Question about HP iPAQ H4355 Pocket PC
HP Ipaq H4355 PDA charging problem
Hi, I have an Ipaq H4355 PDA that has a strange problem that is driving me crazy. I bought it new but did not use it much due to extensive travelling. It was working great until it ran out of power for lack of use. When I tried to recharge it, it started the HP logo and the meter apearing on the screen indicated that it was starting but it only kept booting and rebooting. The charging led light never turned on after that and the PDA never charged even after long time of connecting it to the AC power source. I talked to HP who advised me to buy a new battery. I did and the PDA worked fine until the battery discharged. When I tried to recharge it the same thing I described above happened and could not charge the machine. It only kept booting and restarting itself indefinately. I can't use my PDA and nothing worked from soft to hard reset. Any advice? I need help. This thing is driving me nuts. Sam
  • HP Master
  • 5,327 Answers
This thing is a relic , how can the battery ever be good this old
2004 new, 13 years ago is not new,
$15 battery buy one, and end this.
is your battery 13 years old. if yes, hopeless it is...
google rules on battery life, wiki has it read, it.
no need to guess this. wiki
here is the link....
https://en.wikipedia.org/wiki/Lithium-ion_battery#Variability
cycles over 3000
run hot, ?
lets cells drop below 2v each bad.
the rules for long life are tricky, and same for all batteries, for a century.
Posted on Mar 31, 2017
  • HP Master
  • 20,706 Answers
HP told you straight up
why ignore them.
buy a battery first.
just like everyone else ever 2 years. or so,... batteries never last
or get so weak they are useless
Posted on Mar 12, 2017
    Habit-Forming:
    New Friend:
  • 23 Answers
Use common sense and frequently charge the battery even when the device is not used.
Draining a battery fully often kills it permanently.
Posted on Mar 11, 2017
4 Suggested Answers
SOURCE:
  • 8 Answers
SOURCE: iPAQ Not Charging from AC Outlet
If you are not using the original chargers it could be the type of charging cable. Not all cables that fit will charge the device correctly.
Posted on Aug 12, 2007
Bogdan
  • 198 Answers
SOURCE: Ipaq 4155 wont turn on, dont charge, dont anything, is totally death
I had some similar experiences with these ipaq's when I was working in a specialised service center. I'll try to give some help or tips through the internet, altrough if i could have seen or diagnosticate these pda's myself it would have been more easier. First of all these problems have 2 main causes. Most of the pda's comply with one of them, it is very rare that a pda will develop this problem by having both causes.
The first cause is the hardware one. A component called the main voltage convertor is broken. It's a small chip that uses the voltage given by the main battery to convert it's value to various tensions required by some of the components on the pda's main board. If some sub-parts of this chip fails to work, the result will appear as the problem you face, In this case there isn't much to do. Most service centers will replace the whole mainboard because that particular chip is very hard to find as a replacement and difficult to desolder from the board.
The second cause could be a major firmware / ROM memory corruption. These things can happen out from nowhere. In my time working for service centers I've tried to isolate a pattern for this problem but without much succes. However it seems that most of these problem tend to appear durring charging cicles due to power spikes or drops on the main AC voltage supplied to the charger. This is only a supposition, I'm not sure yet on this cause. What to do here? Well this problems are fixable but first of all you must be sure that this is a software problem, not a hardware one. So let's diagnosticate some things.
Try to charge the pda. Ignore any lights or beeps or whatever your pda is showing on the screen. As long as the charger is connected the charging process is based on the most primary charging circuits on the pda's motherboard. If the pda is not charging or cannot hold any charge (when you unplug it the screen fades away or it simply doesn't do anything else) maybe that circuit is broken (this is a a sign of serious hardware problems ) or maybe the battery is to old/weak. Batteries don't die out of nowhere, if you remember your pda to work and have some 2-3 hours of standby time it's imposible that now, suddently the battery has drained out so much that even if charged it can't hold out at least 30 min.
So we will assume that you charged the pda for at least 2-3 hours and you see some sign that the battery is working. The next step is crucial. TRY TO PUT THE PDA IN BOOTLOADER MODE. You will achieve this by pressing (and keep them pressed!) the following buttons : power, the far left and right buttons near the control pad (joystick or whatever some people call it) and reset button. You may need another person to help you press these buttons. the order should be the following (first power, then the 2 keys, then reset button for as long as it takes to enter bootloader mode). YOU SHOULD SEE A WHITE SCREEN WITH THE HP LOGO.
If your pda fails to do that, there is nothing more you can do to restore it in a DIY fashion. Probably the bootloader is corrupted or you have a hardware fault. Only a specialised HP service center can help you now. In most cases this will end up with a motherboard replacement.
If your pda does that, then there is a chance to fix it. We will need to probe the bootloader for direct data acces. This is needed for having the ROM memory (and operating system) rewritten. A small program called Mtty will be required to access the bootloader via an usb link.
Please make this tests first and then reply with your results. If anyone of you is in situation #2 there may be a chance.
Posted on Feb 10, 2008
  • 1019 Answers
SOURCE: can't get soft reset screen on Ipaq travel companion rx5915
Try This:-
To perform a factory reset and return your HP iPAQ to factory settings:
1. Press and hold the Quick Launch and Rotate Screen buttons.
2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button. The HP iPAQ restarts and powers on.
Mike @ compurepair.
Posted on Jul 23, 2008
Sync Iphone with outlook
just install itunes and you can sync calendar and contact to your iphone. You cannot sync the notes and tasks but. I have just bought an iphone and before I was using an HP ipaq like you. Everything is synced except for the notes and tasks. You cannot even see any word or excel files you had on your ipaq. Cheers
Aug 21, 2008 | Apple iPhone Smartphone
Can't get soft reset screen on Ipaq travel companion rx5915
Try This:-
Mike @ compurepair.
Jul 23, 2008 | HP iPAQ rx5915
HP Ipaq h5550 does not connect through cradle
First sorry for my bad english.I have a same PDA (acually its dead :-( ) And me too had this problem.Try moving a little bit your pda on cardle, or (this looks like crazy but actually worked for me) do not fully put in the cardle into pda.I mean dont stick in into cardle, just a little bit.
Jun 30, 2008 | HP iPAQ H5550 Pocket PC
PC/PDA "connected" yet PC won't read PDA
Did you tried installing the ActivSync again, for Windows XP the version is 4.5, for Windows Vista is 6.0, Try installing the AS
Feb 02, 2008 | HP iPAQ H3955 Pocket PC
Hp rx1950 battery life.
I have the same problem, after I did the hard reset and installed no programs, this power problem disappeared. But once i installed any programs, PDA battery life became no longer than 2 days, which is strange.
Jan 06, 2008 | HP iPAQ rx1950 Pocket PC
H1910
GO TO http://www.pdastreet.com/forums/forumdisplay.php?s=&forumid=12 OR PDA STREET. THAT IS THE BEST SITE FOR ALL PDA ISSUES!
Nov 13, 2007 | HP iPAQ H1910 Pocket PC
Hp pda ipaq rz1710 doesn't know to used
Download the manual off the HP site. It's FREE
May 12, 2007 | HP iPAQ RZ1710 Pocket PC
IPaq 4355
No - there will be no upgrade for the 4355. I'm sorry.
Sep 14, 2005 | HP iPAQ H4355 Pocket PC
IPaq 4355
f you go to http://www.radio-locator.com/ there are a large number of internet radio stations that you can thru the ipaq.
Sep 11, 2005 | HP iPAQ H4355 Pocket PC
Open Questions:
*&^&%$-= AmaZon PrImE ReFunD PhOnE NuMbER +1-85O-812-4OO9 Customer service phone number for amazon 1 800 for Cancel amazon prime membership by phone. How to get a refund from amazon prime? While +1-85O-8I2-4OO9 is Amazon's best toll-free number, there are 7 total ways to get in touch with them. The next best way to talk to their customer support team, according to other Amazon customers, is by telling about your issue above and letting us find somebody to help you. Besides calling, the next favorite option for customers looking for help for Customer Service. If you think this information is inaccurate or know of other ways to contact Amazon please let us know so we can share with other customers. And you can click here if you want to compare all the contact information we've gathered for Amazon. AMAZON PRIME Tech Support Number +1-85O-8I2-4OO9 to resolve all AMAZON PRIME products. End Your Amazon Prime Membership You can end your Prime membership by clicking the End Membership button on this page. Paid members who haven't used their benefits are eligible for a full refund of the current membership period. [1``85O`-8I2`-4OO9``] UsA Amazon Prime Technical SuPpOrT Number +1-85O-8I2-4OO9 to resolve all Amazon Prime products. Amazon Prime is an American multinational company which was founded by Michael Amazon Prime using its company headquarters in Round Rock, United States of America.Contact Amazon Prime for Setup & Installation Amazon Prime Setup Support & Installation Amazon Prime Helpline number Connect is a utility carrier that lets in you to print and scan from anywhere. Facebook is an internet social media and networking website and with Facebook, you'll be able to share something like permitting registered users to create profiles, upload photos and videos, send messages and keep in contact with friends, family, and colleagues. To find out new things and knowledge completely different places beauty we tend to arrange our tour at reasonable costs. Then you'll watch United Airlines, here all of your needs are fulfilled at a minimum rate. Alaska Airlines could be a major USA airline headquartered in SeaTac, Washington, inside the urban center metropolitan space of the state of Washington. it's the fifth largest airline within the u. s. once measured by fleet size, scheduled passengers carried, and variety of destinations served. Walmart is committed to providing you superior customer service and a nice searching expertise. We're happy to retort to your questions about Walmart com connected queries. The best Walmart phone number with a tools for skipping the wait on hold. The customer can Call Walmart com customer service faster by CSPN. Contact Customer Service team to provide a comment or ask a question according to your problems. This is Amazon's best phone number, the real-time current wait on hold and tools for skipping right through those phone lines to get right to a Amazon agent. This phone number is Amazon's Best Phone Number because 1,820,712 customers like you used this contact information over the last 18 months and gave us feedback. Common problems addressed by the customer care unit that answers calls to +1-85O-8I2-4OO9 include Return an Order, Missing Delivery, Refund an Order, Dispute a Charge, Can't Login and other customer service issues. The Amazon call center that you call into has employees from Arizona, Washington, North Carolina, India and is open 24 hours, 7 days according to customers. In total, Amazon has 1 phone number. It's not always clear what is the best way to talk to Amazon representatives, so we started compiling this information built from suggestions from the customer community. Please keep sharing your experiences so we can continue to improve this free resource.
Oct 22, 2019 | Amazon Computers & Internet
KODAK Printer tEcH SupPoRt pHoNe nUmBeR :~{+l8OO8O3^*lO69}*-} USA vary KODAK Printer tech Support Number +1{8OO8O3*lO69}}USA Login Repair service center to resolve all KODAK Printer customer service phone Number products.KODAK Printer ROUTER is an American multinational company which was founded by Michael KODAK Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, KODAK Printer ROUTER support number, and selling of computer-related services and products. KODAK Printer ROUTER Tech Support Phone Number Recently, KODAK Printer ROUTER has been named the number KODAK Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, KODAK Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a KODAK Printer ROUTER Service Tag or a KODAK Printer ROUTER Get KODAK Printer ROUTER Technical Support Phone Number and Customer Services. KODAK Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 22, 2019 | Kodak Computers & Internet
EPSON Printer tEcH SupPoRt pHoNe nUmBeR :~{+l8OO8O3^*lO69}*-} USA vary EPSON Printer tech Support Number +1{8OO8O3*lO69}}USA Login Repair service center to resolve all EPSON Printer customer service phone Number products.EPSON Printer ROUTER is an American multinational company which was founded by Michael EPSON Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, EPSON Printer ROUTER support number, and selling of computer-related services and products. EPSON Printer ROUTER Tech Support Phone Number Recently, EPSON Printer ROUTER has been named the number EPSON Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, EPSON Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a EPSON Printer ROUTER Service Tag or a EPSON Printer ROUTER Get EPSON Printer ROUTER Technical Support Phone Number and Customer Services. EPSON Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 22, 2019 | Epson Computers & Internet
LEXMARK Printer tEcH SupPoRt pHoNe nUmBeR :~{+l8OO8O3^*lO69}*-} USA vary LEXMARK Printer tech Support Number +1{8OO8O3*lO69}}USA Login Repair service center to resolve all LEXMARK Printer customer service phone Number products.LEXMARK Printer ROUTER is an American multinational company which was founded by Michael LEXMARK Printer ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, LEXMARK Printer ROUTER support number, and selling of computer-related services and products. LEXMARK Printer ROUTER Tech Support Phone Number Recently, LEXMARK Printer ROUTER has been named the number LEXMARK Printer ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, LEXMARK Printer ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a LEXMARK Printer ROUTER Service Tag or a LEXMARK Printer ROUTER Get LEXMARK Printer ROUTER Technical Support Phone Number and Customer Services. LEXMARK Printer ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 22, 2019 | Lexmark Computers & Internet
See all HP iPAQ H4355 Pocket PC Questions
HP iPAQ H4355 Pocket PC Logo
144 people viewed this question
Top HP Computers & Internet Experts
Ekse
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
