Question about Panasonic DMR-E55 DVD Recorder
HAS SEVERAL ATTEMPTS TO INITIALISE OR RESETS WWHEN RECORDING
WHEN FIRST SWITCHED ON UNIT HAS SEVERAL ATTEMPTS TO INITIALISE, KEEPS GOING THROUGH SELF CHECK. THEN WHEN RECORDING KEEPS RESETTING ITSELF AND YOU HAVE TO SET RECORD AGAIN. EVERYTHING ELSE FUNCTIONS. AT NO TIME ARE ANY ERRORS REPORTED NEITHER IS UNIT RUNNING HOT.
  • 185 Answers
Ver common fault with these. Please see one of my earlier solutions shown below...
This is a common problem with this particular model. I can tell you what the fault is but unless you feel confident in using a soldering iron, the repair is best left to someone who is.
Ok...the fault you describe is caused by failure of IC001. This is a voltage regulator on the power board. You can identify the regulator as it is fixed to along thin metal strip near the middle of the board. It gets very hot during normal operation and will fail after a couple of years. The metal strip offers very little heat dissipation so the regulator operate in excess of its limits and therefore fails.
You need to take the lid off, remove the board which is mounted on the right hand side of the unit and replace the faulty regulator.
To remove the board, remove the fixing screw above the power connector on the back of the recorder, then the 4 fixing screws that secure the board. Next carefully remove the multi-connector that connects the board to other circuitry and lift the board clear.
A new regulator type STRG 6353 and can be obtained from several online suppliers. The old regulator can be removed by unscrewing the fixing screw, cuttiing the 5 pins with wire cutters. Then using a soldering iron, carefully removing the residual pins from the printed board making sure the print is not damaged.
Use some heatsink compound on the back of the new component, this will help it to dissipate heat more easily, use an additional heatsink if you can, which will help to prolong the life of the new regulator, then tightly secure it in position before carefully soldering the 5 pins.
Check that you have soldered it correctly without any shorted pins or tracks and reassemble the unit. I have repaired dozens of these successfully with exactly this fault.
Mains voltages can be lethal so always remove the power plug before doing any work like this and be sure of your own ability. If you're not confident in tackiling this, get someone to do it. Whatever you do, don't ditch the unit for such an easy to fix fault!
From your user name, I guess you're a radio amateur, so you should be on home territory.........
Comment by Palmbeach, posted on Feb 14, 2008 By the way, I would avoid using the recorder until you have repaired it. If the regulator shorts out, it will take several other components with it. I repaired one where a couple of diodes fried and part of the print fused and burnt, together with an internal fuse which blew.
Posted on Apr 18, 2008
6ya staff
SOURCE:
Initialising and finalising dvd -rw disc
Hi John, several reasons it could be, first off the DVD and Disk has to be compatible and finalise will only work if it was initialize on this DVD recorder. Cheers Greg.
Mar 30, 2015 | Televison & Video
Dmr-ex85 shows u81 code and is not functioning at all, says please wait but eventually just goes onto error code. no buttons will function?
Physically unplug power from the unit for a minute or two.
Connect power cord to unit and Simultaneously Press & Hold
both the [STOP] and Channel UP [^] for 5 seconds. This will
force Eject the DVD tray. Remove any disc if present.
Cycle the power again if necessary and wait for the unit to
go through its self check cycle. If after several attempts, and
you continue to get this error, then your Ram drive may need
to be replaced.
Jul 12, 2011 | Panasonic DMR-EX85EB-S DVD Recorder/HDD...
Hi I have a Magellan 320 that I have owned for 7 yrs. Due to the purchase of a chart plotter I have not used the 320 for about 2/3 years. Having switched it on this week the unit failed to gain a fix to...
I believe you have to input your location lat & long so that it knows basically where it is so that it can decide which sat's to use. Hope this may help.
NOW - CAN YOU HELP ME?
I have bought a 2nd hand 320 and want to upgrade to software V 3.15
I see you've done this with yours - can you tell me how to do it and send the s/w, please? Regards, Ron. Kerikeri NZ
Jan 18, 2011 | Magellan 12, 310, 315, 320
Pioneer HDD DVR DVR630H - in Australia
When fitting a replacement hdd the hdd must be paired with the DVR using the Service Remote Controller used only at Pioneer Service Centres.
Mar 17, 2017 | Pioneer DVR630H DVD Recorder
Disc initialization Toshiba D-R250SB recorder
can i suggest you record vhs tapes on maxell dvd-r or tdk dvd-r (if you wish to keep them) used the dvd-rw to record those sporting events / movies or specials that you might not be around for....(because any one can accidently erase an dvd-rw).......now that formatting dvd-rw issue. i found that dynex http://www.dynexproducts.com/c-11-storage-media.aspx dvdv-rw works best with toshiba . i record all the ultimate fights erase (format) after i look at and on to next good luck
May 28, 2009 | Toshiba DRW2 DVD Recorder
My Tascam DR-1 digital recorder will not turn on
To initialise the Tascam DR-05:
Press and hold the + button and the Mark button while turning on.
Thanks
Feb 03, 2009 | Tascam DR-1 MP3 Player
Stays in self check mode
If self check keeps going after 1 minute unplug machine and open top cover remove 4 screws that hold the recorder top cover remove disk reinsert screws and plug in see what happens.
Most of the time a small scratch or fingerprint on recorded disk cause these units to lock up
Jul 18, 2008 | Panasonic DMR-E55 DVD Recorder
Canon DC210 Camera
The error message is because, either
1. the disc was initialised on another camcorder, or maybe a PC, or
2. The disc has a recording on it in a different TV system (PAL v SECAM).
From the above, it may be you're using the same disc in two camcorders. To be sure of seeing what's on your disc you need to keep it with the same camcorder from 'initialise' to 'finalise' .
To be able to see the disc on a PC you need to finalise it on the camcorder. There's no other way to get to see your work on a PC.
Unfortunately I think you've lost your recordings this time.
Feb 08, 2008 | Canon DC210 DVD Camcorder
PANASONIC DMR-E55 DVD RECORDER
Try first unplugging unit from main, and holding the cancel button.
If that does not work try the following:
Hold at the same time the stop button on the main unit and key >10 on the remote control at the same time for about 5 seconds, until you get the word "initialised" on display. This will reset the unit to factory settings.
Jan 25, 2008 | Panasonic DMR-E55 DVD Recorder
Self test problem
Replacing IC001 STRG6353 maybe the reason on power board.
Be careful when replacing, it is attached to heat sink has five pins, closeby some miniture surface mounted parts.
Regards
capital98
Oct 24, 2007 | Panasonic DMR-E55 DVD Recorder
Panasonic DMR-E55 DVD Recorder Logo
82 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
