When I turn my tv on it turns off after 5 seconds then comes back on and keeps repeating this what is the problem?
  • 4,234 Answers
There can be many causes of this. Can you provide a make and model please? That will allow me to give you some ideas. Each manufacturer has slightly different designs. Also, many provide a blink code when a problem is detected. Please count the standby blinks when this occurs (if it follows the pattern of count,pause,count...)
Posted on Apr 04, 2008
I have a Samsung Plasma PN63A650 that has worked 4 8 years, until today. I turned it on, stays on for 14 seconds, then turns off for 8 seconds. Would not respond to remote commands either
Easy fix for new Samsung TV switching on and off power ...
? 4:41
Sep 15, 2012 - Uploaded by alwaysafix
My tv turns on and off by itself the minute I plug in the cable. ....Samsung E6030 led tv hv blinkin red light issue ... capacitors are looking good ...
Help PLEASE! Samsung Plasma Turning On/Off Repeatedly. > Topics
247Sports.comMy Samsung Plasma HDTV (approx 3.5years old) has some issues as of late. When Iturn the tv on, invariably, it starts to turn off and back on repeatedly.
Samsung Smart TV turning off - Forums - CNET > Forums > Samsung
CNETJun 11, 2015 - I have a Samsung plasma 60 inch model number PN60E6500EFXZA TV. It began to turn itself off every 5 minutes, for the past few days. I was able to factory ... Samsung TV Keeps turning off and on.
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
Samsung Plasma TV turns off by itself
Jun 22, 2011
My Samsung 50 in PN50B650 turns off by itself then on again ...
Apr 30, 2010
More results from
Jan 13, 2016 | Samsung Televison & Video
The TV turns on but cannot find a signal (as has been normal when swictching to HDMI inputs). Usually it takes a second and the Cable or FIOS signal shows on screen. As of today, the images never comes...
Tries tv and cables boxes uplug,replug it back like about an hour later for the tv resetting itself back to the factory setting and those pay boxes updated it softwares.Take the HDMI cable plug it in into another tv HDMI hub.Tv should have signal and work again.
Feb 17, 2011 | InFocus ScreenPlay 61" Rear Projection...
My Samsung LCD TV (40A450) 40 inch, when switch turn on after 2-5 second it turn off, no red light. when i remote to switch on then the red light is on and then press on again the lcd tv on after 2-5...
The capitors on the back might be bad this I have fixed on these tv's many times. That could be one of the problems and the capitors are on the power board inside the tv. If you do not know how to work on electronics I would have a pro do it they contain hight voltage so be careful if you try to fix it yourself.thanks
Oct 06, 2010 | Samsung LA40A450 40 in. LCD TV
Tv turns itself off
do the self test the set has.
when green light (power) comes on and then goes off, press and hold BOTH the Menu and Input buttons for at least 5 seconds and release both buttons on the front of the set.
The power light will display a error code: for example 2 blinks, a pause and 2 blinks (this is the most common one) and it will repeat the code about 5 times.
To get it to repeat it you have to unplug set, plug it back in and turn it one and when it fails repeat the check.
Let me know what error code you find and I will tell you what may be wrong. I hope it is 2,2 as it is the least difficult to resolve.
Jun 16, 2010 | Mitsubishi WS-55809 55" Rear Projection...
I need help to reprogram this remote. The
Hello, I am sorry i did not get back to you sooner!
I found the manual on the internet, you can just copy and paste into your browser to download a copy for yourself if you like.
Here is the simple way of doing it:
0) Turn on TV.
1) Press and hold the TV button, light lights up, continue to hold.
2) Press and hold the power button, light turns off, keep holding both buttons down until light comes back on, release both buttons, light stays on.
3) Point remote towards TV the entire time you are programming.
4) Press and release play button, wait 5 seconds, if TV did not turn off press and release play button again wait 5 seconds. Repeat until TV turns off. (When your TV turns off, it was in the last 10 codes sent).
5) Press and release Reverse button, wait 2 seconds, repeat until TV turns back on.
6) Once the TV turns back on press and release Stop button.
7) Your Remote is now programed! Test it by pressing the power button, volume, mute etc..
Apr 27, 2010 | RCA RCR-4258 Remote Control
Picture & sound go on & off every sec, red light blinks 5 times
helloFive blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
Oct 25, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
Tv tunrns on then goes to stand by flashes 4 times & repeats
turn tv on picture comes up 2to3 seconds later tv blacks out then stand by red light flashes 4 times in a row repeatedly..can not turn on or off when stand by light starts flashing but before tv blacks out you can turn tv on and off repeatedly and picture and sound work.You have to unplug power cord for 30 seconds after stand by light comes on to get tv to turn on.
Mar 13, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Beeps when turned on then power light blinks 5 times
sound like the b+ line is not getting the voltage call a tv repair tech.
Feb 15, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
