Question about Smeg WD16BA Front Load Washer / Dryer
Samsung B1215J Door Error
Hi, I have a Samsung B1215J wich is now out of waranty, I keep getting error door on display screen, the washer thinks the door is open when actualy it's closed.
The 1st time it happend I just released the door with the manual pull cord under the kick cover on the bottom of the washer wich solved the problem but this morning I smelt like burning and now even releasing the door manualy then closing it does not work anymore (the door still releases it just doesnt think its closed when actualy it is).
My guess is that it needs soldering some where as the smell was similar to a solder defect (from experience) but I cant say for definate?
Would it be possible for someone to take me through it, step by step as I do own a soldering iron and could also post pictures.
Or explain what part maybe needed to be replaced.
Thanks in advance Dan
It sounds like the same problem I had with mine, eventually I ended up pulling down on the door release chord so hard it snapped off inside! I've fixed it now so please read on...
WARNING! Before doing any of the following make sure you unplug the machine (or at least switch it off at the wall socket).
I got around the door problem by taking the top off the machine and then reaching down inside to the small white latch which the yellow chord hooks onto and then simply pushing down on it with a screw driver (you could do it by hand if you get your hand down far enough).
Ok so with the door open and soaking wet towels removed I set about removing the door seal from the outer rim of the machine (it's easy enough to remove, just ease your way around the edge tugging a bit as you go!). The seal is held on tight with a wire band which stretches tight with a spring, when you have loosened the rubber enough to reveal this take it off in order to completely free the outer edge from the machine. It is not necessary to remove the entire seal, you just need to be able to reach inside to get a hand to the door release mechanism (with the machine unplugged!). Remove the two screws retaining the release mechanism and then reach in and pull the mechanism through the gap in the seal.
Check the wires - I'm guessing they have probably burnt out at the connection point (at least this is what had happened to mine). Carefully remove each of the four wire connectors (taking note of which one connects to each pin). Now at this point you'll need to ***** the extent of the damage to the connectors and release mechanism. I made mine safe by using lots of electrical insulation tape however you might need to purchase a new door release mechanism and connector(s). You should be able to find a replacement mechanism online (about £45 as I write this) but you might need to make a few calls if you also need to replace the connectors.
How the connectors get to this state I'm not too sure, I suspect it might either be from the connector getting wet or possibly the connector overheats from the mechanism being stuck on somehow.
If you can rewire the connectors safely so there is no chance of shorting then simply re-assemble everything in reverse order. The hardest part I found was getting the wire band back on as it's quite a fiddle!
Good Luck! : )
Posted on Nov 18, 2010
Samsung front load washer door will not lock
Hi
Are there any error codes on the display
Regards
Phillip
Dec 25, 2014 | Samsung 4.3 cu. ft. VRT Plus , Steam and...
D5 error
Error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle. The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly. But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem.
Hope helps.
Jul 28, 2011 | Samsung WF337AA Front Load Washer
My w/m have problem and the error code is the number DE.what is the problem??
DE error means door error wich means either the door lock or the main computer or the wiring in between.Sometimes all the parts above need to be replaced to repair this problem so beware it could get expensive to repair & i would honestly be thinking about replacing the samsung.
Feb 21, 2011 | Samsung Washing Machines
Not sure if this is the right wasing machine that matches ours or not but we are getting a d5 error and don't know what it means
The error code D5 OR DS is the same.Its mostly DS which looks like D5. The D5 error is actually DS. The code means the washer thinks the door is open or unlocked during the cycle.The door has to be checked.Is it getting properly close/open.If its getting close/open then the problem is related to faulty door locking assembly.But if its not getting proper close then there is any blockage causing the door to close or the door lock latch is faulty causing this problem. This has to be checked to confirm the fault.Keep updated with any more queries.Thanks.
Oct 14, 2010 | Samsung WF337AA Front Load Washer
It keeps flashing dl-f
Hi here is the meaning of the code and the corrective action needed. If you have any other questions please feel free to comment. Mike
"F/dL" Door Lock Error
A Door Lock Error occurs if the door cannot be unlocked. It will try to lock it 6 times before displaying the error.
  • Door Lock Mechanism broken or removed from the Door
  • Check Door Lock/Switch Assembly
  • Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
  • Door Lock/Switch Assembly Failure
Jan 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My front load washer is flashing DL. It is a maytag but I do not know the model number. I bought it about 2 years ago. I have it in my apartment and I think that it is 24" in width.
Hi There
I'm sending you this to read and hope this get's you in the right direction.
F/dL Door Lock Error
Thank you for writing to fix ya.
Best Regards Richard
Dec 15, 2009 | Maytag MAH8700A Front Load Washer
An error signal "DL" - door lock signal keeps coming on
Check for loose wires from the door lock to the control board.If no loose wires,
Replace the door lock switch.
May 23, 2009 | LG WM2277H Front Load Washer
Samsung washing machine B1215J E6 error what is this
I have the same E6 error code and violent movement when in spin. have tried to level and such with the same results. Always acts like it's majorly unbalanced
Feb 08, 2009 | Samsung WF337AA Front Load Washer
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Smeg WD16BA Front Load Washer / Dryer Logo
434 people viewed this question
Top Smeg Washing Machines Experts
Tom Chichester
myrlanthian
Are you a Smeg Washing Machine Expert? Answer questions, earn points and help others
