Metrologic Instruments 9520 Voyager Logo
A
Anonymous Posted on May 19, 2010
We have the barcodes to scan to emulate the keyboardwe are trying to scan units of blood that are for example 35 S 13048 the scanner reads 1313048..the first part is always messed up any ideas
WatsHVAC
Level 1:
Loyalty:
Visited the website for 30 consecutive days.
  • Contributor 35 Answers
  • Posted on May 27, 2010
WatsHVAC
Contributor
Level 1:
Loyalty:
Answers
35
Questions
0
Helped
53392
Points
87
Without knowing your application or scanner programming I can't be certain but it sounds like the scanner may be reading information on the code that you want parsed out. Check with whomever labels the units to find out exactly what is in the barcode (it's possible the "35 S " is not encoded) and then determine what you need to send to the program you are scanning the information in to. The scanner can be programed to pass along only specific characters that were scanned (i.e. the 13048) and to pre-pend or append additional characters as well (i.e. 35 S ). You'll need the scanner's programming manual to do that. Here's a link to the scanner's programming manual. Choose the first User's Guide on the list:
http://www.honeywellaidc.com/Site.aspx/na/en/product_center/product_support/?category=5&product=297
Good Luck!
My scanner is scanning but why it's not coming in system notepad while scan sound everything is ok fine?
Your scanner may be set/programmed for a mode other than "keyboard wedge". Scanners typically come with a quick start guide with multiple barcodes that you can scan to program the scanner for your particular needs.
If you are trying to scan into Notepad or other text application, you will want to make sure the scanner is in keyboard emulation/wedge mode, and if you want it to have a "return" or "tab" after the scanned barcode, you should have options for that also.
If you have a used scanner and do not have the quick start guide or manual, you will want to look it up and download it from the manufacturers website.
1helpful
Why doesn't it scan?
usually you need to configure the reader to tell it what kind of barcodes you want it to read and how to interpret & output the codes to your computer (whether you need prefix or suffixes to your codes( for automation))
the user manual for the reader has some bar codes to configure the settings for the scanner.
2answers
How do I connect the main unit to the front end?
Which main unit to Front end of what?
Sorry to say,but your question is not very clear about which product you need support.
Thus, please give some more detail on your product whenever you ask any support so that the experts can search the exact products and provide better support as there are hundreds of similar products in the market.
Please give exact Make and Model number of your product and also some more detail on your problem so that we could identify your issue better ant give appropriate solution.
Thank you.
2answers
Hi can u tell me that symbol scanner ls2208 will work on ATS
The LS2208 is a universal scanner with many supported interfaces. Please check the ATS if one of the interfaces are available. See the list below:
RS-232 IBM 468X/469X Keyboard Wedge Wand Emulation Undecoded Scanner Emulation USB Synapse Adapter
How to make a VC5090 auto send a carriage return after each scan
In the Wavelink TE can you setup the an Tab after Scan option for the 3270 emulation. For other emulations are there similar choices. Please check the Wavelink settings on the desktop machine and the upload the modified config files to the unit via ActiveSync.
LS2208 Can get it to work no driver
If your scanner shipped with a keyboard wedge cable and you are using a PS/2 to USB adapter all you should have to do is scan the IBM AT Notebook barcode on Adobe page 56 of 342 of the LS2208 Product Reference Guide. I suggest saving a copy of the document to your host then printing just that page. Scan the barcode then try scanning your barcode. If the computer still does not see your barcode try rebooting. If this still does not resolve your issue you may want to purchase a USB cable. The part number is CBA-U01-S07ZAR.
If you have the CBA-U01-S07ZAR and the scanner is not sending data then you should scan the HID Keyboard Emulation barcode from the QRG that came with the device or Adobe page 109 of 342 of the guide referenced above. I hope this helps.
Screen in Landscape mode
setting;
System
Screen
Landscape
1helpful
Symbol scanners (several models) not recognizing Code 39 Extended
The barcode must be a Code 39 barcode, not a Code 39 Extended or Full ASCII barcode. The Enable Code 39 Full ASCII must be scanned from the Symbologies section of the LS2208 Product Reference Guide (page 186 of 342). The Enable Function Key Mapping barcodes would have to be scanned if you are seeing something other than the tab happen when you scan into your application. In Word, for instance you will see the italics enable/disbled whenever the $I is encountered in the barcode.
As for the Covert to Code 39 Full ASCII- that is for Wand and Scanner emulation. The setting was having no effect because you were not connecting to either of these hosts.
2answers
Barcode scanner
please get programing manual for Z-3080 then
scan start of configuration barcode then USB emulation barcode then end of configuration barcode
probably your problem wiil be solved.
Top Metrologic Instruments Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Metrologic Instruments Computer and Internet Expert? Answer questions, earn points and help others
