Question about Maytag EPIC MFW9700S Front Load Washer
Can the way the door opens be switched??
Can you switch the way the door opens on the Maytag MFW9700 washing machine. ours currently opens to the left, Can the door be switched so it opens to the right??
    Genius:
  • 1,073 Answers
No no door lock switch monunting on the other side
a maytag dryer can
Posted on Apr 11, 2008
Girlfriend for some reason put a screwdriver in the door latch of our maytag neptune washer. Tripping the breaker. Got the breaker on. Plugged in washer . code dO . wont start.
The D0 error means the door is open. It is not but the switch is now broken and the machine thinks the door is open. IF you post the model number, I can link you the part.
Dec 06, 2017 | Maytag Washing Machines
Maytag front loader 2000 series code LF followed instructions in manual and has no power. Outlet works
Hi, is this a new washing machine? If not, then these Maytag front loading washing machines use a paraffin locking switch in the front panel to lock the door during operation. Now, if the switch has gone south and trip the the lock switch without locking the door. Then the washing machine want turn on.
What is a parfin locking switch work is a small container with paraffin (wax) in it with a heater. When the washing machine is turn on. The control board indicate that the machine is in operation and a small amount of current is applied to the paraffin switch to the heating element. This make the parfin to expand trip the locking mechanism and locking door during operation. Keep the door lock from accidental openings. It will take about 4 minute after the washing machine has quite it running operation to open the front loader door. The paraffin needs to cool down to release the locking mechanism. stewbison
Aug 20, 2011 | Washing Machines
I stopped my maytag A5000 mid cycle and it would not turn back on i did not open the door so it cant be that switch
Have the machine taken off power for sometime and then switch it on. If the cycle does not reset or shut down to open the door, then manually release the water and open . Now after draining check again with the power on and if the machine does not start up then there are issues with the program controller unit.
check for tips on washing machine :
http://www.espares.co.uk/advice/washing-machines/a/7
Aug 04, 2011 | Maytag Washing Machines
My Maytag top loading washer Won't Spin
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.Here is the part you need.
Jan 06, 2011 | Maytag Legacy MAV208DAWW Top Load Washer
My machine is showing the code FL machine has problems locking. How do I resolve this problem
Your Maytag Neptune Washing Machine displays error codes, also called "help codes," to identify specific problems with your washer. Once you close your Maytag Neptune's door, the machine locks the door, goes through the selected wash cycles and unlocks the door when the laundry is finished. Error codes appear when there are problems with the door, the inflow and drainage of water and the motor.
The "FL" code indicates that the washing machine was unable to lock the door after you closed it. Open and close the door tightly, then restart the washing cycle.
Door lock monitor switch in door lock mechanism unable to communicate to control board the door is locked.
1.Check wire connections in harness leading from machine control board to door lock mechanism.2.Check solenoid and door lock enable switch in door lock mechanism.
3.Replace responsible component.
Dec 07, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have front loader MFW9700 Maytag washer. Water
Check the door seal for tears and the drain boot from tub to drain boot for anything that might have put a hole in like a piece of metal from an under wire bra which front loads will spin so fast that the wires come out of the bras.
Feb 01, 2010 | Maytag EPIC MFW9700S Front Load Washer
Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
May 12, 2009 | Maytag Washing Machines
My maytag top loading washing maching only fills up with water
take the two screws out of back controll panel than jam somthing to hold the door closed switch forward mine did same many times and it is always that switch moved back a little to far you can check by holding open door and push in switch with a pen or somthing
Apr 01, 2009 | Washing Machines
Neptune replace door switch
It sounds like a door switch problem, I have seen where they break loose from mount and door pushes switch inside. or the switch my be faulty and showing open all the time. I think u can reach the switch through the top of the washer two screws in the back will allow the top to slide back and up to remove.
Jan 24, 2009 | Maytag MAH8700A Front Load Washer
Maytag MAH-24 door won't open
If your washer doesn't seem to work at all, check these:
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Apr 26, 2008 | Maytag MAH2400A Front Load Washer
Maytag EPIC MFW9700S Front Load Washer Logo
190 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
