Question about HP Compaq Business NX9110 Notebook
Forgot my password
The only solution to rectify the problem of forgotten password is : reconnecting the jumper
OR any other solutions are there?
  • HP Master
  • 13,434 Answers
Is this a start up password before windows starts?
then this might help you!
http://www.tech-faq.com/reset-bios-password.shtml
Remember to rate the solution, I have over 700 solutions and most are unrated!
Thank you!
Posted on Apr 04, 2008
6ya staff
SOURCE:
I forgot my password to my dell laptop how do I reset it
Step 2: Reset Windows 7 password on your Dell laptop.
  1. Connect the Windows 7 password reset USB drive or CD/DVD drive into your locked Dell laptop.
  2. Set Dell laptop to boot from USB drive or CD-ROM. ...
  3. Once laptop boots up, select the password forgotten Windows 7 and user account. ...
  4. Password will be reset to blank.
How do I reset a forgotten password for Windows 7? - Quora
https://www.quora.com/How-do-I-reset-a-forgotten-password-for-Windows-7 forgot my password to my dell laptop how do reset it Google Search
Nov 29, 2016 | Dell Computers & Internet
Tip
Forgot you laptop password?
This tip will help those who have forgotten their bios password not windows password.
Your bios password is the password your computer asks for as soon as you power up your system. The windows password is the password needed to log onto your screen name.
If you have forgotten your bios password almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. E.G. If the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
on Jan 05, 2010 | Computers & Internet
My dell desktop asking for a password
If you want to create a new Basic Input/Output System (BIOS) password on a Dell Optiplex 745, reset the password. Resetting the password also applies if you want to remove an existing BIOS password. BIOS passwords are used to add an additional level of security to your machine. Without the correct BIOS password, your Dell Optiplex 745 will not complete the boot process. The password can be reset whether you know your current password or not.
Turn off your Dell Optiplex 745. Start the computer. Press "F2" the moment the Dell logo appears on the screen. You will only have two to three seconds to press the key. Enter your BIOS password. Navigate to the "Exit" screen. Select the "BIOS Password" setting. Enter your BIOS password and a new password if desired. Do not enter anything in the "New Password" box if you want to remove the BIOS password completely. Press "Enter" to save your password settings. Reset Forgotten Passwords Turn off your Dell Optiplex 745 and remove the power cord from the computer. Disconnect any external hardware and cables. Slide the release latch located on the back of your Optiplex 745. Lift the cover as you slide the latch. Hold the cover firmly and pivot it back on the hinges. Remove the cover from the hinges. Find the "PSWD" jumper on the motherboard. This is a two-pin jumper and should be clearly labeled. Use a flashlight and magnifying glass if you have trouble locating it. Remove the jumper from the motherboard. Replace the cover and slide it into place until the latch snaps into place. Reconnect the power cable and restart your computer. Shut down the computer after it has completely restarted. Disconnect all cables and remove the cover again. Replace the PSWD jumper. Replace the cover. Reconnect all cables and restart your computer.
b> Clearing forgotten passwords http://phubner.eng.ua.edu/Files/Optiplex 745/advfeat.htm - wp1117484
Mar 20, 2013 | Dell OPTIPLEX 745 PC Desktop
DELL LATITUDE D830 CMOS JUMPERS NEED DIAGRAM TO LOCATE JUMPERS
Forgot dell admin password? I also met the same trouble with you, but i used Smartkey Windows Password Recovery to help me to reset forgotten windows password, and you can see the detail direction from http://www.recoverlostpassword.com/products/windowspasswordrecovery.html.
Jun 28, 2012 | Dell Latitude D830 Laptop Computer PC...
How to rest bios password on gateway m-7342u
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk. A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
if you need laptop parts ? goto PcPartsLtd.com
May 09, 2012 | Gateway M7342u Laptop Charger...
Someone gave me a dell optiplex 240 pc they did not have the password i have tried removing the password jumper and also the battery and still it asks me for a pass word help
Make sure you remove the jumper with the power OFF (not connected)
Disabling a Forgotten Password
NOTICE: This process erases both the system and setup passwords.
1 Open the computer cover.
2 Remove the jumper plug from the PSWD jumper to disable the
password feature.
See "Jumper Settings" to locate the password jumper (labeled
"PSWD") on the system board.
3 Close the computer cover.
4 Reconnect your computer and devices to an electrical outlet, and then
turn them on.
This erases the existing password(s).
5 Enter system setup and verify that the password is disabled.
Jul 14, 2011 | Dell XPS 400 PC Desktop
I forgot my bios password of my laptop packard bell s4 easynote. I want to remove the cmos battery but i do not know t o open my laptop and take out the cmos battery to reset the password.please help me....
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
May 20, 2010 | Packard Bell (030069) Sound Card
Forgot password haw i can reset bios
May 20, 2010 | HP Compaq nx9030 Notebook
URGENT! Jumper setting (J4 jumper)
Hi, You can try this
1. Turn off the laptop
2. Disconnect AC adapter
3. Remove battery pack, and remove the keyboard
4. Remove the battery (located underneath the keyboard, the red/white wire)
5. Leave it for about 30 - 60 mins.
6. Reconnect the battery and reassemble the laptop
7. Reconnect AC adapter (Don't put in the battery pack yet!)
8. Turn on the computer and press F10 to enter the BIOS
9. Set the new BIOS password and save all settings.
10. Turn off the laptop and reinsert the battery
If this does not work you can try and check out a manual for your laptop here.
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=1847703
Mar 26, 2009 | HP Compaq nc6400 Notebook
HP Compaq Business NX9110 Notebook Logo
105 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
