Question about Gateway GTW-P42M303 42 in. Plasma Television
Black Line through screen
Dave,
Saw your post on fixya.com and was hoping you could provide me with the necessary steps or information I need to get rid of that black line through my Gateway flat screen. My email is [email protected] I don't think I can watch another baseball game w/ that line cutting the screen in two!!!! Thanks...
Bob
  • bobcoach55 Apr 04, 2008
    Dan,
    I never figured out how to fully remove the flat ribbon cable connectors but I did clear the connectors of dust and clean the connections as best I could, all to no avail.
    So once I got it put back together, I tried a previous solution's suggestion and gave the TV a good whack and for a short while it actually worked. The line disappeared for a few minutes but it eventually did come back, so I whacked it again, and it went away for a few more minutes, but now it's back again and it's not going away at all. I whacked it, smacked it, gave it an elbow... the line's still there.
    I'm open to other suggestions, but at this point, I'm thinking it needs professional attention. Thanks for your help...
    Genius:
  • 3,422 Answers
This is a serious problem. It may be a design problem or a defect in the video processing. Since it is temperature related..... or digital error buildup of some kind - it is not an easy one to diagnose without some hands-on observations and measurements.
A tech - at Gateway warranty or elsewhere - will have to put on an oscilliscope and trace through the circuits and find out where the vertical bar is being introduced. These sets are grossly complicated from a circuits point of view with several IC chips that make it difficult to troubleshoot. If Gateway warranty gets to it, they may replace the main board or the display driver or whatever is producing the malfunction.
But, I believe strongly it is a manufacturers warranty problem and they should be held to it. Make sure they realize it has been going on for before the warranty expired and you have not been able to get their attention.
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Check the line cord. Wiggle both ends near the molded part.
TWO:Do a hard reset by unpluging all the cords for 4hrs and then plug it back.
THREE:The whacking test is to just bang or smack the set with your hand on the back, side, top, etc., to see if there are loose connections or cold solder joints inside that are acting up. If so, the banging should knock them back to normal and the set should restore. You might have to use some creative banging and some have had to put a book or magazine under one corner to torque the chassis enough to get it to work reliably.
If the problem still persists then like i said before,you will have to get it repaired by a technician.
Goodluck,
Please don't forget to rate the solution
Posted on Apr 04, 2008
  • 4,234 Answers
Typically, black line through a panel can be caused by poor connections at the panel itself. If this unit is no longer under warranty, carefully open up the back and reseat all of the cables and connectors. Any dust/dirt in any of the connections can casue this. Also, I have seen some of the flat ribbon cable connectors loosen up. Carefully open each connector. remove the cable and re-insert. Then snap the connector closed again. Let us know if this does not resolve the problem. It is possible that the internal signal processing can cause this as well, but that is more rare.
Dan
  • ABRsvcs Apr 05, 2008
    Since the panel is addressed as a two way grid, a small addressing error can result in a display like this. The fact that a "whack" appeared to clear it for while reinforces the thought that it is a connection issue not a logic one. Try calling a local service shop and ask how much to reseat all of the connectors. That is still the most likely problem area.
    Dan
SOURCE:
Looking for a front and rear locking fence for this table saw also owners manual,any help would be appreciated.THANKS BOB
Please go to this link where you will find a list of available parts and a downloadable instruction manual for your saw.It looks like the fence assembly is still available, but I recommend you review the exploded parts diagram and compare the numbers found there to the parts list to confirm that you have ordered all necessary parts before shipping.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 20, 2011 | Black & Decker BDTS200 15-Amp Table Saw...
Reolacing door springs
Most dishwashers share the basic design either between models or between brands. There are even cases of the same model being sold under different brand names. Below are two (2) common door assembly diagrams with parts placement. Please check which closely resembles that of your unit.
This image was originally posted here.
This was originally posted here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 28, 2008 | Dishwashers
Guide rail assembly [email protected]
Hello, Welcome to FixYa. I just saw your post while following up on another clients Asko, sorry you've had to wait a couple of days but I can help now. I'm presently on my iphone as it is the only internet service I have for now, and I cannot post images through this device, however if you copy & paste the address I provided here it will direct you to a post of mine that will guide you step by step fairly thoroughly on "how to". http://www.fixya.com/support/t6589773-replace_rail_replacements_in Regards, Macmarkus :)
Nov 14, 2010 | Asko 1385 Dishwasher
Roper Washing Machine Repair
I believe Roper washers are manufactured by Whirlpool. The following link should provide you with the necessary steps in removing the washer casing, so you can access the pump:
http://www.fixya.com/support/r397092-replacing_water_pump
If this information is not correct, or if you require additional assistance, please let me know. I hope this helps you.
Jan 11, 2009 | Roper RAX4233PQ Top Load Washer
Black verticle line on screen of zenith p42w34
I'm sorry you have not been given a clear answer on how to repair your TV. I know how to fix the problem you are having (1.5 inch Black vertical lines that come and go) If you still need help fixing your Plasma TV please feel free to message me @ [email protected] or just give me a call @ 1-503-432-9904 and I'll help you fix your TV buddy! Ask for Dave! If your reading this post and you have a plasma or LCD type TV and need any type of help please feel free to give me a ring or message me with the problem your having. I'll do my best to help you!
Talk to you later!
Dave :-)
Nov 30, 2008 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
F06 whirlpool duet error
"F06" is a motor speed error. The following link explains:
http://www.fixya.com/support/r714929-f06_error_whirlpool_duet_kenmore_elite
The link provided will give you the necessary steps to diagnose the problem yourself (yes, this a DIY project). All you need is a simple multimeter. I would begin by checking all the wiring to ensure you have nothing loose or broken. Then, I would recommend checking the motor windings. This would potentially rule out the first two possibilities by confirming whether or not the motor and wiring harness are good. That would leave the Motor Control Unit to troubleshoot. More commonly, the MCU fails causing this error. I'm not saying this is your problem, however. You will need to follow the steps provided to rule out all possibilities.
I hope you find this information helpful. Let me know if you require additional assistance.
PS If you do require parts. You can order on line at searspartsdirect.com. Repairclininc.com also carries parts for your washer if you would like to do some comparative shopping. There are other web sources out there, but I have found that these two have good service and are usually the lowest priced.
Nov 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Laptop screen
Based on your description, it would appear that your laptop has a defective LCD display screen. This is normally replaceable. In some instances, it could just be a loose connection on the LCD interface/board.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 10, 2008 | Computers & Internet
Why did my HP Pavilion ze2000 screen go black?
john79:
I know that you had a chat about this matter, and I hope that your issue was solved. However, I had made a note of it when I saw the chat go through. I was unable to help at that time, but remembered having seen something of this nature and wanted to follow through on it.
Although the ze2000 is not listed, other 2000 models are listed in the following link as defective - and recognized as such by HP - with this very specific defect. (Please see http://h10025.www1.hp.com/ewfrf/wc/fastFaqLiteDocument?lc=en&dlc=en&cc=us&product=18703&docname=c01087194.)
Again, if your issue has already been solved, congratulations. Otherwise, I hope that the information provided here will be of use to you, either in fixing the equipment problem yourself (perhaps with a BIOS update) or by convincing HP to do something about it. At least you would be armed with good solid documentation of their recognized issue!
If this information assists you in resolving the problem, please take a moment to rate the solution at a "FixYa" level. If you do not feel that you can rate at a "FixYa", please post back with more information regarding what has occurred subsequently and/or more details regarding the situation, and I will gladly help you until we have reached a definitive solution. Thank you for using and rating FixYa!
Sep 17, 2008 | HP Pavilion ze2000 Notebook
Whirlpool duet washer
Assuming that your model number is correct, searspartsdirect.com has the pump for a reasonable price. Just type in your COMPLETE model number in the Search menu and you can locate the pump under the "Pump and Motor Parts" heading as item number 10 (part #8181684). If you need assistance in how to replace the pump, click on the following link for step-by-step instructions:
http://www.fixya.com/support/r401841-replacing_kenmore_elite_water_pump
If you do not wish to order the part on line, take the part number provided, and go to your nearest applaince repair retailer. I hope you find this information helpful. Please post back if you need further assistance.
May 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Multi zoning of DVD player Tobishi 4500
Try this:
http://www.dvdunlocker.com/
Hope that helps!
If your issue is not resolved, please do not assign a rating just yet. Please post back as to what steps you took, results, etc, and I will try to assist you further as best I can. I am here at your service.
P.S. - You can rate a solution with one of four ratings as explained under (remember that at times a bit of to and fro dialogue may be necessary to resolve an issue).
  • "FixYa!" - The solution provides great advice on how to solve the problem.
  • "Helpful" - The solution provides useful leads that helps solve the problem.
  • "Thanks for Trying" - The solution does not solve the problem but the effort is appreciated.
  • "Inappropriate" - The solution has absolutely nothing to do with the problem.
Thank you for using FIXYA!
IrishDruid
May 07, 2008 | Televison & Video
Gateway GTW-P42M303 42 in. Plasma Television Logo
60 people viewed this question
Top Gateway Televison & Video Experts
Ronald
Level 1 Expert
Jerry Greenberg
Jerry Greenberg
Are you a Gateway Televison and Video Expert? Answer questions, earn points and help others
