Question about Neff H5642 Convection / Microwave Oven
Neff H5642 1000 Watt Microwave
Stopped working, does not seem to cook anything or even heat anything up and cuts out after about 30 seconds.
Have removed but not sure where to start can anyone help me!!.
PS its about 3 years old and not much use either thanks
    Problem Solver:
  • 9 Answers
Sounds like the Magnetron may have collapsed. Probably not worth repairing. Check for burnt/browned components on circuit board/s. Burnt wires, insect or ant damage or soiling. Magnetron is the large-ish square metal object with lots of heat-sink fins on it. Check for discolouration. If nothing obvious, it's probably stuffed, If something is obvious, it's still stuffed, but it may be repairable.:::Spiceweasel.au
Posted on Apr 04, 2008
SOURCE:
Frigidaire Microwave heats everything except for food
Your fianc? employed a surefire method of killing a microwave oven. A simple perusal of the manual would have revealed the recommended cleaning method.
Feb 26, 2017 | Microwave Ovens
Ge pvm2070smss shuts down
It may be a noisy magnetron if the failure occurs in a second or two of hitting "Start" to begin cooking.
See this FixYa solution. even though your model number is different.
Otherwise, if the internal cooling fan is not running when you are cooking, it will shut down after 30-60 seconds or so and stay off until it cools back down.
Also see http://www.microwavedisplay.com/jvm2070.htm
Feb 24, 2013 | GE PVM2070SMSS Microwave Oven
Micro wave stops working after 30 secs
Replace the door interlockswitches - or try re-positioning the existing set. They wear after time
Jun 08, 2012 | Neff H5470 Microwave Oven
My neff h5430nogb 900 watt oven is not heating. it makes all the right sounds and the timer comes on but it doesn't heat? can you help
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 24, 2011 | Neff H5430 Convection Microwave Oven
Hi i have a neff microwave h5642nogb/02 when i switch it on to heat up food it cuts out after about 10 seconds can you please help
The magnetron is probably not working and the main board senses that.
Call an authorised repairer to fix it for you. There are no user serviceable parts in that section of the machine.
Feb 18, 2011 | Neff H5642 Convection / Microwave Oven
My h5470nogb/03 900 watt microwave cuts out after 20 seconds what is the problem please
Possibly the magnetron is not producing power and as the cavity temperature is not rising, it cuts out.
Is there an error code in the display?
Jan 02, 2011 | Neff H5470N0GB Microwave Oven
Turntable not turning - no microwave cooking
Could be a reset or fuse within may just have popped Beware of excessive internal Voltages when servicing...
Apr 20, 2010 | Neff B7740N0GB Microwave Oven
Kenmore Microwave Hood Combination: over the stove Model #721.80602500
Disclaimer: I'm a DIYer, not a technician.
Our GE over-the-range microwave stopped producing heat yesterday while warming part of the T-giving feast. Everything else (fan, control panel, light) works fine.
After disassembly and testing last night, I discovered a defective "secondary door switch." Your Kenmore uses a similar switch (~$19 on-line), and that might be the problem. But it also could be other things, such as a bad thermal cut-out.
If you know anyone who's handy with a multimeter, most of the basic diagnostics seem to be pretty straightforward.
Nov 23, 2007 | Kenmore 62622 Microwave Oven
Magic chef microwave shuts down
We had the same problem with our brand new Magic Chef. Before going through the trouble of taking it back I called Home Depot. After talking to a Home Depot Rep I am told that the overheat sensor is under the glass plate directly beneath the popcorn bag. Popcorn gets very hot and the heat of the popcorn causes the sensor to shut the machine down. I would imagine this would be the same for a baked potato.
Very poor design.
I was told to put a microwave safe plate down and put the popcorn bag on it. This should help to reduce the heat and not trip the sensor.
A safety sensor is great, but not if it keeps tripping the machine and shutting down!
Sep 02, 2007 | Microwave Ovens
Neff H5642 Convection / Microwave Oven Logo
761 people viewed this question
Top Neff Microwave Ovens Experts
William Miller
William Miller
Bob Farthing
Level 1 Expert
Jaime Hernandez
Are you a Neff Microwave Oven Expert? Answer questions, earn points and help others
