Question about D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE)
Can't find printer connected to DI-624s USB port
Workgroup name is HOME for printer and all computers and laptops, but I can't seem to find out how to find the printer and print.
Have you tried:
(1) add a printer
(2) click Next when the Add a Printer wizard is displayed
(3) select Local printer attached to this computer. Untick automatically detect and install my Plug and Play printer; click Next
(4) select Create a new port - Standard TCP/IP Port. Select your printer driver.
(5) enter IP address of printer: 192.168.0.1; accept default port name; click Next
(6) select Custom, then click Settings
(7) select LPR protocol; enter 'lp1' in LPR settings
(8) click Finish
Hope this helps! :)
Posted on Apr 26, 2008
6ya staff
SOURCE:
How do I setup/install a printer on the DI-524UP?
Here I find your printer is not a network printer hence directly accessing is not possible . You need to configure the printer to one of the PC and share the printer access rights . Then take a another PC and search for the computer name ed : \\resdc
When you find the PC double click and you shall find the printer .Click on thee printer and connect.
Dec 30, 2009 | D-Link AirPlusG DI-524UP Wireless Router
I am trying to setup up a D-Link DES-1016D, 10/100 Fast Ethernet Switch to allow 5 laptops to connect, 1 cat 5 is connected to another switch that will provide these 5 laptops internet how can i do this? I...
The Simplest Way of doing this is this:
You will need just 1 switch and 5 Straight-Through cables.
(This is Provided that your laptop will connect to the internet through another method. e.g (Though a USB Modem or WIFI) ).
Connect the Main laptop to the internet through either a USB Modem or a WIFI.
Next, Connect a straight-through cable to the LAN Port of the laptop, and the other end to one of the ports of the switch.
On the network connections page, right-click on the ethernet adapter, go to TCP/IP, and give the laptop a static IP-Address, e.g 192.168.0.1 and Subnet 255.255.255.0
For the other laptops, connect each one of them to the switch using the straight-through cables, and on their ethernet adapter TCP/IP Properties, give them different IP Adresses, but in the same subnet. e.g
192.168.0.2 and 255.255.255.0 for the 1st one
192.168.0.3 and 255.255.255.0 for the 2nd one
192.168.0.4 and 255.255.255.0 for the 3rd one, ....and so on.
Next, in the default gateway for these other laptops, put the IP-Address of the First laptop that is connected to the internet. i.e 192.168.0.1.
Also repeat the same IP Address of the 1st laptop in the Preferred DNS Server for these other ones.
Next, setup home or office network on all of them,
follow on-screen instructions and when you get to the place where you have to select the type of network setup, Just select :
"This computer connects directly to the internet........" for the 1st laptop,
For the others, select : " This Computer Connect through a residential gateway or other computer on my network.".
Then give them all the same workgroup name, and accept file and printer sharing for all of them.
In case you are using Windows Vista.
The only different things include:
When you get to the TCP/IP Place, select TCP/IPv4 and Not TCP/IPv6.
Also, When you are changing the workgroup, all you need to do is to right-click on My Computer Icon, then Properties then go to Advanced, then Select Computer Name, and change the workgroup from there and restart the computer.
What I have told you is a typical, very easy network setup, and I do hope it helps you out.
Keep me posted about the problem.
Hope it helps you out.
Good luck
Nov 20, 2009 | D-Link DES 1016D (DES-1016D) 16x10/100...
How to get the router to work.... i have a desktop and a laptop and the desktop has internet .....but how do i get the laptop connected to the internet using the router
Connect your internet connection to the port on the router
then connect your laptop and desktop to the router.
if you have a user name and password enter these in the router settings
everything should work
Oct 07, 2009 | D-Link AirPlus Xtreme G DI-624S Wireless...
File sharing isn't happening
You need to go to control panel and into system, Click on teh Computer name tab and give each computer it's own name if it doesn't have one already. Then click on the change button and give your workgroup a name. Make all computers part of the same workgroup.
Oct 04, 2009 | Dynex 5 Port 10/100 Ethernet Switch...
Printing with Dlink DI-624S and VPN connection
I am guessing this VPN is something work related and not a VPN you setup yourself?? If that is the case your company's VPN access will not allow you to pass from there network back to yours which is why you are unable to print to your local home printer when connected to VPN. You might could run it by your IT staff and see if they will allow connection and help you set it up. If not then simply email the docs to yourself and then print them out after you are finished using VPN connection.
Hope this Helps
TankMurdock
Jan 24, 2009 | D-Link AirPlus Xtreme G DI-624 Wireless...
Windows networking issue
all computers must have same workgroup name and diffrent descriptions and names. try to use set up home and small office network in every computer. its located under control panel network connections if u put there all the same workgroup names and diffrent descriptions and comupter names
Jan 21, 2009 | Learn.com Windows XP Networking Tutorial...
Wep?
If your router has security you have to enter the security key on the laptop for it to connect properly.
Jul 26, 2008 | D-Link AirPlus Xtreme G DI-624S Wireless...
Using DI-624S ... VPN works fine through CAT5 but not wireless
I resolved my issue by updating the DI-624s firmware.
regards,
boreeeeec
Jun 09, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
DI-624s
That sucks... we need more info before we can try to help though.
Sep 09, 2007 | D-Link AirPlus Xtreme G DI-624S Wireless...
D-Link AirPlus Xtreme G DI-624 Wireless Router (DI624RE) Logo
585 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
