless card (ie. the SSID and the WPA encryption).
Nov 15, 2009 | D-Link Air DWL 520 802.11b (DWL-520)...
I have D-link 625 Wireless router but i try to connect on my desk top computer by Belkin G wireless USB network Adapter 5012. If i put password on WSK-Personal ( on wifi password setting) is not going...
Check your settings on your wireless setup and make sure the adapter on your computer is set to Security Type: Shared. That is the most over-looked stumbling block.
Nov 15, 2009 | D-Link DIR-625 (790069292637) Wireless...
I got belkin wireless g gaming adapter for my xbox 360 the other day and i downloadaded the cd on my computer and followed the instructions, but when i put it in my xbox 360 the xbox couldnot find the...
You will need to match the wireless settings of your router and the gaming adapter.
Who is the manufacturer of your router?
connect your computer to the router with the cable and open the set up page of the router. check the wireless settings of the router SSID, Channel, security settings.
now you gaming adapter and the Router IP address should be in the same range. Suppose if the router IP address is 192.168.x.y and the default IP address of the gaming adapter is 192.168.a.b., then the number x should be equal to a. If it is not then you will need to change the IP address of the gaming adapter so that x will be equal to a.
after that open the set up page of the gaming adapter and change the wireless settings.
power cycle the router and the gaming adapter and now it should work.
For more info about networking Click Here
Oct 06, 2009 | Belkin (F5D7011) 802.11g/b Wireless...
Linksys Wireless-G WRT54G Router Logo
100 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
