Question about Philips CDR796 2-Disc CD Recorder
Will not record disc-to-disc
After putting in both the recordable disc and the disc to be recorded, the display shows 'preparing' and will not continue. The machine then refuses to eject either disc unless you unplug it! I have had different messages displayed the most common being 'initialising'. I did leave the machine to it once thinking it would start recording- 8hours later it still had 'initialisng' on the display! When I first got this player it was very reliable, now though....please help!
The first thing to try is cleaning the lenses,sounds obvious,but i think thats why its continuing to try :initialising: if that fails the lense that reads the disc or both likely need realigning most problems that acure whith any cdplayers ect are down to the lenses.
Posted on Apr 04, 2008
SOURCE:
My Yamaha CDR D651 appears to dislike new 50x maxell CD-r discs saying not audio. Works fine with 12x discs. What's wrong? Rowan
you probably have regular cd-r disks that cannot be recorded on in this unit. You can only use disks marked "DIGITAL AUDIO" for recording
Sep 16, 2014 | Yamaha CDR-D651 2-Disc CD Recorder
DVD Recorder door sticks and the disc preparation process does not complete
Try to burn at the lowest speed possible or at one step lower speed that the one you are currently burning at.
Dec 27, 2013 | Dual Presidian DVD Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Philips DVDR3450H. How format the HD?
Found a document DVDR3450H_3452H_3460H_eurp FWUpgradewk635.pdf Describes procedure of firmware update and disc formatting. Some cut'n'paste from the document:
2. Preparations for new HDD
In the event when the set unable to boot up or recordings not stored due to an defective HDD, the HDD will have to be replaced with the steps describe below:
1. Replace the Faulty HDD with a new HDD.
2. Before connecting the new HDD on the Digital Board ,the jumper pin at the connector of the HDD is to be removed.
3. Connect the new HDD to the Digital Board.
4. Power up the set . It will open the tray and prompt to load the upgrading disc.(the upgrade disc is
the same disc under firmware upgrading.)
5. The set will display
“Load”.
6. Put the upgrade disc and close the tray and the set will show
“Copy” ……… “Boot”
7. The rest of the procedure follows the software upgrade given in 1B -Procedure to apply the firmware upgrade.
*Note : 1)Do not press any button or interrupt the main supply ,otherwise the set may
become defective.
2)When the HDD formatting is successful ,the set will go to standby mode.
Jan 17, 2010 | Philips DVDR3450H DVD Recorder/HDD...
I PUT IN A NEW BLANK DVD THE RECORDER PREPARES TO RECORD THEN AFTER ONE MINUTE IT STOPS RECORDING . I OPEN & RECLOSE THE TRAY & THE RCA RECORDER SAYS BAD DISC.
Some DVD players need to format the DVD+/- R disc before it can be used to record on this is a bit strange as its a WORM (write once read many) disc this is usually what happens with DVD+/- RW media.
If the DVD recorder doesn't finalize (the process that makes it compatible with other players) the DVD+/- R correctly then is will be rendered useless, another coaster for you to use with you cuppa.
I suggest that you use DVD+/- RW media that doesn't need finalizing at least until you can sort out your problem.
WRT your problem with it only recording for a short while it might be that the DVD stops spinning you might need to take the cover off and check this.
Jan 07, 2010 | RCA DRC8052N DVD Recorder
Recording Fall, Invalid disk
Try using Sony +R discs. or +RW's are good, any brand as long as they are +'s. For some reason alot of +R discs brands will not work, I wait and just get Sony +R or the +RW's on sale and stock up and I have no more troubles. Mine is the 05MU. The ZU is a little strange with the RW but will still record. Hope this helps.
Sep 24, 2008 | iLO DVD Recorder DVDR05
RCA CD recorder/player CDRW120
You sure it's recognizing the CDR? And you are using 'consumer audio' cdr? Watch it at all times. If it 'opc fails' after you put a blank in it still shows as a CDR and 0:00 on the display but won't record. It's easy to miss.
Nov 02, 2007 | RCA CDRW120 2-Disc CD Recorder
Recording problem
you need to make shure you get the dvd ready i suggest buy a dvdrw but it in the dvd go to the setup page and in there hit disc it will atomaticaly prepare the dvd cause you cant just put a dvd in and record it needs to prepare (open the disc) also if you are going to watch the recording on another machine after recording you need to finalise the dvd when they ask you to or it will only work on the rca machine
Sep 29, 2007 | RCA DRC8052N DVD Recorder
Philips CDR796 2-Disc CD Recorder Logo
153 people viewed this question
Top Philips Audio Players & Recorders Experts
 Grubhead
Grubhead
Ekse
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
