Question about Altec Lansing ADA 885 Computer Speakers
Altec Lansing ada885
My ada 885 screen appear HD (I dont know what means) then my left speaker nothing action means no sound appear...when i pressed diagnostic button..everything goes well...
Any solution on this...
Your kindest help is highly appreciated
Thanks and best regards
mykhairi@streamyx.com
  • 3 more comments
  • Anonymous May 24, 2008
    XP system
    Speaker check works fine but no PC audio.
    This is not the original computer - is there a software update I need to find?
  • Anonymous Nov 16, 2008
    i have the same problem which my screen are show HD but i never plug in and headset in the speaker.
    Day before, it still work well but it suddenly cant work anymore once it show the HD> I diagnosis the speaker by pressing the button at the sub woofer, all speakers are working well and have sound to come out,
    Any one know how to solve it?
  • thunder7420 Dec 03, 2008
    SATELLITES PLAY FINE ONLY MY SUBWOOFER PLAYS MUSIC BUT TURNS ITSELF ON AND OFF COULD THAT BE THE POWER SUPPLY GOING BAD OR MAYBE CIRCUIT BOARD IT DOESNT LOOK LIKE THE WOOFER BECAUSE IT PLAYS FINE WHEN ON I EVEN REPLACED THE LITTLE 1 AMP SLOW BLOW FUSE ON THE SUBWOOFER AAND STILL NO FIX HAS ANYONE HAD THE SAME PROBLEM YOU WOULD HEAR A CLICKING THAT THE SUBWOOFER TURNED ON AND OFF.
  • altec-s Apr 08, 2009
    i can't take apart the left speaker. i have the same problem and figure if i can actually get the thing open i can get somewhere. anyone know how to get the base open where the headset plug is on the left speaker base.
  • Andrew Jones Jul 25, 2017
    Cutting the wires seems rather ruthless when the problem isn't the wires. I do have the same problem with the headphone socket where it is cutting the sound from the speakers which is what it's supposed to do when the plug is inserted. The problem is caused by the silver contacts in the socket becoming corroded over time (Mine is now 17 years old). I suggest spraying WD40 into the socket hole and putting the plug in and out many times hopefully removing some of the corrosion. If this doesn't solve the problem then the socket (switch) will need replacing at a cost of approx. £2.00 ($4). There isn't any chip (IC) in the speaker just a switch (socket).
Same issue showed up for me today very randomly...
HD comes on and off for no reason and sound cuts in and out. This fix worked for me:
1.Disconnect the left speaker from the sub woofer.
2.Take the 4 screws out on the bottom of the left speaker. (They are under the rubber matting you can just poke holes through it)
3. Remove the bottom plastic assembly from the speaker
4. Cut the 4 wires to the headset chip. Careful not to cut any others to the speakers themselves!
5. Unscrew and remove headset plug chip
6. Reassemble and plug left speaker back into sub woofer.
No more HD issues =)
Posted on May 01, 2009
  • 4 more comments
  • miked2161 Jan 05, 2011
    This worked! In fact I didn't even need to cut all the wires. Just the 2 nearest the headphone socket front were enough (blue and grey I think). The HD sign went straght away and everything is well. Damn pleased as I really like these speakers. So simple.
  • calvingoh
    calvingoh Jan 16, 2013
    Work like a charm! Thank you!
  • calvingoh
  • pianom00
    pianom00 Mar 27, 2013
    I cut the grey wire only and now the HD is gone and my speakers are bumping! Thanks for the help. I love the internets.
  • Nghia Nguyen Dai Jun 19, 2013
    But now can not hear head phone, thanks .
HD means it has a headset plugged into the left front speaker. Maybe your speaker jack is fubarred. :/
Posted on Apr 10, 2008
Dp/n 08506p drivers
I have ALTEC LANSING DP/N 08506P speakers om my Windows 7 PC. The left speaker works fine but no sound from the right speaker. I "think" this is a rather recent event. Can you help?
May 24, 2014 | Altec Lansing ADA 885 Computer Speakers
Cable setup for Altec Lansing ADA885 system needed
Try using the internet to get the information you need
Mar 01, 2013 | Altec Lansing ADA 885 Computer Speakers
Altec lansing ada885 took a dose of 240V, burned fuse in place, replaced fuse, worked for about 2 hours, now nothing
Well is the new fuse still good or out again. if its good, then you probably fried the main board on the amplifier. These computer speakers do not handel big power serge's.
Mar 12, 2011 | Altec Lansing ADA 885 Computer Speakers
Hello, I have an Altes lansing ad-885 system and I have lost the cable that connects it to the pc, Where can I purchase a replacement. Thanks,
Altec Lansing ADA 885 connects with an SPDIF cable. Something like this should do the trick for you:
http://www.amazon.com/Toslink-Digital-SPDIF-Optical-Performance/dp/B001ENJ3ZA
Dec 22, 2010 | Altec Lansing ADA 885 Computer Speakers
Do you have information on an Altec Lansing Model ADA-885 speaker system?
http://supportapj.dell.com/support/edocs/acc/ada885/en/setup.htm
Aug 21, 2010 | Computers & Internet
Problem with Altec Lansing ADA 885 Computer
check u have the lastest sound driver.or u can try uninstalling it and run driver cleaner then try reinstalling driver.if u are using vista u may have to go to audio devices and set from there.also try air the input plug whole just incase dust has settle there. hope this helps.
dt
Dec 06, 2009 | Altec Lansing ADA 885 Computer Speakers
Subwoofer fuse 'holder' missing.
tape or solder a piece of metal across where the fuze and holder would go.
OR
go to radio shack, pick up a small cartridge style fuze holder and an appropriate replacement fuze. (if you dont have the original fuze, dont bother with this method) Open the box or case to gain access to the circuit board. solder a new holder to the contacts.
Be aware that I have no clue what the fuze holder on that particular model looks like.
May 27, 2009 | Altec Lansing ADA 885 Computer Speakers
Can I hook up my ada 885 to my dvd player& my flatscreen tv?
Yes. They are essentially Similar to any other 120 Watt Surround System for Home Entertainment. The Fact is, the only major difference is that the connections are different. On The PC it uses Stereo Standard Outputs. On Your DVD Player, It Will most Likely require an adapter to RCA (red/white -usually- Audio Cables). It just depends on your DVD Player. Have Fun!..... :)
Apr 20, 2009 | Altec Lansing ADA 885 Computer Speakers
Thanks for posting direct. As you posted, the Sony XBR has only left & right (white/red) outputs whereas your Altec ADA has multiple INputs. This leaves us with no other option but to used just the green INput of the Altec as the black and the S/PDIF has nowhere to be connected to in the Sony.
You would need to use a phone stereo to RCA cable/connector as shown below. Additionally, you would have to set up your speakers as suggested here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 11, 2008 | Altec Lansing ADA 885 Computer Speakers
Altec Lansing ADA 885 Computer Speakers Logo
2,460 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
