Question about LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive
Creating space on external hard drive
I have a Lacie 500GB external hard drive which I use to backup my Mac Book. The drive was getting full so I took some of the older backup files and moved them to the trash. But the remaining space did not change. The files are no longer visible on the drive but they are still taking up space.
I could try to empty the trash on my Mac but I am thinking that the trash in on my Mac drive now rather than my Lacie drive and if I empty the trash I may loose any chance of restoring the files so I can delete them in a more effective way.
  • Tracks fkap Apr 07, 2008
    Thank you for the help. I am a bit of a pack rat and don't like to delete files unless I have to in case I might need them.
    Thanks again.
  • pdvos Jun 11, 2008
    Time Machine ran out of space to use on my Lacie 500gig external drive. I moved the oldest files to the trash, but stopped the process when warned that "boot x" would also be deleted. I was concerned I might impact the drives connection to the Mac. Now the files are in the trash and not available to Time Machine, but the space is still occupied.
    Other than buying a new, bigger drive, since Time Machine will continue to eat space, is there a better solution?
When you move files to the Trash on a Mac you are just marking the files to be deleted next time you empty the trash. You are not actually deleting them when you move them to the trash. They will continue to take up space on your drive until you empty the trash.
Emptying the trash will delete everything in the Trash folder regardless of which drive it is stored on. If you have files you are not certain you want to delete that are located on your internal drive, open the Trash folder and move them temporarily out (like to the desk top), then empty the trash to delete all the ones on the external drive that you do want to clear off.
You will see that the free space has increased on the external drive. Now put back in the trash the files from your internatl drive you were thinking of deleting but not certain you wnated to (if that is your reason for not wanting to empty the trash. I'm not clear on why you would not want to delete them.)
Posted on Apr 07, 2008
SOURCE:
I have protools7 that wont load after I installed porsche design lacie 500gb hardrive
USB 2.0 is extremely slow for the purpose of doing direct recording. External drives are best used for backup after a project is done.
Dec 27, 2014 | LaCie 500GB PORSCHE DESIGN P9220 USB30...
LaCie 2big Triple - I replaced one drive, but capacity is wrong
Most likely the problem you are encountering is due to the RAID mode the device is set in. Most RAID arrays utilize multiple drives of the same size, or with drives of differing size, they just use a portion of the largest that matches the smallest drive. When the device rebuilt the array it partitioned off a portion of the 4tb drive of the same size as the existing 500gb drive. If you want to use full capacity of both drives you would need to use JBOD mode, which just strings the disks together into a storage pool using all available space. This won't offer the data redundancy of RAID1 or speed boost of RAID0, but should allow using full space.
Backup any vital data before doing anything, then look for a switch on the back. Rather than RAID0 or 1 the options may be labelled Safe or Fast, but JBOD is usually still labelled JBOD, or sometimes Big. You can try just flipping the switch to JBOD and seeing if it rebuilds to use all space. If that doesn't work you may need to remove the 4tb drive, connect it to a different system and erase it to get rid of the 500gb partition, then with the Lacie set to JBOD reinstall the 4tb drive so it will add its full size to the array.
The safest option though would be to buy another 4tb drive, backup all data and install both 4tb drives with the device set to RAID1/Safe. You would only get 4tb of total storage, but it would mirror the data on both drives so if one fails the other will still have your data. With JBOD you won't have any auto-backup. If a drive fails the data on it will be lost.
Jan 21, 2014 | LaCie 2big Network (2-disk RAID) (301257U)...
My mac wont find my lacie external hard drive
do u connect it in the keyboard? if yes then that doesnt work cause it doesnt have enough power to go through the keyboard. if u connect it in the back of mac then it should work
Aug 11, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
How can I format an external lacie drive to mount on both a PC and a MAC without partitioning
You can not use the drive on both systems. It has to be formatted for one or the other. To transfer your files, I would either backup your files to CD's/DVD's or try to network your Mac and PC, then just dump your files to a share folder of some sort.
Jan 09, 2010 | LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard...
Clarification re WD My Book storage space issue
this happen to a cousins laptop the only way to get it to sort out was to format the drive.it sounds harsh but it was the only way.
Dec 06, 2009 | Western Digital WDH1Q5000N 500GB MyBook...
Device i/o error on 500gb external usb hard drive, less than 6 mo
perhaps this? http://www.lacie.com/us/support/support_manifest.htm?id=10253&guideid=10167
Apr 01, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
My lacie is making clicking noise like clock
Hello
Have a look at the link below, it should be of help.
Click HERE to navigate.
Please feel free to let me know of you have any further questions.
Kind regards
Lock123
Dec 31, 2008 | LaCie External USB 2.0 500GB 7200 RPM 500...
Lacie 320 GB Hard Drive acting as if full when it's not.
Simplest solution: back up the data on the drive and repartition it (which will wipe it). Otherwise it sounds like it could be a problem with the file tree or structure of the drive, the configuration files could be corrupt, some program could have stored temporary files in a hidden place that cannot be deleted without making the program delete them, etc. If you are on a mac, spotlight Disk Utility and use it to repartition. If you are on a PC use the search thing from the start menu and find a program called disk management (or something similar to that, you'll know it when you see it.) external drives are annoying. i kick mine into the wall periodically for good measure.
Mar 22, 2008 | LaCie (300950) 400 GB Hard Drive
LaCie External USB 2.0 500GB 7200 RPM 500 GB Hard Drive Logo
359 people viewed this question
Top LaCie Computers & Internet Experts
Ekse
Marvin
Marvin
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
