Question about Olympus SP-550 UZ Digital Camera
ZOOM ERROR An error message "ZOOM ERROR" is displayed when switched on . Their is an sound from the zoom gears . unable to Zoom in or Out. It was drop down from 3ft height. I think an error with the cambarrel, shutter.... Any solutions or the cost of this spares.???? Camera dropped and has a very slight dent near batteries. LCD displays 'Zoom error' and shuts down. Any help?
    Master:
  • 788 Answers
Did you take it apart to look at the mechanism? Definitely sounds like something is broken or out of place.
KEH.com is a well known repair house that may be able to give you a good estimate.
It would help if you had a look to try to determine what is broken.
Good Luck!
Posted on Apr 04, 2008
    Genius:
  • 1,665 Answers
  • 3,037 Answers
The spare parts won't be so much, if you try and fix it yourself, you will save a ton of money otherwise it could be around $100 to send it in and get it fixed. You can start finding the problem by opening the screws on the bottom/back of the camera and find what gears are jammed and won't zoom. or I can get you a number to call to send it in, thanks
Let me know what you want to do
Fix zoom error
The lens probably has some dirt or pocket fuzz caught in it. Try spraying around it with a can of compressed air when it is extended. Also spray the lens.
Oct 05, 2017 | Fuji FinePix S2000hd Digital Camera
Fuji Zoom Error Message
Here is someone selling the full service repair manual for the a500 for 5$. I coultn't find it anywhere online for donwload but I will keep looking...
Dec 19, 2007 | Fuji FinePix A500 Digital Camera
I dropped it and it says zoom error
Sounds like the power zoom assembly (motor, gears, etc), has jammed due to the drop. That and possible electronic problems on the controller board or possibly the zoom switch itself suffered damage in the drop also. Try working the zoom switch rapidly , back and forth a few times and see if it frees up. May be a candidate for the repair shop. Sorry for your accident.
Jul 14, 2009 | Fuji FinePix S700 Digital Camera
drop it on the floor from a few feet I did this and now mine works
Aug 02, 2008 | Fuji FinePix A820 Digital Camera
Zooming in.
Your camera jumped out of gear. Open the front metal cover and disassemble all arm working with the main motor gear and try to reposition the red dot on the big gear with the small gear side by side. Presto now your camera is aligned. Place all arms back in order to your new alignment.you got your self a working camera. D: 3403 3404 mean error = some thing is block your lense and stopping the motored gear. For future referance don't drop the camera agian, next time it might be a expensive fix next time around.
Apr 26, 2008 | Olympus ? Stylus 500 Digital Camera
Finepix A400
If the "!ZOOM ERROR" message is displayed on the digital camera, switch the camera off and on again 2 or 3 times.
If this does not clear the error, take the camera to your nearest FUJIFILM Service Station for testing and repairs. Problem may caused by lens zooming gears stuck.
Apr 04, 2008 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Fuji Finepix Z1 Zoom Error
I saw another post in this forum were someone suggest banging it on a table a couple times, not to hard that you'd dent it but a good enough bang. Worked like a charm! I tried the trigger and slide method but while the error message went away the zoom wouldn't focus. Try banging it, it sounds bad but it worked wonders!
Mar 06, 2008 | Fuji FinePix Z1 Digital Camera
ZOOM ERROR
zoom error usually comes from lens off track or bent.. definitely needs repair
Feb 10, 2008 | Olympus SP-550 UZ Digital Camera
Zoom malfunctioning
This sounds like there is debris lodged in the zoom gears. Been to the beach lately? The gears in the zoom mechanism are very small, and even a tiny spec of sand or other debris can jam them up. Alternatively the sensor inside the lens that feeds back the position of the lens to the control circuit may be failing - so the camera thinks the lens has retracted all the way and stops. If the stoppage of the zoom action is abrupt then it is probably debris, if it is a smooth stoppage like the camera is stopping on purpose it is probably a position sensor. Either way the camera will require repair. David Millier Advance Camera Repair
Feb 20, 2007 | Olympus SP-350 Digital Camera
Zoom lens jammed
this is a protection mechanism against further damage when the zoom/lens mechanism is obstructed. It's a very delicate mechanism, and it's not easy or cheap to fix. The gears probably got misaligned or broken when you dropped the camera. You should get a repair estimate, and only if you decide you'd rather trash it try opening it up again. Good luck
Jun 22, 2006 | Samsung Digimax 420 Digital Camera
Olympus SP-550 UZ Digital Camera Logo
403 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
