My new 19 inch 1952 LG monitor stretched my display picture from what I use to have on my 17 inch. How do I adjust the height to width ratio for a picture that isn't distorted?
  • 242 Answers
Right-click your desktop, click properties
go to 'settings' and select the 19 inch monitor
now change the resolution to the format you want to use.
Set it to something like 1600x1200, or 1024x768
Posted on Apr 04, 2008
SOURCE:
How to change monitor aspect ratio for acer AL1916
The aspect ratio is expressed as two numbers separated by a colon (x:y). and they actually represent the relation between width and height of (in your case) your monitor.
Did you mean to change the resolution of your monitor? Could you please explain your problem in more detail? What is it exactly you want to achieve?
Oct 22, 2013 | Acer AL1916 A (Black, Silver) 19 inch LCD...
I hv lg 700s studioworks crt monitor... i hv set a resolution of 1280*1024, but now m not able to control some of its functions like its width size...width has gone out of the monitor, it isnt getting
Hello
Select reset option by monitor menu, set it to default first. Then try to adjust the width and height of the screen. If this does not help you, try other resolutions set by the system.
Nov 26, 2011 | LG Studioworks 700S 17" CRT Monitor
Can the monitor height be adjusted. It seems to be fixed to the stand with no adjustments?
No but you could always put something under the stand most can only be tilted for lighting reasons.
Jul 04, 2011 | Princeton Digital VL1916 19" LCD Monitor
We have just bought an LG 23 inch monitor. Everything okay on it except for the proper resolution. The monitor no. is W2343T. I have put the resolution of 1920 x 1080 and frequency of 60 hertz on it as...
I think the problem is going to be in the Windows software, and not the settings on the monitor. Not sure which type of computer or which Windows you're running, but get into control panel, monitor settings and see what you can do. Windows help and support might be able to assist you.
Here's an excerpt from ncix.com:
Cons Clumsy front panel controls
Vertically, picture is no larger than my old 17"
May require video card upgrade for higher resolutions
Front panel illuminated power button is distracting
Summary Overall, I really like this monitor. But don't expect a size increase vertically over a 17" display. I actually lost half an inch. I prefer a 16:10 aspect ratio so I'm not actually using the full wide available. If you're like me you can save some change and go for the 2243.
Not sure if that will help, but there it is.
Here is the whole blog:
http://ncix.com/products/index.php?mode=productreviewread&product_id=37490
Not sure if this will help, but you might check it out:
http://www.sevenforums.com/graphic-cards/19981-cannot-display-1920-x-1080-a-2.html
Good luck, and hope this helps.
Sep 20, 2010 | LG Computers & Internet
I m using acer moniter,i got the probs with its screen display..width of the screen is expand until max n now pic doesnt look good because width is wider then its height...can u pls assit me how to decrese...
You need to set the PC VIDEO resolution to the native resolution of the monitor to get correct aspect ratio (not adjustable at the monitor, the adjustment is doen at the PC VIDEO card setting), you need to find that out from your monitor owner manual.
Mar 22, 2010 | Computers & Internet
Stretched monitor? I have a 19 inch LG and it looks stretched. Please help.
Hello Rbeaudoin, Hi! the stretch thing is caused due to improper computer configuration, you need to load the VGA device driver for your PC. A properly setup device driver for your VGA will produce a resolution properly for your monitor.
explanation, you see, without the device driver, windows assumes several resolutions, most of the time, this does not match the monitor resolution, so the device driver when loaded, talks to your monitor, and identifies it, then sends the proper resolution info to the VGA and windows, so that windows can create an option for that resolution. using this proper resolution the monitor can display the video properly.
Mar 11, 2010 | LG Flatron L1750S 17" LCD Monitor
My lg 14 inch crt desktop monitor pictue become
The CRT has screen adjustments, there is a screen adjustment button on the monitor that will allow you to adjust the width of the image as well as the height etc.
Jan 21, 2010 | LG Studioworks 775N 17" CRT Monitor
Computer monitor does not use whole screen
Use the controls on the monitor to adjust the screen width.
Mar 30, 2009 | Computers & Internet
Lg flatron 775ft screen size problem
Hi Edit123,
U can chane output width and height from buttons given on LCD panel manually
Sep 19, 2008 | LG Flatron L1750S 17" LCD Monitor
Open Questions:
Computers & Internet Logo
101 people viewed this question
Ekse
Alun Cox
