Question about Sony DSR-45P DV / Mini DV VCR
Get a C:31:30 Error Code
Hey,
When ever I try to play or record a tape, I keep getting this error code and then the machine shuts down.
Any suggestions?
  • 53 Answers
C 31:30 IS FG fault when starting capstan.
Posted on Jan 14, 2009
  • 4,234 Answers
This is an indication of a motor failure. There are a number of sensors inside that watch for tape movement. If any of them fail, the machine shuts down to prevent damage to the tape or the machine. This is a relatively simple repair, but will require an alignment. This unit should be brought to an authorized Sony service center.
Posted on Apr 04, 2008
Error 0507
see the cause and fix it:
1 alternative for playing DVD:
  1. No disc. - Load a disc into the tray.
  2. Disc has been loaded upside down. Place the disc with the label side up.
  3. Disc region code does not match region code of the player.
  4. Disc type is not the correct type to play.
  5. Disc is damaged or dirty. Clean the disc or try another.
  6. Moisture may be condensed inside the unit. Remove the disc and the leave the power on for one or two hours.
2ND ALTERNATIVE: FOR VHS RECORDING:
play the VHS TAPE CLEANING , FOR clean the sensors, rollers, drum etc.
b) Try it.
c)Otherwise you must go to the repair shop TV for fix it.
God bless you
Jul 21, 2012 | Samsung VR-325 DVD Recorder / VCR Combo
URGENT NEED HELP WITH C:31:23 CODE ON DISPLAY SCREEN
Try first removing the battery and see if this clears the error.
Aug 24, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Error Code C:31:00 in a Sony CCD-TRV75 Handycam Camcorder
    This error shows that the problem is in mechanical section of the tape loading path. Please contact an expert for mechanical adjustment
 Thanks for using fixya.
May 21, 2009 | Sony Handycam CCD-TRV75 Camcorder
ERROR CODES E24 ~& E4 54037380 ON MY DVD RECORDER, CAN ANYONE TELL ME WHAT THESE MEAN, THANKS
If you are trying to record vhs tapes to the dvr side, first you need to get 1x up to 8x DVD-R dvds. You can find them on ebay. The machine has problems recognizing the up to 16x type. Put the blank DVD in and let it load. Then start playing (not dubbing but playing) the videotape for at least 6-8 seconds. If you have somewhat of a lead-in on the videotape you can let it go even 10 seconds. Only after the videotape has been playing for this period of time, press the dubbing button. If the error code does come up, rewind the tape and start again, but in most cases the error code will not happen if you do it like this.
Mar 31, 2008 | Sylvania SRD3900 DVD Player/VCR
F08 Error message, keeps shutting down
Get it to a shop. The error is a drum servo related problem. Don't force the mechanism or you'll be out even more...accordianman
Feb 15, 2008 | Panasonic AG-DV2700 Mini DV VCR
Sony error code
cheak batteries and the tape your using
Feb 03, 2008 | Sony Handycam DCR-DVD305 DVD Camcorder
Error Code EO3 System in Safeguard Mode
Defective mechanism, 03 error states that a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera.
Aug 16, 2007 | JVC 580136 Camcorder
Stops during rec, error code E - 5 in display
E-5 is a "reel lock" error. This means that one or both of the reels that move the tape through the deck have stopped turning and are not sending a feedback signal to the system control cpu. This deck does use a drive belt, and has a clutch mechanism to transmit power to the reels. Check the belt and clutch for wear (the belt has a tensioner; the tension screw may be loose.).
Aug 05, 2007 | Panasonic AG-TL500 VHS VCR
E04 Error Can't watch or play
Hi there, please check this link: http://www.planetdvd.net/board/index.php/m/131342/0/#msg_131342 Best regards, Arpi
Jun 08, 2007 | JVC Cybercam GR-DVL820 Mini DV Digital...
Trying to Copy Home VCR tape and keep getting copyright message.
Try replacing the tab on the VCR tape-which may have been removed to prevent VCR eraure [?]
Aug 27, 2006 | Toshiba D-VR4 DVD Recorder/VCR
Televison & Video Logo
737 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
