Question about Lands Phones
Cant connect to web sites tzones web n walk ect.network setup,server not found.says on phone to perform the connection test go to tools help perform test
    Master:
  • 518 Answers
You probably need to contact your Service Provider. They should be able to correct the problem for you.
Hope that helps...
Geno
Posted on Apr 04, 2008
6ya staff
SOURCE:
With google chrome i cannot connect to the internet
If the problem isnt with your fire wall try this. After a little poking around I found that IE and Chrome both use the same type of means to access the internet so, this is what worked for me.
Open IE and on the menu: Tools -> Internet Options
Hit the Connections tab, then hit the LAN Settings button and UNCHECK
"Use a proxy server for your LAN", then OK both windows.
refresh the browser and both Chrome & IE should work.
Mar 18, 2011 | Google Chrome
I have a Sylvania 7"
In getting msg server cannot be found: Possible network (our network) could be down, the server at the site you are trying to reach could be down, or adjustments to your settings for the new network upgrade have not been made yet. You may also check the settings of your browser. If you are using IE you may go to Tools, Internet Options, Connections, Lan Settings and make sure NO boxes have check marks in them.
Try to ping the website by going to RUN, type CMD and click on OK, type in ping name of the website and enter. If error local host cannot be found there is something wrong either with your Internet settings or network adapter.
Mar 10, 2011 | Sylvania G-Netbook
Not able to apply the proxy settings for internet explorer
Open Microsoft Internet Explorer and from the 'Tools' menu select 'Internet Options'. from the 'tools' menu.
Select the 'Connections' tab.
Select 'LAN Settings'. In the 'Proxy server' section select 'Use a proxy server for LAN ..., enter your proxy address, and enter port 8080. 'Bypass proxy server for local addresses' is selected if you are accessing network resources through a intranet. When complete, select OK twice.
NOTE:
After you apply your settings to the web browser test your Internet connection by attempting to access an external Web site such as http://www.google.com. Test more than one Web site. If you are unable to access external Internet resources, verify the spelling of your entries. If spelling is correct, contact your company's helpdesk to find out if there is a problem with the corporate proxy server.
Regards.
Jan 12, 2011 | Microsoft Computers & Internet
How i know the IP address assgined to the print server? once this how can I change it?
According to this site http://www.argecy.com/xtnd100s.html it it supports the use of HP's JetAdmin/Web JetAdmin utility which will allow you to configure the IP address as well as other features.
"Features such as full support for HP JetAdmin/Web JetAdmin"
Utility located here:
http://h20338.www2.hp.com/Hpsub/cache/332262-0-0-225-121.html
That same site also has this information about the ExtendView utility which may help you as well.
TROY LAN Administration Tools
  • ExtendView - 32-bit utility allowing most versatility and functionality available in network printing. Ability to view and configure print servers from unlimited number of views and quick and easy Windows IP address assignment are 2 key benefits. Features such as bulk configuration allow configuration changes for multiple print servers with simple steps. Save and restore feature allows a standard configuration to be saved and later recalled to restore same configuration
  • WebView - web based configuration tool allows complete status and configuration changes simply by typing the print server's IP address into a standard web browser
  • NetworkAlert - specialized Windows printer error utility providing proactive notification of printer problems through the use of SNMP traps
  • ExtendNet Connect - serverless (peer-to-peer) printing for Windows 95/98. Excellent tool for small businesses and remote offices
  • ExtendNet Connect NT - performance enhanced port monitor helps to improve the speed of data flow to the printer
Dec 22, 2010 | Troy ExtendNet 100s Print Server
Tmobile mms settings for lg kf900 prada 2
i got this from here
From the home screen go to Menu, Settings, Connectivity, Network, Network Profile, Data Connections, New Profile. Fill in the spaces as follows.
Bearer: GPRS
APN: wap.voicestream.com
User ID: Leave Blank
Password: Leave Blank
Primary Server: 216.155.165.050
Secondary Server: Blank or all zeroes
Now from the home screen go to Menu, Browser, Settings, Network Profile, New Profile. Fill in the spaces as follows.
Homepage: http://wap.myvoicestream.com
Proxy: On
IP Address: 216.155.165.050
Port: 8080
Access Point: Select the Tzones profile you've created in the last step.
Now click Save. It should return you to the previous screen with the heading Network Profile. Select options using the proper softkey and select activate. There should now be a checkmark next to Tzones.
To make sure your settings are correct so far, use the browser's homepage to test that the settings have taken effect. You should see T-Zones homepage as you would on any standard T-Mobile phone. If it does not work, double check your settings and shutdown and restart your phone and try your browser again.
For some reason I could not get our phones to work without setting up the browser as well, which is why I've included this step. Now on to the final step.
From the home page select, Menu, Messaging, Settings, Multimedia Message, Network Profile, Add. Enter the following information.
Profile Name: Picture Messaging
MMSC: http://mms.msg.eng.t-mobile.com/mms/wapenc
Internet Mode: WAP
Proxy IP: 216.155.165.050
Proxy Port: 8080
Connection: Select Tzones
Click save and return to the Network Profile in the same menu. Select Picture Messaging to activate it. There should now be a checkmark next to Picture Messaging. Now send a test text. If it does not go through, shutdown and restart your phone and try again. Once operational, you will have a phone that can use all major functions on the T-Mobile network including picture messaging, web browsing, and should also allow downloading of ringtones.
Dec 02, 2009 | Cell Phones
The computer im on keeps blocking everything i go on and i cant find no web sites that is unblocked, can u give me a web site or something
Can you get onto www.google.com
If you can't then there is something wrong with your connection to your ISP.
Ring your ISP to get them to test the connection to your modem.
Nov 02, 2009 | Black Box IP Address Translator With...
Connect ps3 to laptop via web and walk
Connecting PS3 to a network I have LinkSys wireless router which is working perfectly for other devices (like laptop, Xbox360, TiVO). My wireless network is configured to NOT broadcast the SID and with a WEP key. After entering this manually in the network setup on my PS3, I was able to obtain an ip address from my router, I was able to open the configureation page on my router, but connecting to the internet would fail with some kind of DNS error. The way this was resolved for me, was to enter the DNS server addresses manually in the PS3 network settings AND use tetertiary DNS server from my ISP as either the primary or the secondary DNS server. ..btw, this also fixed the similar problem I had with my PSP.. Thanks!
Jul 29, 2009 | Sony Computers & Internet
Cant configre printer sharing via web on win server 2003
Yes is possible. Use Routing and Remote Access facility from Windows 2003 server to create a VPN Server. Create a VPN connection to Windows server, and thus you get an IP address from windows 2003 server and you can use printer.
Jul 07, 2009 | Microsoft Windows Server 2003 R2...
My iphone will not connect to tmobiles web site
go into Settings > General.
Then go to Network and then Cellular Data Network.
–Change the APN to: epc.tmobile.com
(if this does not work, you may need: wap.voicestream.com this is the older APN for tzones and works for certain areas only)
–Also be sure that “Data Roaming” is enabled from the Network screen.
Apr 23, 2009 | Apple iPhone Smartphone
Rocada xphone using tmobile cannot receive tzones or video/audio
good news i can solve this problem. this is what you do. ready? first call tmobile (611) when you reach a customer rep ask for (data support). from there tell them what kind of phone you have and tell them you need them to send tmobile settings to your phone they may do it or they may redirect you either way your on your way. then once they do that download the settings on your xphone when that is done go to your tzone profile on your xphone and change (http) to (wap) and then you should be able to access tzone. this work for me and i have tzone on my rocada gold xphone. now they may tell you they have multipal settings so if the first dont work tell them to send another one. there you have tzone on aw rocada xphone.
Dec 01, 2008 | Nokia 1600 Cellular Phone
Lands Phones Logo
46 people viewed this question
Top Lands Phones Experts
Ekse
Marvin
Marvin
Are you a Lands Phone Expert? Answer questions, earn points and help others
