Question about Acer Aspire 5500 5570-2609 Laptop
Only runs in safe mode
Ok my pc wont run in its normal mode, it come up in normal mode and freezes, then i would have to turn power off with out shutting it down and run it in safe mode, now when i try to run in safe mode the screen stay blank but it still comes up cause i hear it.
  • 472 Answers
Startup in Safe Mode (hehe sorry)
Goto START- RUN
Type msconfig press enter
Select the third tab at the top (Startup)
Click the word Manufacturer, it will sort out the list by who wrote the software.
Remove the ticks from all boxes that are NOT Microsoft as the manufacturer. This includes adobe, and unknown and anything else.
Click APPLY then OK
You will get a box asking you to restart, select yes.
This time try to boot normally.
If you get through, then the box will pop back up, repeat the procedure above, but now put the ticks back into boxes you believe you can trust such as Adobe. Do one or two at a time so you can narrow down what may have been causing the problem.
Posted on Apr 15, 2008
SOURCE:
My phone is a Verizon Moto G , it sometimes freezes the apps, and then it turns off by itself. When I try turning it on it wont work, then i hold the power button and it vibrates, and take a while to
Panesha
Try running the phone in safe mode. To do this. Press power button then when power down appears. Long press power down option. It will ask if you want to boot into safe mode. Select ok the it will reboot in safe mode. Use the phone in safe mode for 24 he's to see how it works. If it works better, then there is a third party app you installed on the phone that I'd causing freezing.
Mark
Motorola Support
Nov 13, 2014 | Motorola Mobility Moto G - Verizon Prepaid...
Hp pavilion dv4 2045dx keeps freezing and shutting down
It seems that you have a virus and it is running at boot.
first try to boot in safe mode and see if the computer stay up.
"Restart... hold the f8 key down until you see the boot option menu and select: "Safe Mode with Networking"If your pc still shut off and freezes then is not a virus and it is a hardware issue, possibly power issue or heating issue with the CPU.If it is ok in safe mode, then you need to remove the virus in safe mode. Download antivirus program that support safe mode operation.after successful removal of the viruses, reboot in normal mode and edit your msconfig, to remove any running programs that might be viruses.
If you continue to have a problem, I can log gin to your PC and fix it myself, just download teamviewer and contact meTony
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/tony_a41fa0b801734e2f
Feb 10, 2013 | Computers & Internet
How do you get out of Oceania change background w7?? My desktop is frozen on a cartoon image.
Sounds like you've got an infection. You probably need to scan the computer. Have you tried booting up in safe mode and see if it freezes?
Turn the computer off, then hit the power button to turn it back on and immediately start hitting the F8 key until you see Safe Mode. Select Safe Mode and let it boot up. Safe Mode will look different than normal windows, the screen will be darker and the icons will be bigger, this is normal.
If it does not freeze then turn it off and hit the power button to turn it on again and immediately start hitting the F8 key until you see Safe Mode. This time scroll down until you see SAFE MODE WITH NETWORKING. Select Safe Mode With Networking. This will give you internet connectivity. Download and Install MalwareBytes and run a QUICK SCAN.
Go to www.google.com and in the search box type:"Download cnet Malwarebytes" (without the quotes). Download andinstall malwarebytes from the sites download.cnet/malwarebytes. When thesite opens up click on the Green Download button on the left. Do notclick the Red Download button, that's junk. When it finishes installing the GuiInterface will open up with an offer to Accept a Trial Version orDecline. CLICK DECLINE you want the totally free version. Run aQUICK SCAN. As it scans, if it finds infections the number will be inred. When it finishes scanning, click SHOW RESULTS. A notepad textdocument will open up showing you the results. You can close the textdocument and go back to the Gui Interface where you will click REMOVE SELECTEDRESULTS. The objects will already be selected for you. When itfinishes removing the objects click ok and it will sometimes reboot yourmachine.
Apr 01, 2012 | Toshiba Computers & Internet
Hard drive not showing in explorer
Maybe a virus has hidden it. It seems like you are booting up ok and everything seems to be normal since you are able to run explorer. The drive is there otherwise you wouldn't be able to run explorer.
Try booting up in safe mode then checking explorer or click Start/My Computer to see if the drive is there.
Turn off your computer, then hit the power button to turn it on and immediately start hitting the F8 key repeatedly until you see Safe Mode. Select Safe Mode and let it boot up. Things will look different in safe mode. The desktop will be darker and the icons bigger, this is normal.
Mar 31, 2012 | Computers & Internet
Hp pavilion freezes at startup
Will it start in SAFE mode? Reboot and press F8 before Windows loads. This will give a small menu about different SAFE modes and Normal mode. Select SAFE mode and allow system to start. If the system starts fine then you have corrupted drivers and/or a virus which is corrupting your drivers. Download AVGFREE.exe, MALWAREBYTES.exe and SUPERANTISPYWARE.exe and run these. Now goto START, Run and type SFC/scannow and have your original disks handy because any corrupted drivers will have to be replaced. Now try to reboot into NORMAL mode. If OK you're done. If not OK or even in SAFE mode all you see is the cursor then the laptop needs to go to a reputable repair person or check my website www.micromendllc.com
Feb 26, 2010 | Microsoft HP Pavilion DV6276US Notebook PC
My pc wont even load up. it just gets stuck on the first HP screen with press f9 or f10. it just freezes up, and i dont know what to do. ive tried pressing both of the keys but none work.
try to start it in safe mode, then you can run system restore back to see if this fixes it. when computer loads up and shows the first screen, then push f-8 before it fully loads, this will take you to the safe mode screen, choose safe mode, then when loaded run system restore back to where the problem was ok. if this does not work then I would restore windows from the backup cd. if using safe mode when rebooting, it will change back to normal.
Feb 07, 2010 | HP Mini 1000 Netbook
My dell inspiron 1525 continuously keeps locking up. The screen just freezes up. I am unable to bring up task manager or hit escape. The only thing I can do is shut the power down / bring back up. This is...
Try this steps:
Turn off your laptop.
Power own your laptop then press release the F8 key until this option will popup.
Select Safe Mode.
Wait until Windows succesfully boots up using safe mode.
If you can succesfully log-on on your Safe Mode.
Press Windows Key + R
The run window pops up type MSCONFIG
Click Start Up as show below
Uncheck all check Items and click OK
Reboot your laptop and boot windows in normal mode...
Hope this helps...
Oct 21, 2009 | Dell Inspiron 1525 Laptop
A22m wont start
hi,
welcome to fixya,ok as u said that its been freezing up,and it is being freezing up all the time,what u have to have to do is that just run the scan of virus removal but u can log into the safe mode and then try and run virus scan and then try and turn on the computer and also try and do the msconfig and restart the computer from safe mode,it should work...goood luck...pls rate this solution....
Feb 16, 2009 | IBM ThinkPad A22m 2628 Notebook
Laptop works fine in safe mode but freezes in normal mode
Okay, easiest first. In Safe Mode, your sound won't work. Safe Mode means only enough drivers to make your PC more than a doorstop get loaded, so that's okay.
Second, if it boots to Safe Mode without difficulty, try running System Restore in System Tools. Go back to some date before when your issue started. That should get you going. Don't worry, your data files will not be affected in System Restore. I hope this helps.
Dec 28, 2008 | Dell Inspiron 2200 Notebook
Acer Aspire 5500 5570-2609 Laptop Logo
66 people viewed this question
Ekse
Alun Cox
