Question about Bosch Exxcel WFO 2264 Front Load Washer
Very loud noise BUt washes fine
Half way through a cycle it will make a very loud and annoying buzzing/vibration , the spin used to be pretty quiet but is considerably louder aswell
  • Anonymous Apr 05, 2008
    have same problem washes fine but half way through rinse cycle makes a loud buzzing noise cannot get filter cap off to check if blocked as wont budge and know filter cap is broke as tried with pliers,any suggestion as can get to filter without removing cap,
  • neil79 Oct 28, 2008
    I have the same problem, a very loud buzzing at the end of the wash cycle. The machine still washes ok, but seems reluctant to move on the spin cycle. The filter is clean. Luckily all still under warranty, we'll see what the 'Bosch' man has to say. Keep you posted.
  • 43 Answers
Could be wheel on back of drum check its not loose , only way to get to filter is to remove the pump from filter assembly lay it on the soap draw side to get to it easier
Posted on Nov 11, 2008
Why do i have loud noises coming from my washing machine only whilst it spins
The bearing in the drum has failed and it's always noiier as it spins faster as there is more debris being thrown around inside the hardened steel casing of the bearing. Bad news is that's a write off. Uneconomical repair. It will tear its self apart shortly, probably leaking grease into the wash and leaving black marks everywhere, oor the drive belt will come off, or the drum will impact the front gasket and fill the drum with smoke. Any way you look at it, it's almost certainly going to destroy a load of washing. Throw it away now before it wrecks your washing
Aug 21, 2016 | Washing Machines
My washer is 4 years old and the last couple of times I used it, it made a very loud noise when it was in the spin cycle and now it is more quiet but it is not spinning all the water out.
Welcome to FixYa.
Have you checked the pump to insure nothing is in there causing the noise, or do you believe it is coming from the main wash basket ?
I would rule out anything being in the pump first before declaring the main bearings or motor brushes being worn which can sound pretty loud, but usually just in the spin cycle.
I could possibly assist in directing you "how to" if I had a make and model number, or you can refer to your owners manual and that should have instructions on maintaining and cleaning the pump.
Let me know what you find out.
good luck
macmarkus :)
Jul 29, 2010 | Whirlpool Washing Machines
My kenmore HE 2 Plus washing machine makes a loud grinding noise when it enters the pre-wash/wash cycle (worse on this cycle) then continues on through the rest of the cycles. Washer fills, rinses, spins...
Unfortunately, I don't think you will be able to fix this issue, some mechanical parts are breaking. If your appliance still under warranty, you may need to contact the appliance manufacturer for assistance. This kind of repair can be expensive and is difficult enough so a service technician may need to fix it.
Aug 31, 2009 | Kenmore HE2 Plus Front Load Washer
Our Frigidaire Ultra Quiet II dishwasher loud buzzing noise- wash
No longer "ultra quiet" huh?
A sound during certain cycles indicates a broken part. By the information provided sounds like a pump may be the problem. You may need to contact a service tech about this issue. If the appliance still under warranty, the service should be provided for free.
Every time when you hear noises (other than the normal ones) in the appliance, it indicates there is something wrong and it will worsen over time, so as soon you hear something is not ok, get assistance.
Aug 30, 2009 | Frigidaire Dishwashers
I am getting a lot of vibration from my pump
there is a bad bearing inside that has worn out and causes vibration and excess heat, when it frees up it will spin quiet for a little then bind and vibrate again. need to replace bearing.
Jun 20, 2009 | Little Giant 2-MDQX-SC Inline Pump
Spining makes noise and machine vibrates a lot
its a simple solution just remove the brown colour clamp at the bottom of the machine with a screw driver
Jun 03, 2009 | Whirlpool Washing Machines
Loud humming noise when dishwasher is filling up with water
your model is pretty new. just so you know your warrenty is 1 year parts and labor. 2 years on parts. it should not cost that much money.
there are two components that start before the circulation pump.(wash noise you hear)
first sounds you hear will be the drain pump. usually rattling noises if something is in it but it can make a hum noise if something is jamming the drain propeller up. which is accessible with a T20 torx driver. take the filters out and the mesh filter. and unscrew the screw in the base towards the left. pull out whatever is lodged.
the other humming sound can come from the next component that activates is the watervalve. make sure you dont have a kinked water intake line. otherwise its a bad valve. i have had to change a few of those water valves out already but not for a hum noise on your model. you have a new style water valve. when brands make new parts we get problems fast sometimes..
Feb 14, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
My wash spins SO loudly
hiya
sounds like your drum bearings are in need of replacing.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Aug 19, 2008 | Washing Machines
Loud noise during spin cycle
I bought the frigidaire affinity washer. It was quiet until it began the spin cycle, then it sounded like a jet taking off and began to bounce. Come to find out we set it up improperly. You must remove all shipping bolts on the back of the machine and make sure it is level. Ta Da!! it now runs perfectly quiet with little vibration.
May 05, 2008 | Frigidaire GLTF1670A Front Load Washer
Bosch Exxcel WFO 2264 Front Load Washer Logo
510 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
