Can I simply replace Honeywell 24 hour wireless CM61 with CMT927 on wall with no other work?
  • 86 Answers
1.u can
Posted on Apr 05, 2008
Failure of my Honeywell CM61ng wireless thermostat. Replacement advice
Probably not. There are replacement models available.
The T6661B programmable room thermostat is also known as CM61.
CM61 1 day wireless programmable thermostat is replaced by CM921.
CM61 1 day wired programmable thermostat is replaced by CM901.
Oct 21, 2017 | Heating & Cooling
My timer is set to shut off at a certain time of day, and I want to turn the timer off, but I can't figure out how to do it. Can you send instructions on how to turn the timer off?
Honeywell product is not identified.
More information is needed to identify product. Add a comment with as much information as possible, to help expert locate correct information.
For example Honeywell makes timer controls for boiler and heat-ac units.
Honeywell also makes Aube brand wall and box timers for lights and pumps.
http://waterheatertimer.org/Aube-timers.html
Honeywell has a contact-us page:
https://honeywell.com/Pages/contact-us.aspx
Aug 30, 2011 | Honeywell 24-hour Timer Control 120v Spdt...
My wireless control is not working my heating is there a reset button for honeywell cm61?
Here is a tip that tells you how to get a manual for most any Honeywell productonline...
Manual Honeywell How to Find Honeywell Manuals
heatman101
Oct 12, 2010 | Heating & Cooling
I have a Honeywell Chronotherm III Thermostat and in instead of showing the temparature in the display it shows -AC. I've replaced the batteries, and tryied adjusting Temp up and down for cooling and...
It would appear to me that you have lost the 24 volt power supply to the thermostat. In referencing the manuals for this thermostat, available @ www.honeywell.com, I've found that when the thermostat is not connected to the wall plate (plate mounted on the wall, that the thermostat either snaps or screws into), it will display the -AC. This being said, either the thermostat is loose on the wall currently, or your 24 volt transformer has died. Hope this helps.
Dec 23, 2009 | Honeywell Power Humidifier: Furnace...
Remote not workin
what's happened here is the cm61 ng and the reciver box have lost there connection you will have to "rebind" them then it will be fine -
THE BINDING OPERATION DESCRIBED BELOW IS REQUIRED IF:
· Any of the system components (room unit or relay box) are replaced
· HC60NG has incorrect or no binding data stored (e.g. when pre-bound system pack components have been mismatched)
· Interference with the RF signal has caused a communication failure
During the binding procedure keep approximately 1m distance between the room unit and the HC60NG
1 Turn off mains supply to HC60NG for 10 seconds. Re-connect supply.
2 Press and hold the HC60NG push button for 15 seconds to reset previously stored data. The red LED will start to flash at 0.1 s on/0.9 s off. Release the push button.
3 Press and hold the HC60NG push button for 5 seconds to enter the binding mode. Red LED flashing at 0.5 s on/0.5 off confirms the binding mode has been entered.
4 Move the CM67NG slider to the OFF position (CM61 push the OFF button) and press the TEMP , TEMP and PROG 1 buttons together. The CM61/67NG will display InSt.
5 Press the i button to send the binding signal. The red LED is switched off on the receiver box to confirm the successful binding operation. If the red light still flashes push the repeat steps 1-3 and press the the i button until binding is successful.
hope this is helpful
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Red LED on honeywell r6660d
The problem is that the 2 units are "not speaking to each other". this could be caused by low batteries or a loss in signal caused by a powercut or an objection in the way of the 2 units.
first you need to turn the power off to the r666od (or otherwise known as the HC60NG) for 10 secs, then turn back on. then hold the grey button in for 15 secs. release then hold in for a further 5 secs.
go to the honeywell cm61 press the off button. hold temp up. temp down and prog 1 in for 3 secs until the dipslay goes to INST. at this point release all 3 buttons then press the i button until a beacon starts flashing.
this is now the end to your problem.
N.B the reason the green light was on is because the man override button will have been pressed.
hope this helps
Nov 14, 2008 | Honeywell Programmable Thermostat Heater
Replacement of heating programmer
yea you should be able to just when you remove the old one mark witch wire went to witch connection by marking it some how i personaly take one wire at a time wrap it with a small piece of white tape and write the letters on the piece of tape then when i replace with the new one i cant mess it up also look for any of the wire connections to see if any have to be or have been jumped out
Nov 14, 2008 | Honeywell Water Heaters
Radiators cold when thermo says otherwise !
First, check to see if the battery in the stat is good. If you can move the manual temp up and down...causing the relay to click on and off, the unit ought to work. If not the battery is bad or the stat is. IF THE UNIT IS ON 110V, you can't do the following:
If this is a two wire connection, simply short them out. If the heat comes on, the stat is bad. If not, the relay package is likely defective. You may want to get help from someone who knows electrical items.
Nov 12, 2008 | Honeywell Programmable Thermostat Heater
Central heating thermostat
Looks like it was replaced by the CM67 series, try this link for the manual:
http://www51.honeywell.com/pacific/common/documents/CM67_User.pdf
Geno
Feb 29, 2008 | Honeywell Programmable Thermostat Heater
Honeywell cm61 controller
Turn off ‘Optimum Start’
Step 1 Put the thermostat in the OFF position.
Step 2 Press 3 buttons together (at the same time) which are the INFORMATION BUTTON (i) and PROGRAM BUTTONS 3 & 4.
This will show a code of ICL 1 – now let go of the buttons.
Step 3 Press PROGRAM BUTTON 2.
This will now show a code of 30t 1
Step 4 Press the + BUTTON (on the left of the display), tap through until you reach 15 OP 1
Step 5 With the TEMPERATURE DOWN BUTTON; change the 01 to a FLASHING 0. Confirm the FLASHING 0 with the INFORMATION BUTTON ( i ). The 0 will now be static.
Step 6 Put the Thermostat back in the ‘AUTO’ position.
‘OPTIMUM START’ is now switched off.
Dec 23, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
239 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
